Indexable Inserts
View as Grid List
Items 46-60 of 321
per page
Set Descending Direction
  1. Kyocera PNEU 1205ANERGL PR1510 Grade PVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Cast Iron
    $312.3 Save $101.41
    $210.89
  2. Kyocera PNEU 1205ANERGL PR1225 Grade PVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Steel and Stainless Steel
    $312.3 Save $101.41
    $210.89
  3. Kyocera PNEU 1205ANERGL PR1210 Grade PVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Cast Iron and Heat-resistant Alloy
    $312.3 Save $101.41
    $210.89
  4. Kyocera PNEU 1205ANELGL PR1510 Grade PVD Carbide, Pentagon, Positive Rake Angle, Left-Hand Milling Insert for Finishing-Roughing in Cast Iron
    $312.3 Save $101.41
    $210.89
  5. Kyocera PNEU 1205ANELGL CA6535 Grade CVD Carbide, Pentagon, Positive Rake Angle, Left-Hand Milling Insert for Medium-Roughing in Stainless Steel and Heat-resistant Alloy
    $297.5 Save $96.6
    $200.90
  6. Kyocera PNEG 1106XNERW PR1525 Grade PVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Steel and Hard Material
    $162.55 Save $52.78
    $109.77
  7. Kyocera PNEG 1106XNERW PR1510 Grade PVD Carbide, Pentagon, Positive Rake Angle, Right-Hand Milling Insert for Finishing-Roughing in Cast Iron
    $162.55 Save $52.78
    $109.77
  8. Kyocera PNEG 1106XNENGL PR1525 Grade PVD Carbide, Pentagon, Positive Rake Angle, Neutral Milling Insert for Finishing-Roughing in Steel and Hard Material
    $259.8 Save $84.42
    $175.38
  9. Kyocera PNEG 1106XNENGL CA420M Grade CVD Carbide, Pentagon, Positive Rake Angle, Neutral Milling Insert for Finishing-Medium in Cast Iron
    $247.4 Save $80.39
    $167.01
  10. Kyocera PNEA 1106XNTNT01020 KS6050 Grade Ceramic, Pentagon, Positive Rake Angle, Neutral Milling Insert for High Speed Finishing-Medium in Cast Iron
    $225.1 Save $73.07
    $152.03
  11. Kyocera PNEA 1106XNTNT01020 CS7050 Grade CVD Ceramic, Pentagon, Positive Rake Angle, Neutral Milling Insert for High Speed Finishing in Cast Iron
    $258.8 Save $84.09
    $174.71
  12. Kyocera OFMT 070408ENGT PR1225 Grade PVD Carbide, Octagon, Positive Rake Angle, Neutral Milling Insert for Medium-Roughing in Steel and Stainless Steel
    $226.1 Save $73.4
    $152.70
  13. Kyocera OFMT 070405ENSH PR1225 Grade PVD Carbide, Octagon, Positive Rake Angle, Neutral Milling Insert for Medium-Roughing in Steel and Stainless Steel
    $226.1 Save $73.4
    $152.70
  14. Kyocera OFMT 070405ENSH PR1210 Grade PVD Carbide, Octagon, Positive Rake Angle, Neutral Milling Insert for Finishing-Roughing in Cast Iron and Heat-resistant Alloy
    $226.1 Save $73.4
    $152.70
  15. Kyocera OFMT 050405ERSH PR830 Grade PVD Carbide, Octagon, Positive Rake Angle, Right-Hand Milling Insert for Medium-Roughing in Steel and Stainless Steel
    $182.4 Save $59.27
    $123.13
View as Grid List
Items 46-60 of 321
per page
