CapabilitiesCustom Online CNC Machining ServicesCustom CNC Milling Services
CNC milled prototypes and production parts in days | AS9100D | ISO 9001:2015 | ISO 13485 | IATF 16949:2016 | ITAR Registered | Free standard shipping on all US orders
Materials
Applications and Benefits
Tolerances
About CNC Milling
Download Guide
High Quality Rapid CNC Milling Service
Xometry integrates seamlessly with over 10,000 qualified manufacturing partners, including US-based ITAR qualified and AS9100D registered CNC milling facilities. That massive network means that whatever your part, we have a shop and a machine that can make it. We support 3-axis, 4-axis, 5-axis milling, and right angle milling capabilities to help you rapidly create designs from simple straight lines to complex geometric shapes. Xometry offers instant pricing, on-demand lead times, and design-for-manufacturability feedback on materials and manufacturing processes for your custom CNC milled parts, no matter your industry. Get your instant quote today.
    Custom CNC Machining Materials
    Materials Available at Xometry
    AluminumBronze/BrassCopperPlasticsSteel / Titanium / Zinc
    Aluminum 5052
    Bronze/Brass
    Brass C360
    Copper
    EPT Copper C110
    Plastics
    ABS
    Alloy Steel 4130, 4140
    Aluminum 7075 & 7075-T6
    Bronze/Brass
    Brass 260
    Copper
    Copper 101
    Plastics
    Acetal [Delrin]
    ASTM A36
    Aluminum 6063-T5
    Bronze/Brass
    C932 M07 Bearing Bronze
    Copper
    Plastics
    Acrylic
    Stainless Steel 15-5, 17-4, 18-8, 303
    Aluminum 7050-T7451
    Bronze/Brass
    Copper
    Plastics
    G-10 Garolite
    Stainless Steel 303, 304, 316/316L
    Aluminum MIC-6
    Bronze/Brass
    Copper
    Plastics
    Nylon 6/6
    Stainless Steel 416, 420
    Aluminum 6061-T6
    Bronze/Brass
    Copper
    Plastics
    PEEK
    Steel, Low Carbon
    Aluminum 2024-T3
    Bronze/Brass
    Copper
    Plastics
    Polycarbonate
    Steel A36
    Bronze/Brass
    Copper
    Plastics
    PTFE [Teflon]
    Titanium Grade 2, Titanium 6Al-4V, Zinc Sheet Alloy 500
    Bronze/Brass
    Copper
    Plastics
    Polypropylene
    Bronze/Brass
    Copper
    Plastics
    Ultra-High Molecular Weight Polyethylene
    Additional alloys and tempers are available upon request. We can source to your project specifications. If you do not see your alloy or material listed on our platform, please select "Other" and write in that specific material.
    Custom Sourced Materials
    A variety of custom CNC milled parts, including metal and plastic, options are available for an instant online quote. If you do not see the material stock you are looking for, please choose "Other" under the material drop-down on your quote page and submit for an expert engineering review once you have specified features, tolerances, inspection needs, and quantities required.
    Available Finishes
    As-Milled
    Bead Blast
    The part surface is media blasted, typically using glass bead, to produce a smooth, matte appearance.
    Type II creates a corrosion-resistant finish. Parts can be anodized in different colors—clear, black, red, and gold are most common—and is usually associated with aluminum. Type III is thicker and creates a wear-resistant layer in addition to the corrosion resistance seen with Type II.
    Powder Coat
    Custom
    Ready to get started on your CNC milling quote?
    Applications of CNC Milling
    Rapid Tooling
    Because CNC can be applied to virtually any material, it is perfect for rapid tooling, i.e., creating fixtures or molds.
    The range of materials available, low CNC machining costs per unit, and speed of production makes CNC a great option for prototyping.
    End-Use Production
    High-quality finish, vast material options and precise tolerances have made CNC a favorable technology for end-use parts.
    Advantages of CNC Milling
    CNC machined parts
    Rapid Turnaround
    CNC machined parts
    Using the latest CNC machining capabilities, Xometry produces highly accurate, quick turn parts in as fast as 1 day. We also instantly quote CNC machined parts, cutting days off of your RFQ process.
    High Precision Tolerances
    CNC machining
    Offers high-precision tolerances, including sub +/- 0.001" tolerances. We are the experts in making parts that are truly custom and ready to use.
