Indexable Inserts
View as Grid List
Items 16-30 of 30
Page
per page
Set Descending Direction
  1. Kyocera LOMU 100408ERGM PR1535 Grade PVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Heat-resistant Alloy and Stainless Steel
    $185.7 Save $60.27
    $125.43
  2. Kyocera LOMU 100408ERGM PR1525 Grade PVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Steel and Hard Material
    $185.7 Save $60.27
    $125.43
  3. Kyocera LOMU 100408ERGM PR1510 Grade PVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Cast Iron
    $185.7 Save $60.27
    $125.43
  4. Kyocera LOMU 100408ERGM CA6535 Grade CVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Stainless Steel and Heat-resistant Alloy
    $176.9 Save $57.41
    $119.49
  5. Kyocera LOMU 100408ERGH PR1535 Grade PVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Heat-resistant Alloy and Stainless Steel
    $185.7 Save $60.27
    $125.43
  6. Kyocera LOMU 100408ERGH PR1525 Grade PVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Steel and Hard Material
    $185.7 Save $60.27
    $125.43
  7. Kyocera LOMU 100408ERGH PR1510 Grade PVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Cast Iron
    $185.7 Save $60.27
    $125.43
  8. Kyocera LOMU 100408ERGH CA6535 Grade CVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Stainless Steel and Heat-resistant Alloy
    $176.9 Save $57.41
    $119.49
  9. Kyocera LOMU 100404ERGM PR1535 Grade PVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Heat-resistant Alloy and Stainless Steel
    $185.7 Save $60.27
    $125.43
  10. Kyocera LOMU 100404ERGM PR1525 Grade PVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Steel and Hard Material
    $185.7 Save $60.27
    $125.43
  11. Kyocera LOMU 100404ERGM PR1510 Grade PVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Cast Iron
    $185.7 Save $60.27
    $125.43
  12. Kyocera LOMU 100404ERGM CA6535 Grade CVD Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Stainless Steel and Heat-resistant Alloy
    $176.9 Save $57.41
    $119.49
  13. Kyocera LOGT 100408FRAM PDL025 Grade DLC, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Medium in Non-ferrous Metal
    $321.3 Save $104.33
    $216.97
  14. Kyocera LOGT 100408FRAM GW25 Grade Uncoated Carbide, Rectangle, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Medium in Non-ferrous Metal and Heat-resistant Alloy
    $229.8 Save $74.67
    $155.13
  15. Kyocera LNEU 1240084 PR0725 Grade PVD Carbide, Rectangle, Negative Rake Angle, Neutral Milling Insert for Medium Speed in Steel and Stainless Steel
    $466.8 Save $151.68
    $315.12
View as Grid List
Items 16-30 of 30
Page
per page
