Aluminum 6061
Online CNC machining service for prototypes and production parts
Get an Instant Quote
CNC Machined 6061 Aluminum
Xometry is trusted by thousands to deliver high-quality machining using aluminum alloy 6061. Aluminum 6061 is one of the most common materials used for CNC Machining. Easily machined and lightweight, it is an ideal material for prototypes. It has excellent joining characteristics and accepts applied coatings easily. The natural finish of aluminum 6061 is light grey, and will shine where cut or milled. It combines relatively high strength with good workability and high resistance to corrosion. The T8 and T9 tempers offer better chipping characteristics compared to T6 temper. Aluminum 6061-T6511 is the specific temper for the most commonly used bar stock, and 6061-T651 for plate or sheet stock.
Xometry Supplies offers high quality, custom cut Aluminum 6061-T6 with free shipping and prices that are among the industry's lowest.
Xometry's Online CNC Machining Service
Xometry is the industry leader in custom, quick-turn CNC machining services. You can upload your CAD files to our online Instant Quoting Engine to receive a CNC machining quote within seconds.
Our massive partner network means that whatever your part, we have a shop and a machine that can make it. We integrate seamlessly with over 3,000 vetted manufacturing partners in the U.S. including ITAR qualified facilities and we are ISO 9001:2015 and AS9100D certified.
With such a high volume of qualified shops and certified materials available, using Xometry takes the guesswork out of CNC part sourcing. Our partners support the latest in CNC machining and turning processes, can support a high level of part complexity, and provide exceptional surface finishes. We can also machine and inspect to any 2D drawing, always ensuring you have the CNC machined parts you need, at-quality and on time.
CNC Processes
  • 5 Axis Machining
  • 4 Axis Machining
  • 3 Axis Machining
  • Right Angle Milling
See more on CNC Milling
  • Dual Spindle Lathes
See more on CNC Turning
CNC Materials
Available aluminum varieties:
  • Aluminum 5052
  • Aluminum 7075
  • Aluminum 7075-T6
  • Aluminum 6063-T5
  • Aluminum 7050-T7451
  • Aluminum MIC-6
  • Aluminum 6061-T6
  • Aluminum 2024-T3
Available brass varieties:
  • Brass C360
  • Brass 260
  • C932 M07 Bearing Bronze
Available copper varieties:
  • EPT Copper C110
  • Copper 101
Available plastic varieties:
  • ABS
  • Acetal [Delrin]
  • Acrylic
  • G-10 Garolite
  • Nylon 6/6
  • PEEK
  • Polycarbonate
  • PTFE [Teflon]
  • Polypropylene
Available steel varieties:
  • Alloy Steel 4130
  • Alloy Steel 4140
  • ASTM A36
  • Stainless Steel 15-5
  • Stainless Steel 17-4
  • Stainless Steel 18-8
  • Stainless Steel 303
  • Stainless Steel 304
  • Stainless Steel 316/316L
  • Stainless Steel 416
  • Stainless Steel 420
  • Steel 1018
  • Steel A36
Available titanium varieties:
  • Titanium Grade 2
  • Titanium 6Al-4V
Available zinc varieties:
  • Zinc Sheet Alloy 500
CNC Finishes
As-Milled
Bead Blast
Powder Coat
Custom
Overview: What is CNC?
Xometry's CNC Manufacturing Standards
  • Sharp edges will be broken and deburred by default. Critical edges that must be left sharp should be noted and specified on a print.
  • For features of size (Length, width, height, diameter) and location (position, concentricity, symmetry) +/- 0.005”.
  • For features of orientation (parallelism and perpendicularity) and form (cylindrical, flatness, circularity, and straightness) apply tolerances as follows:
0-12”
Tolerance of 0.005”
Angularity
+/- ½ degree
Over 12”-24”
Tolerance of 0.010”
Angularity
+/- ½ degree
Over 24"-36"
Tolerance of 0.015625" (1/64)
Angularity
+/- 1 degree
Over 36"-60"
Tolerance of 0.03125" (1/32)
Angularity
+/- 1 degree
Over 60"
Tolerance of 0.0625" (1/16)
Angularity
+/- 1 degree
Featured CNC Resources
Ready to quote?
Machine Hours
13MM+
Parts Quoted
500k+
Get your instant CNC quote