    Scalability
    machined parts stacked up
    CNC machining processes are perfect for prototyping and production CNC parts. Xometry's massive scale can help you scale up from testing phase to production runs of 100,000 parts of more.
    Material Selection
    raw aluminum
    Choose from over 50 metal and plastic materials. CNC Machines offer a wide variety of certified materials.
    CNC Milling Tolerances & Standards
    DescriptionGeneral Tolerance or Standard
    Description
    Maximum Part Size
    Milled parts up to 80” x 48” x 24” (2,032 x 1,219 x 610 mm).
    Description
    Distance Dimensions
    For features of size (Length, width, height, diameter) and location (position, concentricity, symmetry) +/- 0.005”.
    Description
    Orientation and Form Dimensions
    0-12" +/- 0.005", Angularity 1/2 degree. For 24" and beyond please consult Xometry's Manufacturing Standards.
    Description
    Xometry can manufacture and inspect to tight tolerances, including sub +/- 0.001" tolerances, per your drawing specifications and GD&T callouts.
    Description
    Minimum Feature Size
    0.020” (0.50 mm). This may vary depending on part geometry and chosen material.
    Description
    Threads and Tapped Holes
    Xometry can accommodate any standard thread size. We can also machine custom threads; these will require a manual quote review.
    Description
    Surface Finish
    The standard finish is as-machined: 125 Ra or better. Additional finishing options can be specified when getting a quote.
    Description
    Edge Condition
    Sharp edges will be broken and deburred by default. Critical edges that must be left sharp should be noted and specified on a print.
    Please check out Xometry's Manufacturing Standards for more information on tolerances per process. Unless we have agreed to other tolerances in your Quote, we will work to achieve and hold the tolerances noted.
    Overview: What is CNC Milling?
    The Basics Of CNC Mills
    CNC mills are automated cutting machines using a rotating spindle-head to cut away unwanted material. CNC milling machines come in a variety of sizes and different axis configurations. This manufacturing process is mainly utilized to cut harder metals but can work with workpiece materials ranging from plastic and aluminum to stainless steel and titanium.
    How CNC Milling Works
    CNC mills excel at profile cutting harder materials. Like all CNC machines, a CNC mill is controlled with G-Code created through CAM software. The Gg-Code instructs the machine where to move the tool head, how fast to spin the tool, how deep to cut, how to move the workpiece, and other factors relating to speed, feed rate, and coordination. The G-Code complexity depends on how many axes the milling machine has.
    Mills can still be used for profile cutting of softer materials, but are not as cost-effective for that use as CNC routers. The main difference between these machines is that with a CNC router the workpiece remains stationary while the router cutting head is directed around the piece, while a CNC mill may move both tool head and workpiece. CNC mills are mainly used in industrial manufacturing, while CNC routing is more common for lower output manufacturing like woodworking.
    CNC machined parts
    Types of CNC Mills
    3-Axis
    The most widely used type of CNC milling machine. The full use of the X, Y, and Z directions makes a 3 Axis CNC mill useful for a wide variety of work.
    4-Axis
    This type of router allows the machine to rotate on a vertical axis, moving the workpiece to introduce more continuous machining.
    5-Axis
    These machines have three traditional axes as well as two additional rotary axes. A 5-axis CNC router is, therefore, able to machine 5 sides of a workpiece at in one machine without having to remove the workpiece and reset. The workpiece rotates, and the spindle head is able to also move around the piece. These are larger and more expensive.
    Other Benefits Of CNC Mill Machining Processes
    CNC milling machines are built for precise manufacturing and repeatability which makes them perfect for rapid prototyping and low-to-high volume production runs. CNC mills can also work with a variety of materials from basic aluminum and plastics to more exotic ones like titanium — making them the ideal machine for almost any job. Learn more about the difference between a mill and a lathe and when milling is the best process to use.
      CNC Milling
      Instant Quote Demo
      See how simple it is to get an instant quote for CNC machining using the Xometry Instant Quoting Engine®.
      Why Choose Xometry for Custom Milling?
      We are ISO 9001:2015, ISO 13485, IATF 16949:2016, and AS9100D certified. Only the top CNC machine shops that apply to become Suppliers make it through our qualification process.
      Download the CNC machining design guide
      Quick Links
      • Home
      • Contact Us
      • Help Center
      • About Us
      • Careers
      • Press
      • Investors
      • Xometry Go Green
