CNC Turning
CNC (Computer Numerical Controlled) Machining is a means to remove material using high speed, precision machines that use a wide variety of cutting tools to create the final design, including vertical milling machines, horizontal milling machines, lathes, and lathes with live tooling. CNC turning is a process that uses a lathe where the part stock rotates while the cutting tools remain stationary. On a multi-axis CNC milling machine, the cutting tools move while the stock remains fixed. CNC turning with a live tooling lathe combines the capabilities of both CNC lathes and mills to dramatically decrease lead times and increase the amount of features that can be machined. While multi-axis and right angle mills can rapidly create complex geometric shapes, more complex cylindrical shapes can be more cost effectively manufactured using CNC turning with a live tooling lathe.
XOMETRY'S CNC TURNING: LATHE AND LIVE ACTION TOOLING
  • Dual Spindle Lathes with 32″ Swing
  • 18″ Max Diameter
  • 8″ Chuck
CNC Milling materials are available in metals and plastics. Material selection is critical in determining the overall functionality and cost of a part. The designer must define the material characteristics key to the part’s design – hardness, rigidity, chemical resistance, heat treatability, thermal stability, and so on. Xometry machines a wide variety of metal and plastic materials.
CNC Design Guide
CNC machining is one of the fastest way to build functional prototypes, product molds, low to high volume production runs, and fixtures.
Learn how to design your parts for CNC machining to ensure high quality and cost-effective results. Download your free guide today.
 Download Guide
Manufacturing On Demand
Massive scale when you need it
We integrate seamlessly with over 900 vetted manufacturing partners in the US including ITAR qualified facilities. You are no longer subject to the limits of your existing local suppliers. Dynamically scale your manufacturing capacity when you need the flexibility. And Xometry guarantees your custom parts will be built to your specifications.
Extensive capabilities on one platform
Xometry’s Partner Network offers wide-ranging capabilities from CNC Machining, industrial-grade 3D Printing, Sheet Metal, Urethane Casting, and production-grade Injection Molding. All just a click away.
Fast lead times, low prices, & lightning-fast quoting
Xometry gives you instant pricing, lead times, and DFM on materials and manufacturing processes for your custom parts. Our proprietary pricing engine uses Machine Learning to analyze 3D CAD drawings and provide instant feedback on pricing, lead times, and the best process to make your custom parts. We turn around Injection molding within 24 hours.
back to CNC Machining
