Tube Bending Services for North Carolina
High Quality North Carolina Tube Bending and tube fabrication services for metallic pipe and tube stock to meet your needs.
Your North Carolina Tube Bending Service
Our project managers and experts personally review and manually quote each tube bending project to ensure we meet your unique needs while providing a fast and easy manufacturing experience. Review our capabilities in the sections below to learn more about the different tube bending machines and techniques.
Tube Bending Capabilities in North Carolina
- Roll Tube Bending
- Rotary Draw Tube Bending
- Mandrel Tube Bending
- Compression Bending
Compression Bending – With compression bending, the tube or pipe is clamped in place, and force is directly applied, which creates the bend. This process is primarily utilized for single bend applications. No internal support is used with compression bending, which typically produces an oval cross-section and may result in crushing of the bend. Bends generally are limited to angles of 120 degrees or less.
Material Options
North Carolina Tube Bending Material Options
Material | Round Tube | Pipe | Rectangular Tube | Square Tube |
Material Aluminum | Round Tube
| Pipe
| Rectangular Tube
| Square Tube
Material Steel | Round Tube
| Pipe
| Rectangular Tube
| Square Tube
Material Stainless Steel Tubes | Round Tube
| Pipe
| Rectangular Tube
| Square Tube
Material Brass | Round Tube
| Pipe
| Rectangular Tube
| Square Tube
Material Copper | Round Tube
Material Titanium | Round Tube
Tube Bending Services near North Carolina
