3D Printing Services for Baltimore, Maryland
High Quality 3D Printing serving Baltimore, Maryland | 60+ Materials Available
Your Baltimore, Maryland 3D Printing Service: 3D Prototypes and Production Parts
Fused Deposition Modeling (FDM) is a 3D printing technology widely known for its speed, accuracy, and competitive cost. A machine precisely extrudes melted plastic filament to create a part. Parts are very rigid, especially compared to Selective Laser Sintering (SLS), which makes them a great fit for projects with a rigidity requirement. Xometry's FDM solution offers large build volumes up to 24 ″ x 36″ x 36″, a variety of colors, and a diverse selection of production-grade thermoplastics — from ABS to Polycarbonate to Ultem.
