ResourcesMachining DesignChoosing the Right Metal Process
CNC Machining, DMLS, Metal Binder Jetting, or Sheet Metal?
April 18, 2024
 12 min read
When it comes to building end-use metal parts, we offer a few options: CNC MachiningDMLS (Direct Metal Laser Sintering)Metal Binder Jetting, and Sheet Metal fabrication.
To help you select the right one for your next project, we put together a brief summary of these four processes, including the key benefits, available materials, lead times, and more.
As you read through this post, note that metal 3D printing and CNC machining are not mutually exclusive; they can actually complement each other. Many of our customers have DMLS parts machined to hit tighter tolerances or achieve certain finishes.
CNC Machining
CNC Machining
CNC Machining
CNC Machining
Key benefits: CNC machining offers high precision parts with a high-quality finish.
Materials: Aluminum, Brass, Titanium, Carbon Steel, Copper, Stainless Steel, plus others available
Best suited for projects that need:
  • Production-quality materials
  • Tight tolerances
  • Production at scale (up to 10,000 parts)
  • Custom finishes, including anodizing, passivating, plating, and powder coating
Tolerances: ±0.005″ – 0.001″, depending on customer specs
Lead Time:
  • Milled: within 9 business days
  • Turned: within 5 business days
DMLS
DMLS
DMLS
Key benefits: DMLS is capable of building complex geometries that otherwise wouldn’t be possible using traditional manufacturing. Additionally, metal sintered parts possess nearly the same strength and density as cast metal parts, but can be built in a fraction of the time.
Materials: Aluminum, 17-4 Stainless Steel, 316 Stainless Steel
  • Metal parts with complex geometries
  • Aftermarket/replacement parts for legacy systems
  • Low-volume parts and prototypes for functional testing
Max build volume:
  • Stainless Steel – 9″ x 6″ x 6″
  • Aluminum – 6″ x 6″ x 6″
Tolerances: ±0.005″ (can be improved through post-processing)
Lead Time:
  • Stainless Steel: within 5 business days
  • Aluminum: within 8 business days
Key benefits: Metal Binder Jetting is our least expensive 3D printing option for building custom metal parts. It also possesses high strength and abrasion-resistance properties.
Materials: Stainless Steel infiltrated with Bronze (60% 420 Stainless Steel, and 40% Bronze)
  • Low-cost, complex metal parts
  • Parts that are too large for the DMLS build platform
  • High abrasion resistance (e.g., thermal, chemical or mechanical stress)
Max build volume: 29″x 15″ x 14.25″
Tolerances: Parts can shrink during the binding process (approximately 1-2%)
Lead Time: within 13 business days
Sheet Metal
Sheet Metal
Sheet Metal
Sheet Metal
Key benefits: Sheet metal is capable of producing thin walled parts that are either not possible or not cost-effective to build via CNC milling.
Materials: Aluminum, Copper, Stainless Steel, Steel, Zinc
  • Thin metal walls
  • Low-cost device panels, brackets, boxes, cases, and chassis
  • Lightweight applications
Lead Time: within 12 business days
