Order Status
Search
CapabilitiesCustom Plastic Injection Molding ServiceNew Mexico
Injection Molding Services for New Mexico
High Quality New Mexico Injection Molding | Our skilled engineering team guides you through every step of the molding process.
Your New Mexico Injection Molding Service: Plastic Prototypes and Production Parts
Xometry injection molding is a highly customized service providing on-demand prototype and production molding for New Mexico. We take a customer-first approach which means we find the right injection molding supplier within our manufacturing supplier network to mold the parts the way you need them—without design compromises—at the right price point. We offer expert consultation on each injection mold quote and project managers on every order to move your parts from design to production. Our team has experience across industries, including medical, automotive, aerospace, consumer goods, and more. First-time buyers receive $500 off their first mold with Xometry.
Injection Molded Parts
capacity
quote engine
quality assurance
Insert Molding
Insert molding is an injection molding process that works especially well for parts that have threaded holes. It can also help you create better wheels, pulleys, fan blades, and other similar parts. Done correctly, insert molding can help:
  • Improve reliability: Metal inserts will assure the function of threads and mitigate wear and tear over the part’s life.
Overmolding
Injection Molding Services near New Mexico
Albuquerque
New Mexico
Injection molding in New Mexico
