CNC Machining Service in Chicago
Get an Instant Quote
Xometry's Chicago CNC Machining Service
Xometry is the industry leader in custom, quick-turn CNC machining services for rapid prototyping and production parts. We deliver daily to Chicago. Our online Instant Quoting Engine gives you a CNC machining quote within seconds. Then we make your machined metal or plastic parts and get them to your door in as few as 2 days. We inspect the parts and guarantee their quality.
CNC Processes
  • 5 Axis Machining
  • 4 Axis Machining
  • 3 Axis Machining
  • Right Angle Milling
See more on CNC Milling
  • Dual Spindle Lathes
See more on CNC Turning
CNC Materials
Available aluminum varieties:
  • Aluminum 5052
  • Aluminum 7075
  • Aluminum 7075-T6
  • Aluminum 6063-T5
  • Aluminum 7050-T7451
  • Aluminum MIC-6
  • Aluminum 6061-T6
  • Aluminum 2024-T3
Available brass varieties:
  • Brass C360
  • Brass 260
  • C932 M07 Bearing Bronze
Available copper varieties:
  • EPT Copper C110
  • Copper 101
Available plastic varieties:
  • ABS
  • Acetal [Delrin]
  • Acrylic
  • G-10 Garolite
  • Nylon 6/6
  • PEEK
  • Polycarbonate
  • PTFE [Teflon]
  • Polypropylene
Available steel varieties:
  • Alloy Steel 4130
  • Alloy Steel 4140
  • ASTM A36
  • Stainless Steel 15-5
  • Stainless Steel 17-4
  • Stainless Steel 18-8
  • Stainless Steel 303
  • Stainless Steel 304
  • Stainless Steel 316/316L
  • Stainless Steel 416
  • Stainless Steel 420
  • Steel, Low Carbon
  • Steel A36
Available titanium varieties:
  • Titanium Grade 2
  • Titanium 6Al-4V
Available zinc varieties:
  • Zinc Sheet Alloy 500
CNC Finishes
As-Milled
Bead Blast
Powder Coat
Custom
Featured CNC Resources
Ready to quote?
Machine Hours
13MM+
Parts Quoted
500k+
Get your instant CNC quote
