Resources3D Printing DesignProduct Update: New Materials for HP Multi Jet Fusion (MJF)
Now you can order MJF parts in two new materials: Nylon 11 and TPU 95A.
By Serena Ngoh
October 9, 2020
 2 min read
April 18, 2024
 12 min read
Xometry’s HP Multi Jet Fusion service is a more cost-effective way than ever to buy 3D printed parts. Now, you can order MJF parts in two new materials: Nylon 11 and TPU 95A.
New Materials for MJF
Xometry’s HP Multi Jet Fusion service is now adding two new materials: Nylon 11 (PA 11) and TPU 95A (Estane M95A). These materials will join Nylon 12 (PA 12) and glass-filled Nylon 12 (PA 12 GB) to round out HP Multi Jet Fusion’s current material offerings.
As seen below, the new materials are available in the drop-down menu in Xometry’s Instant Quoting Engine℠
Nylon 11 has optimal mechanical properties, with high chemical resistance, ductility, and enhanced elongation-at-break. Its pliable nature and strength mean that Nylon 11 can withstand impact, making it an excellent choice for defense, sports, and medical prosthetic applications.
TPU 95A is a thermoplastic urethane, with high levels of flexibility and tear strength. The material exhibits rubber-like qualities—much like a shoe sole—allowing for a range of end-use applications.
Technical Specifications for HP Multi Jet Fusion Materials
Name and Standard Color% Elongation at Break (XY, Z)MPa Tensile Strength (XY, Z)°C Heat Deflection (HDT @66 PSI, @264 PSI)°C Melting Point
HP MJF Nylon 12, Matte Gray
20%, 15%
48, 48 MPa
175°C, 95°C
°C Melting Point
187°C
HP MJF Nylon 12 Glass-Filled, Matte Gray
10%, 10%
30, 30 MPa
174°C, 114°C
°C Melting Point
186°C
HP MJF Nylon 11, Matte Gray
55%, 40%
52, 52 MPa
185°C, 54°C
°C Melting Point
202°C
HP MJF TPU 95A, Matte Gray
400%, 90%
17, 8 MPa
Shore A 90-95
°C Melting Point
80, 35
How to Achieve the Highest Cost Savings
  • Nylon 12 is a safe bet: parts printed in Nylon 12 will offer the highest cost savings when compared to the other MJF material options
  • Forget minimum quantities: low quantities (of approximately 20 or less) will offer the same per part pricing as higher quantities
  • Try designing small: parts measuring 4” x 4” x 4”—or otherwise fitting within a 4” box—could be 50% cheaper than before
Serena Ngoh
