Xometry Logo
Sign In
Search
CNC
CNC Machining
Other Services
Injection Molding Services for Evanston, IL
Injection Molding Evanston
Your Evanston Injection Molding Service: Plastic Prototypes and Production Parts
Xometry injection molding is a highly customized service providing on-demand prototype and production molding for Evanston, Illinois. We take a customer-first approach which means we find the right injection molding supplier within our manufacturing supplier network to mold the parts the way you need them—without design compromises—at the right price point. We offer expert consultation on each injection mold quote and project managers on every order to move your parts from design to production. Our team has experience across industries, including medical, automotive, aerospace, consumer goods, and more. First-time buyers receive $500 off their first mold with Xometry.
Massive Network Capacity
Guaranteed Quality
Guaranteed Quality
Insert Molding
Overmolding
Injection molding services in Evanston
