Resources3D Printing DesignFreeCAD vs. Autodesk Fusion® — Software Comparison
Blue 3D printed sneaker. Image Credit: Shutterstock.com/asharkyu
A comparison of these two 3D printing softwares and their different features.
FreeCAD is a completely free and open-source CAD (Computer Aided Design) package that is available to use for commercial purposes. FreeCAD has a powerful 3D modeling workspace that can compete with many commercial CAD packages. However, its learning curve is steep and there is no brand-name company standing behind it to provide technical support. Architectural, CAM, and robotics simulation module add-ins further extend FreeCAD’s functionality. FreeCAD is continuously being improved and further developed, which comes at the cost of some application stability.
Autodesk Fusion® is a cloud-connected engineering tool with an excellent set of features that assist engineers throughout the entire product development lifecycle. It has a robust collaborative function that allows teams to work on projects without having to be in the same location. Fusion is easier to learn compared to FreeCAD, has a modern user interface, and has a large, active user community. Multiple subscription models are also available at different price points.
This article will explore the differences between FreeCAD and Fusion, highlighting their optimal use cases and defining minimum system requirements. The two software packages will be compared based on a range of parameters such as user experience, customer support, application stability, user community expertise, and price.
What is FreeCAD?
FreeCAD is an open-source CAD package used for creating parametric 3D models. “Parametric” means that model dimensions can be changed without having to redraw the entire model each time. As the name suggests, FreeCAD is completely free to use. FreeCAD has a CAE (Computer Aided Engineering) component that can be used to simulate how a part reacts to a load. It also has an experimental CFD (Computational Fluid Dynamics) module as well as some limited CAM (Computer Aided Manufacturing) functionality for preparing parts for CNC machining. For more information, see our Guide to 3D Printing and List of 3D Printing Software.
What is Fusion?
Fusion (developed by Autodesk®) is a powerful cloud-connected engineering tool designed for collaborative product design. Like FreeCAD, Fusion is also a parametric-style 3D modeling package. It has a wide range of features that include standard 3D modeling, and a very capable CAE module that includes features like: FEA (Finite Element Analysis), mold analysis, motion analysis, and generative design. Fusion also has an excellent CAM module that is regularly updated. This software runs more of its processor-intensive functions, such as simulation and rendering, in the cloud. This results in a significantly faster turnaround time to generate an output when making use of these computationally intensive functions.
FreeCAD vs. Fusion — Use Cases and Applications
FreeCAD has many of the modeling features found in premium CAD packages. It is primarily used for mechanical engineering and product design tasks and is used extensively for designing mechanical components and assemblies. FreeCAD can assist engineers with all of the tasks required throughout a product's complete lifecycle, from initial modeling, through simulation using an FEA (Finite Element Analysis) solver, to manufacturing simulation and control using its powerful CAM package.
FreeCAD also has a powerful architectural modeling toolkit that makes it relatively easy to create architectural plans and can be used to create photorealistic renderings for marketing purposes.
FreeCAD vs. Fusion — System Requirements
FreeCAD and Fusion have a smaller footprint when compared to more feature-rich CAD packages like Solidworks® and Autodesk Inventor®. However, FreeCAD can be run on almost any hardware, provided the GPU supports OpenGL (a programming interface used in rendering 2D and 3D vector graphics). Fusion cannot be run on lower-end systems. Table 1 indicates the recommended system requirements for Fusion and FreeCAD:
Table 1: FreeCAD and Fusion System Requirements
FreeCAD 2022Fusion 2022
FreeCAD 2022
Operating System
Fusion 2022
Apple® Microsoft® Ubuntu®
Apple® or Microsoft® Recommended
FreeCAD 2022
Processor
Fusion 2022
64 Bit Processor (Does not support parallel processing)
Processors with Rosetta 2 (Apple)
64-Bit, 4-Core 1.7+ GHz (Microsoft)
FreeCAD 2022
Memory (RAM)
Fusion 2022
> 4 GB
> 8 GB
FreeCAD 2022
Display Resolution
Fusion 2022
1920 x 1080 or Greater
FreeCAD 2022
Display Card
Fusion 2022
Compatible with OpenGL
  • Dedicated GPU with > 1GB VRAM
  • Integrated graphics with > 6 GB RAM
FreeCAD 2022
Disk Space
Fusion 2022
> 2GB
> 3 GB
What is the Operating System of FreeCAD and Fusion?
FreeCAD can be run on macOS, Ubuntu, and Microsoft Windows versions back to Windows 7. Fusion is only supported on macOS 11 & 12 and any Microsoft Windows version except Microsoft Windows 7.
What Are the Minimum Memory Requirements for FreeCAD and Fusion?
