CapabilitiesSheet Metal Fabrication ServicesWest Virginia
Sheet Metal Fabrication Services for West Virginia
High Quality West Virginia Sheet Metal Fabrication | Fast lead times and free standard shipping on all US orders.
Rapid Tooling
Fast parts and fast shipping
Part Production
End-Use Production
Your West Virginia Sheet Metal Fabrication Service: Prototypes and Production Cuts
Aluminum 6061
Aluminum 5052
Copper
Copper 101
Copper C110
Copper 260 (Brass)
Bronze
Bronze 220
Bronze 510
Stainless Steel
Stainless steel 301
Stainless steel 304
Stainless steel 316/316L
Steel
Steel 1018 (Low Carbon)
Standard
Bead Blast
Anodize (Type II Or Type III)
Powder Coat
Electroless Nickel Plating
Gold Plating
Silver Plating
Standard Sheet Thicknesses
Sheet Metal Fabrication Services Near West Virginia
Morgantown
West Virginia
