Injection molding done your way:Great prices and engineering support on simple and complex jobs
Xometry Logo
Sign In
Cookie Policy
CNC Machining Service in New York
High Quality CNC Machining in 40+ Metal and Plastic Materials. AS9100D and ISO 9001:2015 Certified.
CNC Part New YorkCNC Part New York
Massive Network Capacity
Guaranteed Quality
Guaranteed Quality
Xometry's New York CNC Machining Service
Xometry is the industry leader in custom, quick-turn CNC machining services for rapid prototyping and production parts. We deliver daily to New York. Our online Instant Quoting Engine gives you a CNC machining quote within seconds. Then we make your machined metal or plastic parts and get them to your door in as few as 2 days. We inspect the parts and guarantee their quality. Our massive partner network means that whatever your part, we have a shop and a machine that can make it. We integrate seamlessly with over 5,000 vetted manufacturing partners globally including over 3,000 in the U.S. Our network includes ITAR qualified facilities and Xometry is ISO 9001:2015 and AS9100D certified.
With over 40 engineering-grade materials available, using Xometry takes the guesswork out of CNC part sourcing. Our partners support the latest in CNC machining and turning processes, can support a high level of part complexity, and provide exceptional surface finishes. We can also machine and inspect to any 2D drawing, always ensuring you have the CNC machined parts you need, at-quality and on time.
CNC Threaded Hole
Our CNC Materials
  • Aluminum 5052
  • Aluminum 7075
  • Aluminum 7075-T6
  • Aluminum 6063-T5
  • Aluminum 7050-T7451
  • Aluminum MIC-6
  • Aluminum 6061-T6
  • Aluminum 2024-T3
Brass/Bronze
  • Brass C360
  • Brass 260
  • C932 M07 Bearing Bronze
Get an instant quote or check out more information about our brass/bronze materials.
Copper
  • EPT Copper C110
  • Copper 101
Get an instant quote or check out more information on our copper materials.
Plastics
  • ABS
  • Acetal [Delrin]
  • Acrylic
  • G-10 Garolite
  • Nylon 6/6
  • PEEK
  • Polycarbonate
  • PTFE [Teflon]
  • Polypropylene
Get an instant quote or check out more information on our plastic materials.
Steel
  • Alloy Steel 4130
  • Alloy Steel 4140
  • ASTM A36
  • Stainless Steel 15-5
  • Stainless Steel 17-4
  • Stainless Steel 18-8
  • Stainless Steel 303
  • Stainless Steel 304
  • Stainless Steel 316/316L
  • Stainless Steel 416
  • Stainless Steel 420
  • Steel, Low Carbon
  • Steel A36
Get an instant quote or check out more information about our steel materials.
Titanium
  • Titanium Grade 2
  • Titanium 6Al-4V
Get an instant quote or check out more information about our titanium materials.
Zinc
  • Zinc Sheet Alloy 500
Get an instant quote or check out more information about our zinc materials.
Our CNC Finishes
As Milled
Bead Blast
Powder Coat
Custom
CNC machined part
Ready to Quote?
Xometry Logo
ITAR Registered
