Xometry Platinum Plating Services
Get Quotes in Two Hours and Parts Finished in as Fast as 2 Days. GE-F70J-WB2 Available.
ITAR Registered
ISO 9001
ISO 13485
AS9100D Certified
Platinum Plating Overview
Platinum, one of the transition metals, is an excellent choice for electroplating. It is resistant to oxidation and corrosion and is both conductive and chemically stable. Platinum is a silver-white metal that was once known as "white gold." It is highly resistant to tarnishing and corrosion and is quite soft and malleable. This makes it ductile and easy to shape or stretch into wire. It is also un-reactive, which means it does not oxidize and is not affected by most common acids. Specifications: GE-F70J-WB2.
  • Symbol: Pt
  • Relative atomic mass: 195.1
  • Atomic number: 78
  • Melting point: 3,215.1°F
  • Boiling point: 6,917°F
Finishing Services
Quality
Competitive Pricing
Access a deep network of world-class platinum platers, helping you find the suppliers you need at competitive prices.
Fast Quoting
Massive Network Capacity
Streamlined Communication
Anodizing
  • Type II Anodize
  • Type III Hard coat
  • Type III w/ PTFE
Metal Plating
  • Copper Plating
  • Electroless Nickel
  • Electrolytic Nickel
  • Nickel Plating
  • Nickel Sulfamate
  • Nickel Watts
  • Tin
  • Zinc
Adhesives and Coatings
  • Black Oxide
  • Dry Film Lubricants
  • Powder Coat
  • Wet Paint
Conversion and Pretreatments
  • Chem Film
  • Chromate Conversion Coating
  • Heat Treat
  • Passivation
  • Pickle and Oil
Surface Treatments
  • Bead Blasting
  • Electropolishing
  • Etching
Part Marking
  • Ink Stamping
  • Laser Marking
  • Silk Screening
Heat Treatments
  • Annealing
  • Carburizing
  • Cryogenic Treatment
  • Flame Hardening
  • Hydrogen Embrittlement Relief
  • Induction Hardening
  • Nitriding
  • Stress Relieving
Certifications
  • AS 9100D
  • ISO 13485
  • ISO 9001:2015
  • ITAR
  • NADCAP
  • RoHS
Finishing Services at Xometry
number 1
Find Your Finisher
Find verified finishers using our robust search tools with over 50 different criteria including location, finishing capabilities, and certifications.
number 2
Create and Submit Your Request
Send a breakdown of your project's requirements to the finisher of your choice complete with details on your finishing needs and any necessary files.
number 3
Manage Your Order
Manage your order from start to finish in one place, including fast and easy transactions with your credit card or apply for net-30 terms with no hassle or risk.
finished parts
All the Finishers You Need in One Place
Quick Links
  • Home
  • Contact Us
  • Help Center
  • About Us
  • Careers
  • Press
  • Investors
  • Xometry Go Green
