Indexable Inserts
View as Grid List
Items 31-44 of 44
Page
per page
Set Descending Direction
  1. Kyocera LOMU 100412ERGM PR1510 Grade PVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Cast Iron
    $185.7 Save $60.27
    $125.43
  2. Kyocera LOMU 100412ERGM CA6535 Grade CVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Stainless Steel and Heat-resistant Alloy
    $176.9 Save $57.41
    $119.49
  3. Kyocera LOMU 100408ERGM PR1535 Grade PVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Heat-resistant Alloy and Stainless Steel
    $185.7 Save $60.27
    $125.43
  4. Kyocera LOMU 100408ERGM PR1525 Grade PVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Steel and Hard Material
    $185.7 Save $60.27
    $125.43
  5. Kyocera LOMU 100408ERGM PR1510 Grade PVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Cast Iron
    $185.7 Save $60.27
    $125.43
  6. Kyocera LOMU 100408ERGM CA6535 Grade CVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Stainless Steel and Heat-resistant Alloy
    $176.9 Save $57.41
    $119.49
  7. Kyocera LOMU 100404ERGM PR1535 Grade PVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Heat-resistant Alloy and Stainless Steel
    $185.7 Save $60.27
    $125.43
  8. Kyocera LOMU 100404ERGM PR1525 Grade PVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Steel and Hard Material
    $185.7 Save $60.27
    $125.43
  9. Kyocera LOMU 100404ERGM PR1510 Grade PVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Cast Iron
    $185.7 Save $60.27
    $125.43
  10. Kyocera LOMU 100404ERGM CA6535 Grade CVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Stainless Steel and Heat-resistant Alloy
    $176.9 Save $57.41
    $119.49
  11. Kyocera LOGU 030310ERGM PR1535 Grade PVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Heat-resistant Alloy and Stainless Steel
    $166.3 Save $53.97
    $112.33
  12. Kyocera LOGU 030310ERGM PR1525 Grade PVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Steel and Hard Material
    $166.3 Save $53.97
    $112.33
  13. Kyocera LOGU 030310ERGM PR1510 Grade PVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Cast Iron
    $166.3 Save $53.97
    $112.33
  14. Kyocera LOGU 030310ERGM CA6535 Grade CVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Stainless Steel and Heat-resistant Alloy
    $158.4 Save $51.47
    $106.93
View as Grid List
Items 31-44 of 44
Page
per page
