Indexable Inserts
View as Grid List
Items 31-45 of 321
per page
Set Descending Direction
  1. Kyocera PNMU 1205ANERGH PR1210 Grade PVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Cast Iron and Heat-resistant Alloy
    $274.3 Save $89.06
    $185.24
  2. Kyocera PNMU 1205ANELGM PR1535 Grade PVD Carbide, Pentagon, Positive Rake Angle, Left-Hand Milling Insert for Medium-Roughing in Heat-resistant Alloy and Stainless Steel
    $274.3 Save $89.06
    $185.24
  3. Kyocera PNMU 1205ANELGM PR1510 Grade PVD Carbide, Pentagon, Positive Rake Angle, Left-Hand Milling Insert for Finishing-Roughing in Cast Iron
    $274.3 Save $89.06
    $185.24
  4. Kyocera PNMG 1106XNENGM PR1525 Grade PVD Carbide, Pentagon, Positive Rake Angle, Neutral Milling Insert for Finishing-Roughing in Steel and Hard Material
    $225.4 Save $73.24
    $152.16
  5. Kyocera PNMG 1106XNENGM PR1510 Grade PVD Carbide, Pentagon, Positive Rake Angle, Neutral Milling Insert for Finishing-Roughing in Cast Iron
    $225.4 Save $73.24
    $152.16
  6. Kyocera PNMG 1106XNENGM CA420M Grade CVD Carbide, Pentagon, Positive Rake Angle, Neutral Milling Insert for Finishing-Medium in Cast Iron
    $214.7 Save $69.7
    $145.00
  7. Kyocera PNMG 1106XNENGH PR1510 Grade PVD Carbide, Pentagon, Positive Rake Angle, Neutral Milling Insert for Finishing-Roughing in Cast Iron
    $225.4 Save $73.24
    $152.16
  8. Kyocera PNMG 1106XNENGH CA420M Grade CVD Carbide, Pentagon, Positive Rake Angle, Neutral Milling Insert for Finishing-Medium in Cast Iron
    $214.7 Save $69.7
    $145.00
  9. Kyocera PNEU 1205ANERW TN100M Grade Uncoated Cermet, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Medium in Steel
    $147.65 Save $47.94
    $99.71
  10. Kyocera PNEU 1205ANERW PR1535 Grade PVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Heat-resistant Alloy and Stainless Steel
    $156.15 Save $50.7
    $105.45
  11. Kyocera PNEU 1205ANERW PR1525 Grade PVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Steel and Hard Material
    $181.7 Save $59.04
    $122.66
  12. Kyocera PNEU 1205ANERW PR1510 Grade PVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Cast Iron
    $181.7 Save $59.04
    $122.66
  13. Kyocera PNEU 1205ANERW CA6535 Grade CVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Stainless Steel and Heat-resistant Alloy
    $148.75 Save $48.3
    $100.45
  14. Kyocera PNEU 1205ANERGL PR1535 Grade PVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Heat-resistant Alloy and Stainless Steel
    $312.3 Save $101.41
    $210.89
  15. Kyocera PNEU 1205ANERGL PR1525 Grade PVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Steel and Hard Material
    $312.3 Save $101.41
    $210.89
View as Grid List
Items 31-45 of 321
per page
