Xometry Supplies
Xometry Supplies logo
Industrial supplies. Priced competitively. Delivered quickly.
When it comes to procurement, we’re the total package
Procurement should operate on your time, not the other way around. Our goal is overall efficiency, from cost to shipping. Everything—from our location to our machines—is aimed at shrinking the time between when you accept a job and when you get to start machining.
Shop now
Material processing a cut above the rest
Get your materials fast. Receive same-day shipping on standard cuts, select custom cuts, and all of our tooling products on orders received before 12:00 pm EST. This commitment goes for any materials or tooling we offer.
We believe in the power of hard work and good tech. We invested in equipment capable of the speed and precision necessary to get your orders processed and shipped in record time. We are always willing to go the extra mile to meet your needs, with same day processing on standard cuts, select custom cuts, and all tooling products.
Flow Mach 500 Waterjet machine in the Xometry Supplies facility
Xometry Supplies utilizes the Mach 500 Series of Flow Waterjets to bring you precise and reliable cuts. With this machine, our team is able to provide standard and custom cuts—all with industry-leading processing times.
KASTOwin A 3.3 machine in the Xometry Supplies facility
KASTOwin A 3.3
Designed for mass production sawing of solid material with optimum efficiency in mind, the KASTOwin A 3.3 allows our team of expert operators to process your materials quickly and accurately.
Custom cuts—handled with care
Get your aluminum cut exactly to your specifications without being charged an arm and a leg. Choose width, length, custom blanking etc. on any sized order. Plus, if you order by 12 ET, we’ll have your order out the door and on it’s way to you the next day. We promise to only cut the corners you want us to.
We deliver on faster shipping
Xometry Supplies is located in Lexington, KY, right in the heart of manufacturing country (and bourbon country, if we’re honest). Our facility is strategically placed to get you your industrial supplies faster than other suppliers, no matter where you’re located.
Estimated Delivery Times
Once your order is placed online, it is transmitted to the warehouse for cutting and processing. In most cases, orders received before 12:00pm ET will be processed and shipped from our warehouse the same day. Orders that may require additional processing time contain any of the following:
  • Material over 3 inches thick or plate/sheet over 24 inches long
  • Over 25 pieces
  • Special order materials
In the rare instance where we require more than 24-hours to process and ship your order, we will contact you to let you know there is a delay.
Bring efficiency to your door.
Shop Xometry Supplies
