Injection molding done your way:Great prices and engineering support on simple and complex jobs
Xometry Logo
Sign In
Cookie Policy
Local 3D Printing Services in Milwaukee
High Quality Milwaukee 3D Printing | 60+ Materials Available
3D Printed Part Milwaukee3D Printed Part Milwaukee
Massive Network Capacity
Guaranteed Quality
Guaranteed Quality
Your Milwaukee 3D Printing Service: 3D Prototypes and Production Parts
Xometry is an industry-leading 3D printing service. Whether you need prototypes or production parts, we can make them for you in as fast as a day. We are your one-stop-shop for accurate, precise custom 3D printed parts at a low cost. Upload your 3D CAD file to get a quote and lead time within seconds. We use the latest additive manufacturing processes to build affordable functional prototypes & end-use parts in over 60 metals and plastics.
Stereolithography (SLA)
HP Multi Jet Fusion (HP MJF)
PolyJet 3D (PJ3D)
Carbon DLS™
Metal Binder Jetting
Commercial and industrial 3D printing services
Quick Links
  • Contact Us
  • Help Center
  • Our Story
  • Xometry Go Green
  • Careers
  • Legal
  • Press
  • Refer a Colleague
Locations
  • 7529 Standish Place
    Suite 200-220
    Rockville, MD 20855
  • 7940 Cessna Avenue
    Gaithersburg, MD 20879
    240-252-1138
  • 7315 Wisconsin Ave
    Suite 300 East
    Bethesda, MD 20814
  • 446 East High Street
    Lexington, KY 40507
  • 11777 San Vicente Blvd
    Suite 747
    Los Angeles, CA 90049
  • 117 Wright Industrial Cove
    Jackson, TN 38301
  • Ada-Lovelace-Str. 9
    85521 Ottobrunn, Germany
    +49 32 22 109 8186
    www.xometry.eu
Xometry Go Green Initiative
2.0M+
LBS OF C02 OFFSET
Xometry
