CNC Machining Service
Online CNC machining service for prototypes and production parts
Get an Instant Quote
Xometry's Online CNC Machining Service
Xometry is the industry leader in custom, quick-turn CNC machining services. You can upload your CAD files to our online Instant Quoting Engine to receive a CNC machining quote within seconds.
Our massive partner network means that whatever your part, we have a shop and a machine that can make it. We integrate seamlessly with over 3,000 vetted manufacturing partners in the U.S. including ITAR qualified facilities and we are ISO 9001:2015 and AS9100D certified.
With such a high volume of qualified shops and certified materials available, using Xometry takes the guesswork out of CNC part sourcing. Our partners support the latest in CNC machining and turning processes, can support a high level of part complexity, and provide exceptional surface finishes. We can also machine and inspect to any 2D drawing, always ensuring you have the CNC machined parts you need, at-quality and on time.
CNC Processes
  • 5 Axis Machining
  • 4 Axis Machining
  • 3 Axis Machining
  • Right Angle Milling
See more on CNC Milling
  • Dual Spindle Lathes
See more on CNC Turning
CNC Materials
Available aluminum varieties:
  • Aluminum 5052
  • Aluminum 7075
  • Aluminum 7075-T6
  • Aluminum 6063-T5
  • Aluminum 7050-T7451
  • Aluminum MIC-6
  • Aluminum 6061-T6
  • Aluminum 2024-T3
Available brass varieties:
  • Brass C360
  • Brass 260
  • C932 M07 Bearing Bronze
Available copper varieties:
  • EPT Copper C110
  • Copper 101
Available plastic varieties:
  • ABS
  • Acetal [Delrin]
  • Acrylic
  • G-10 Garolite
  • Nylon 6/6
  • PEEK
  • Polycarbonate
  • PTFE [Teflon]
  • Polypropylene
Available steel varieties:
  • Alloy Steel 4130
  • Alloy Steel 4140
  • ASTM A36
  • Stainless Steel 15-5
  • Stainless Steel 17-4
  • Stainless Steel 18-8
  • Stainless Steel 303
  • Stainless Steel 304
  • Stainless Steel 316/316L
  • Stainless Steel 416
  • Stainless Steel 420
  • Steel 1018
  • Steel A36
Available titanium varieties:
  • Titanium Grade 2
  • Titanium 6Al-4V
Available zinc varieties:
  • Zinc Sheet Alloy 500
CNC Finishes
As-Milled
Bead Blast
Powder Coat
Custom
Overview: What is CNC?
The Basics of CNC Machining
CNC (Computer Numerical Controlled) machining is a means to remove material with high precision machines, using a wide variety of cutting tools to create the final design. Common CNC machines include vertical milling machines, horizontal milling machines, lathes, and routers.
How CNC Machining Works
To successfully make a part on a CNC machine, skilled machinists create programmed instructions using CAM (Computer Aided Manufacturing) software in conjunction with the CAD (Computer Aided Design) model provided by the customer. The CAD model is loaded into the CAM software and tool paths are created based on the required geometry of the manufactured part. Once the tool paths are determined, the CAM software creates G-Code (machine code) that tells the machine how fast to move, how fast to turn the stock and/or tool, and where to move the tool or workpiece in a 5-axis X, Y, Z, A, and B coordinate system.
Types of CNC Machining
There are several types of CNC machine — namely the CNC lathe, CNC mill, CNC router, and Wire EDM
With a CNC lathe, the part stock turns on the spindle and the fixed cutting tool is brought into contact with the workpiece. Lathes are perfect for cylindrical parts and are easily set up for repeatability. Conversely, on a CNC mill the rotating cutting tool moves around the workpiece, which remains fixed to a bed. Mills are all-purpose CNC machines that can handle most any machining process.
CNC machines can be simple 2-axis machines where only the tool head moves in the X and Z-axes or much more complex 5-axis CNC mills, where the workpiece can also move. This allows for more complex geometries without requiring extra operator work and expertise. This makes it easier to produce complex parts and reduces the chance of operator error.
Wire Electrical Discharge Machines (EDMs) take an entirely different approach to CNC machining in that they rely on conductive materials and electricity to erode the workpiece. This process can cut any conductive material, including all metals.
CNC routers, on the other hand, are ideal for cutting soft sheet materials such as wood and aluminum and are more cost-effective than using a CNC mill for a similar job. For harder sheet materials such as steel, a waterjet, laser, or plasma cutter is required.
Benefits of CNC Machining
The benefits of CNC machining are numerous. Once a tool path is created and a machine is programmed, it can run a part 1 time, or 100,000 times. CNC machines are built for precise manufacturing and repeatability which makes them cost-efficient and highly scalable. CNC machines can also work with a variety of materials from basic aluminum and plastics to more exotic materials like titanium — making them the ideal machine for almost any job.
Xometry's CNC Manufacturing Standards
  • Sharp edges will be broken and deburred by default. Critical edges that must be left sharp should be noted and specified on a print.
  • For features of size (Length, width, height, diameter) and location (position, concentricity, symmetry) +/- 0.005”.
  • For features of orientation (parallelism and perpendicularity) and form (cylindrical, flatness, circularity, and straightness) apply tolerances as follows:
0-12”
Tolerance of 0.005”
Angularity
+/- ½ degree
Over 12”-24”
Tolerance of 0.010”
Angularity
+/- ½ degree
Over 24"-36"
Tolerance of 0.015625" (1/64)
Angularity
+/- 1 degree
Over 36"-60"
Tolerance of 0.03125" (1/32)
Angularity
+/- 1 degree
Over 60"
Tolerance of 0.0625" (1/16)
Angularity
+/- 1 degree
Featured CNC Resources
Ready to quote?
Machine Hours
13MM+
Parts Quoted
500k+
Get your instant CNC quote
