Indexable Inserts
View as Grid List
Items 16-30 of 30
Page
per page
Set Descending Direction
  1. Kyocera PNMU 1205ANERGH PR1210 Grade PVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Cast Iron and Heat-resistant Alloy
    $274.3 Save $89.06
    $185.24
  2. Kyocera PNMU 1205ANELGM PR1535 Grade PVD Carbide, Pentagon, Positive Rake Angle, Left-Hand Milling Insert for Medium-Roughing in Heat-resistant Alloy and Stainless Steel
    $274.3 Save $89.06
    $185.24
  3. Kyocera PNMU 1205ANELGM PR1510 Grade PVD Carbide, Pentagon, Positive Rake Angle, Left-Hand Milling Insert for Finishing-Roughing in Cast Iron
    $274.3 Save $89.06
    $185.24
  4. Kyocera PNEU 1205ANERW TN100M Grade Uncoated Cermet, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Medium in Steel
    $147.65 Save $47.94
    $99.71
  5. Kyocera PNEU 1205ANERW PR1535 Grade PVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Heat-resistant Alloy and Stainless Steel
    $156.15 Save $50.7
    $105.45
  6. Kyocera PNEU 1205ANERW PR1525 Grade PVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Steel and Hard Material
    $181.7 Save $59.04
    $122.66
  7. Kyocera PNEU 1205ANERW PR1510 Grade PVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Cast Iron
    $181.7 Save $59.04
    $122.66
  8. Kyocera PNEU 1205ANERW CA6535 Grade CVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Stainless Steel and Heat-resistant Alloy
    $148.75 Save $48.3
    $100.45
  9. Kyocera PNEU 1205ANERGL PR1535 Grade PVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Heat-resistant Alloy and Stainless Steel
    $312.3 Save $101.41
    $210.89
  10. Kyocera PNEU 1205ANERGL PR1525 Grade PVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Steel and Hard Material
    $312.3 Save $101.41
    $210.89
  11. Kyocera PNEU 1205ANERGL PR1510 Grade PVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Cast Iron
    $312.3 Save $101.41
    $210.89
  12. Kyocera PNEU 1205ANERGL PR1225 Grade PVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Steel and Stainless Steel
    $312.3 Save $101.41
    $210.89
  13. Kyocera PNEU 1205ANERGL PR1210 Grade PVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Cast Iron and Heat-resistant Alloy
    $312.3 Save $101.41
    $210.89
  14. Kyocera PNEU 1205ANELGL PR1510 Grade PVD Carbide, Pentagon, Positive Rake Angle, Left-Hand Milling Insert for Finishing-Roughing in Cast Iron
    $312.3 Save $101.41
    $210.89
  15. Kyocera PNEU 1205ANELGL CA6535 Grade CVD Carbide, Pentagon, Positive Rake Angle, Left-Hand Milling Insert for Medium-Roughing in Stainless Steel and Heat-resistant Alloy
    $297.5 Save $96.6
    $200.90
View as Grid List
Items 16-30 of 30
Page
per page
