Subscribe and Save with the Xometry 3D Pro Membership
The More You Print, The More You Save
Save Up to $2,400 on 3D Printing Orders for Just $48*
Designed with professional architects, designers, and engineers who rely heavily on 3D printing technologies in mind, Xometry 3D Pro Membership is a subscription service that gives you the ability to print using 7 different Additive technologies at substantial savings of up to $200 every 30 days. We will email you special member coupon codes every month. If you order 3D-printed parts more than once a month or spend more than a couple hundred dollars per month on additive manufacturing, it would be irrational not to consider this service. Your purchasing department will love you.**
Just $4 Per Month*
*With an annual plan for $48 (charged upfront), the 3D Pro Membership works out to just $4 per month. Pay once, and we'll take care of the rest. Your special member codes will arrive in your inbox promptly so you can get to work. Your 3D Pro membership pays for itself in the first month.
Special Offers Every Month
We will email you a collection of special member coupon codes every 30 days, adding up to $200 in savings every month. That's a total savings of $2,400 over a 12-month period. Simply copy and paste the code into the checkout page. These codes are single-use only and may not be combined with other offers. The best part is...they never expire!
Up to $2,400 in Savings
Save on 3D Printing orders in any of our 7 additive manufacturing technologies including Carbon DLS™, Direct Metal Laser Sintering, and HP Multi Jet Fusion every single month, or a total of $2,400 in discounts over 12 months. Select from the world's biggest selection of industrial additive manufacturing plastic and metal materials.
Access Seven Additive Technologies from Your Desktop
Stereolithography (SLA)
HP Multi Jet Fusion (HP MJF)
PolyJet 3D (PJ3D)
Direct Metal Laser Sintering (DMLS) is a 3D metal printing technology that builds prototype and production metal parts from a CAD file using a laser to selectively fuse a fine metal powder in either stainless steel or aluminum materials. A DMLS machine is capable of producing highly complex features and all-in-one assemblies using metal materials that would be difficult to achieve with subtractive manufacturing techniques.
Our DMLS metal 3D printing service typically offers to build volumes up to 250 x 250 x 325 mm, but we may be able to accommodate larger part volumes upon request in the quote. (See our Manufacturing Standards for more details) A good first step is to find out the cost of the parts you need using DMLS and compare them to other 3D printing processes and CNC machining.
Carbon DLS™
**Just an expression. Xometry does not actually guarantee that your purchasing team will love you. Love is a fickle thing and depends on many factors outside our control. Or your control. But saving the company money probably doesn't hurt.
