CapabilitiesWire EDM Machining ServiceNew Hampshire
Wire EDM Services for New Hampshire
High Quality Wire EDM Machining services near New Hampshire | Our skilled engineering team guides you through every step of the machining process.
Wire EDM Machining services. Image Credit: Shutterstock.com/Aumm graphixphoto
Your New Hampshire Custom Wire EDM Machining
Use the 3D viewer above to preview Xometry's part rendering features.
Other New Hampshire CNC Machining Services From Xometry
CNC milling
Custom CNC Milling Services
CNC milled prototypes and production parts in days | AS9100D | ISO 9001:2015 | ISO 13485 | IATF 16949:2016 | ITAR Registered | Free standard shipping on all US orders
CNC Turning
CNC Turning Service
CNC Turning Service
Wire EDM Machining Finishes Available near New Hampshire
Standard Finish (as-milled)
Bead Blast
Tumbled
Type II  (MIL-A-8625, Type II) creates a corrosion-resistant finish. Parts can be anodized in different colors—clear, black, red, and gold are most common—and is usually associated with aluminum. Type III (MIL-A-8625, Type III, Class 1/2 "hardcoat") is thicker and creates a wear-resistant layer in addition to the corrosion resistance seen with Type II.
Titanium Anodize
PTFE Impregnated Hard Anodize
Chem Film
Passivation
Powder Coat
Electropolishing
Electroless Nickel Plating
Silver Plating
Silver offers high solderability and electrical conductivity but is susceptible to tarnish. Conforms to AMS QQ-S-365D. Thickness is about 0.00002” - 0.0003.”
Gold Plating
Zinc Plating
capacity
quote engine
quality assurance
Wire EDM Machining Services near New Hampshire
Manchester
New Hampshire
New Hampshire Wire EDM Machining Service
Ready to get started on your wire EDM machining project?
