High Quality CNC Machining in 40+ Metal and Plastic Materials. AS9100D and ISO 9001:2015 Certified.
Xometry is the industry leader in custom, quick-turn CNC machining services for rapid prototyping and production parts. We deliver daily to Columbus. Our online Instant Quoting Engine gives you a CNC machining quote within seconds. Then we make your machined metal or plastic parts and get them to your door in as few as 2 days. We inspect the parts and guarantee their quality. Our massive partner network means that whatever your part, we have a shop and a machine that can make it. We integrate seamlessly with over 5,000 vetted manufacturing partners globally including over 3,000 in the U.S. Our network includes ITAR qualified facilities and Xometry is ISO 9001:2015 and AS9100D certified.
With over 40 engineering-grade materials available, using Xometry takes the guesswork out of CNC part sourcing. Our partners support the latest in CNC machining and turning processes, can support a high level of part complexity, and provide exceptional surface finishes. We can also machine and inspect to any 2D drawing, always ensuring you have the CNC machined parts you need, at-quality and on time.
