We are excited to offer Glass-Filled Nylon as a new Selective Laser Sintering (SLS) material, now available on Xometry's instant quoting platform! This material allows you to have the same complexity of Durable White Nylon but with a much bigger build area, as well as parts that are mechanically more robust. Check out exactly how Glass-Filled Nylon can benefit you.
Glass-Filled Nylon provides:
1. Stiffer Plastic Parts
Glass-Filled Nylon is stiffer than regular nylon-12, because of the glass infill along the entirety of the part. This infill drastically prevents warping and breaking, especially for larger parts. Glass-Filled Nylon parts are highly heat resistant, which allows them to operate under elevated temperatures, making them ideal for uses in the aerospace industry, as well as many others. It’s important to note that Glass-Filled Nylon parts will be stiffer than standard unfilled nylon-12, meaning very fine features could be more brittle.
2. Larger Size Capabilities
When you are being limited in size by standard nylon-12, this material is perfect for parts that don’t normally fit within our build volume of about a 12 inch cube. The overall build volume for Glass-Filled Nylon is 26” x 15” x 23”. This can be for a few large parts, or many smaller pieces. Make sure to design wall thicknesses appropriate to a part’s size; as the size increases, walls should thicken up to about 0.1-0.2” max.
3. Cost-Effective Complex Parts
Glass-Filled Nylon is a cost-effective option that will save you money for larger, more complex parts, as compared to standard nylon-12. This pricing solution occurs in part due to the Complexity Paradox, a concept detailing that as 3D parts become more complex, often with organic shapes and pockets, the price will become more competitive versus traditional manufacturing.
4. Fast Lead Times
Parts typically are produced within 2-5 business days. Often, entire production runs can finish within a week!
Key Takeaways
Overall we recommend this new material as a fantastic alternative to parts that need to be more mechanically robust than regular SLS parts, while still maintaining SLS's cost-effectiveness.
Check out our Selective Laser Sintering design guide for an extensive look into this 3D printing process, or our Glass-Filled Nylon Data Sheet for in-depth specifications and properties!
Generate an instant quote with Glass-Filled Nylon for your parts today!