Fusion requires a minimum of 4 GB of RAM. However, having at least 8 GB available for larger and more complex models will result in a far smoother user experience. FreeCAD has an extremely small footprint and can easily run on 4 GB of RAM. However, as models become larger and more complex, upgrading to 8 GB would result in a better experience.
What File Formats do FreeCAD and Fusion Support?
FreeCAD is open-source software. As such, it works with most open CAD formats but does not support a number of proprietary formats. Fusion, on the other hand, can import a wide range of proprietary file formats. For more information, see our guide on 3D Printing Files.
Table 2 lists the major file formats compatible with FreeCAD and Fusion:
Table 2: Supported CAD Formats for Fusion and FreeCAD
FreeCADFusion
FreeCAD
Native File Formats
Fusion
FCS
F3D
FreeCAD
External File Formats
Fusion
DWG, DXF
OBJ
IGES, IGS
STEP
3MF
AMP
GLB, GLTF
OCA
X3D
STL
SCAD
3DS
DWG, DXF
OBJ
IGES, IGS
STEP
123DX
3DM
ASM
CATPART, CATPRODUCT
IAM, IPT
NEU
FreeCAD vs. Fusion — User Experience
Fusion has a modern and easy-to-understand user interface. However, this interface changes from one software version to the next, since it is still under active development. Such changes in the user interface can be confusing at times, as some buttons might be in different locations after an update. FreeCAD, on the other hand, has a dated user interface that is not as polished and streamlined as that of Fusion. However, FreeCAD's user interface still gets the job done.
Learning Curves for FreeCAD and Fusion
The learning curve for FreeCAD is much steeper than that for Fusion. Fusion has built-in tutorials that make learning the software much easier. FreeCAD is not as intuitive, and some tools are difficult to locate.
Is FreeCAD Easier to Learn And Use Than Fusion?
No, FreeCAD is not easier to learn and use than Fusion. Fusion provides a polished and intuitive user experience with built-in tutorials, as well as thousands of freely available online tutorials. FreeCAD, on the other hand, is not as popular and has a smaller online presence, making it more difficult to find quality tutorials. FreeCAD does, however, have an extensive Wiki community.
FreeCAD vs. Fusion — Application Stability
Both FreeCAD and Fusion are still in active development. This results in numerous bugs being present in the software. Fusion is a cloud-connected software, so crashes very rarely result in lost data.
FreeCAD is also under development, and can also be unstable. However, unlike Fusion, FreeCAD is not cloud-connected and offers no technical support if a major failure occurs.
FreeCAD vs. Fusion — Customer Support
FreeCAD is not a commercial product and therefore does not have any formal customer support. However, FreeCAD has an active forum where users can ask questions and get answers from other, more experienced users. Fusion is a commercial product and does have formal customer support, in addition to a very active forum where users and Autodesk® employees answer questions.
FreeCAD vs. Fusion — Community
Both FreeCAD and Fusion have active user communities in the form of official forums and social media pages. However, Fusion has a much larger online presence, with thousands of video tutorials.
FreeCAD vs. Fusion — Price
FreeCAD is completely free to use and even to modify. Its source code is available under an LGPL-2.0 License which means it is free even for commercial use.
The Fusion price structure is based on a subscription model. It can be purchased on a monthly, yearly, or 3-year price package. A monthly plan costs $70, an annual plan costs $545, and a 3-year plan costs $1,555. However, the pricing can get even more complicated, as Fusion makes use of a token system to access some of its more advanced CAE and CAM features. For example, some types of FEA simulations will require more tokens to run and therefore cost more money. Fusion does have free versions, but these have relatively limited capabilities when compared to the paid versions.
Alternatives to FreeCAD and Fusion
In terms of purely free software, there are not many fully featured options to replace FreeCAD. However, the closest would be SketchUp, which is a cloud-based CAD platform. SketchUp has a basic free version, but a paid subscription is required to be able to use its  more advanced features.
A direct competitor for Fusion is OnShape. However, OnShape runs completely on the cloud through a web browser. OnShape is significantly more costly than Fusion and does not have flexible monthly subscription packages.
When comparing FreeCAD vs. Fusion it is important to understand that while FreeCAD is an impressive open-source project, it cannot compete with Fusion in terms of features, useability, and support.
This article presented FreeCAD and Fusion, explained what they are, and discussed the different features and uses of each software. To learn more about 3D printing software, contact a Xometry representative.
  1. Fusion®, Autodesk Inventor®, and Autodesk® are trademarks of Autodesk, Inc.
  2. Windows® is a trademark of Microsoft Corporation.
  3. macOS is a trademark of Apple Inc.
  4. Ubuntu is a trademark of Canonical Ltd.
