ResourcesBlogWhat is GD&T and How is it Used?
chart
GD&T or Geometric Dimensioning and Tolerancing is an important piece of communication between engineers and manufacturers. It is the system used to communicate acceptable levels of deviation from a part’s design dimensions. GD&T is, however, a complex topic that is often misunderstood. This article aims to remove some of the confusion and define some basic GD&T principles.
 4 min read
May 15, 2024
 20 min read
Why is GD&T Important?
Engineers must supply GD&T values along with the design itself. Without that tolerancing information, manufacturers are likely to default to their own internal standards. This may seem fine at first, but if the part needs to interface with other parts made under different tolerances, there is a good chance they will not fit or align properly.
In terms of quality control, a part’s acceptance criteria must be clearly defined. If it is not defined, the manufacturer cannot be held responsible for parts that fail to meet tolerance requirements.
What is Tolerance?
Tolerance is simply the deviation from an ideal value that is considered acceptable and which will still allow the completed product to function. This needs to be defined because even the most advanced manufacturing methods cannot consistently achieve an exact value. Many variables caused by tool wear, temperature, fixturing, and operator inconsistencies can affect the production in ways that can’t always be avoided.
What is a Datum?
Before all the different GD&T symbols are defined, it is important to understand the concept of a datum. A datum is a theoretically ideal line, surface, or feature that is used as a reference from which to define the tolerance limit of another feature. For example, in order to specify whether two planes are parallel, one of those planes needs to be assumed as being perfectly aligned. That acts as a reference from which to measure the other plane’s deviation. Once specified, that acceptable deviation becomes the tolerance for both planes as a system.
GD&T Symbol Classification
When adding GD&T to a drawing, it is important to use standardized symbols and methodologies. Most CAD packages will already have these symbols built-in. The type of tolerance, datum feature, and tolerance value are all specified in a feature control frame like the one below.
Image: Feature Control Frame
Explanations for each of the different types of geometric tolerances are given in the sections below.
Form tolerance
A form tolerance defines deviations from the ideal shape of a feature. This type of tolerance does not need a datum.
TypeSymbolDescription
Type
Straightness
Symbol
Straightness
Description
Typically used to define the permissible deviation on long straight features like the axis of a shaft.
Type
Flatness
Symbol
flatness
Description
Defines acceptable deviation between the high and low points on a flat surface.
Type
Roundness
Symbol
roundness
Description
Defines acceptable deviation from a perfect circle on parts with circular cross-sections.
Type
Cylindricity
Symbol
cylindricity
Description
Defines both the straightness and roundness tolerances of a cylindrical part.
Turn Your File Into Parts
Orientation tolerance
An orientation tolerance refers to the shape of a feature based on a datum. All orientation tolerances require a datum.
Type
Angularity
Symbol
angularity
Description
Defines the acceptable deviation of an angle with the datum being a straight line or plane.
Type
Parallelism
Symbol
parallelism
Description
Defines the permissible parallel deviation between a line or plane and a datum line or plane.
Type
Perpendicularity
Symbol
perpendicularity
Description
Defines the acceptable deviation of a line or plane that is designed as perpendicular to the datum line or plane.
FREE CNC Machining Tolerances E-Book
Location Tolerance
A location tolerance defines the position of a feature with relation to a datum. It is typically used to define the positioning of holes. All location tolerances require a datum.
Type
Concentricity
Symbol
concentricity
Description
Defines the acceptable deviation between two cylinders that are designed to be concentric about the same central axis. The datum is the center point.
Type
Coaxiality
Symbol
coaxiality
Description
Defines the permissible coaxial deviation of the central axis of two cylinders. The two axes may form an angle with one another as long as they stay within a theoretical cylinder with a radius equal to the defined tolerance.
Type
Symmetry
Symbol
symmetry
Description
Defines the acceptable deviation between two planes’ symmetry. This tolerance indicates the deviation of one plane from a theoretical center plane between the features.
Run-Out tolerance
A run-out tolerance defines the permissible deviation when a feature is rotated around its centerline. All run-out tolerances require a datum.
Type
Circular Run-Out
Symbol
circular run-out
Description
Defines the acceptable deviation of a cylindrical part at any point on its circumference.
Type
Total Run-Out
Symbol
total run-out
Description
Defines the acceptable deviation of a cylindrical part at any point on its circumference and along its axis.
Profile tolerance
A profile tolerance defines acceptable deviations of a profile line or plane. Profile tolerances do not require a datum.
Type
Line Profile
Symbol
line profile
Description
Defines the acceptable deviation of a curve as viewed from a cross-sectional perspective.
Type
Surface Profile
Symbol
surface profile
Description
Defines the acceptable deviation of a surface along its entire surface area, i.e. deviations from the ideal shape of the surface are controlled.
Measuring Tolerance
Various tools and methods are used to measure the above-mentioned tolerances. A dimensional tolerance (i.e. a length or diameter) can often be measured using micrometers or vernier calipers. However, with complex profiles or planar tolerances, it is more efficient to use a CMM (Coordinate measuring machine) to measure multiple points all over with the feature.
What to Look Out for With GD&T
Caution must be exercised when applying GD&T to drawings. One of the biggest mistakes is over-defining the drawing. An over-defined part is just as bad as an under-defined one when it comes to GD&T. Not every single feature needs to be manufactured to exacting tolerances, and as such only critical dimensions and features need to have their tolerances defined and controlled. Over-tolerancing a part will significantly increase its cost because the manufacturer must spend extra time and care to achieve such precision. In addition to this, parts with unrealistic tolerances are more likely to be rejected for failing tolerance checks. Rejections based on non-critical tolerance deviations are not only wasteful but also costly.
CNC machined parts
CNC machined parts
CNC machined parts
CNC machined parts
When Should GD&T Be Used?
GD&T makes things easier for both the designer and the manufacturer as it clearly defines dimensional requirements. This leaves no room for incorrect interpretations. However, care must be taken when defining tolerances as these values cannot just be arbitrarily chosen. If unsure what tolerances are realistic, a discussion with the manufacturer can usually clear things up. This can prevent costs from spiraling due to over-specified tolerances and unnecessarily complex features. To learn more about how GD&T can ensure that your end product exactly meets your requirements, contact a Xometry expert.
