ResourcesCastingCasting: Definition, Importance, Types, and How It Works
Sand casting mold. Image Credit: Shutterstock.com/Funtay
 11 min read
Casting is a fundamental manufacturing process in which molten metal is poured into a pre-designed cavity, known as a mold, to produce a solid object with the desired shape and structure. The process is widely used across various industries, such as: automotive, aerospace, and construction, due to its versatility and cost-effectiveness. Casting plays a crucial role in producing complex components with intricate details and precise dimensions.
Die casting, investment casting, sand casting, and other casting techniques are among the options available. Each has its benefits and is appropriate for a variety of applications. For engineers and manufacturers to ensure effective production and high-quality final products, it is crucial to understand how casting works and the various casting methods. This article will discuss casting, its significance, the main varieties, and methods of operation.
What Is Casting?
Casting is a manufacturing process in which molten material, like metal, is poured into a mold and allowed to harden. Once solidified, the mold is broken or ejected to retrieve the casting. This method enables the production of intricate and complex components with specific properties.
How Does Casting Differ From Injection Molding?
Casting and injection molding are two distinct manufacturing processes. Injection molding involves injecting molten material into a mold under high pressure to create a solid object. In contrast, casting commonly utilizes the force of gravity to pour the molten material into the mold cavity. These processes differ in their mechanisms and applications, providing unique solutions for various manufacturing needs. For more information, see our guide on Injected Plastics.
What Is the Importance of Casting in Manufacturing?
The importance of casting in manufacturing is that it allows for the production of complex and intricate metal components cost-effectively. Casting reduces the number of individual parts required, as multiple pieces can be cast as a single unit. This simplifies assembly processes, streamlines inventory management, and reduces overall costs. By eliminating the need for extensive welding or joining, casting enhances efficiency and productivity in manufacturing operations.
What Are the Different Types of Casting?
Here are five different types of casting:
  1. Sand Casting: This process involves using silica-based materials, such as sand, to create molds. It is commonly used for manufacturing large components and is suitable for casting both ferrous and non-ferrous materials.
  2. Investment Casting: Also known as lost wax casting, this method uses a wax pattern that is coated with refractory material to create a mold. It is known for its high degree of accuracy, ability to create complex shapes, and good surface finish.
  3. Plaster Casting: Plaster casting utilizes a mixture of water, strengthening compound, and gypsum instead of sand. It is capable of casting complex shapes with thin walls and offers a smooth surface finish. However, it is typically more expensive and limited to casting aluminum and copper-based alloys.
  4. Die Casting: This process involves injecting molten metal under high pressure into a reusable mold. Die casting is known for its close size and shape tolerances, high dimensional consistency, and reduced need for post-casting machining. It is commonly used for non-ferrous metals and alloys.
  5. Centrifugal Casting: In centrifugal casting, molten metal is introduced into a spinning mold, producing cylindrical parts with minimal voids. It is often used for casting long, cylindrical components and can be done using water-cooled molds or pressure casting for asymmetric parts.
How Does Casting in Manufacturing Work?
Casting in manufacturing involves the process of pouring molten material into a mold to create the desired shape. The molten material solidifies and takes the shape of the mold, forming the final product. The mold can be made from various materials, such as: sand, plaster, or metal, depending on the casting method. After solidification, the casting is removed from the mold, cleaned, and further processed as needed.
What Is the Process of Casting?
The casting process, specifically sand casting, involves the following steps:
  1. Place the mold pattern, which determines the size and shape of the casting, in the sand. The sand (which includes additives) will take the shape of the pattern.
  2. Establish a gating system, consisting of a pouring cup and gates, to direct the molten metal into the mold cavity.
  3. Remove the mold pattern from the sand once the sand has taken its shape.
  4. Pour the molten metal, heated to the appropriate temperature, into the mold cavity through the gating system. The metal can be one of many elements or alloys such as: iron, steel, aluminum, and bronze.
  5. After pouring, the molten metal is left to cool and solidify within the mold. The cooling time varies depending on the type of metal used.
  6. Once the metal has cooled and solidified, open the mold to remove the newly formed metal casting. The mold patterns are typically reusable, but the molds themselves need to be remade for each casting.
How Long Does the Casting Process Take To Finish?
The duration of the casting process can vary significantly and is influenced by several factors. The time required for casting depends on: the size of the product, the specific type of casting performed, the sample size of production, and the level of labor involved in the process. Consequently, there is no fixed or standard time for casting. The time frame can range from as little as one hour to as long as 2–10 weeks, depending on these variables.
What Are the Common Materials Used in Casting?
Common materials used in casting include:
1. Magnesium
Magnesium alloys are commonly used in casting due to their lightweight properties and good strength-to-weight ratio. They are often utilized in applications for which weight reduction is crucial, such as: aerospace components and automotive parts.
2. Aluminum
Aluminum is a versatile casting material known for its excellent corrosion resistance, high thermal conductivity, and good mechanical properties. It is widely used in various casting methods, including: sand casting, die casting, and investment casting. Aluminum is utilized in industries such as: automotive, aerospace, and consumer goods. For more information, see our guide on the Physical Properties of Aluminum.
3. Iron
Iron is a widely used casting material that comes in different forms, including gray iron and ductile iron. Gray iron is known for its good casting properties, high thermal conductivity, and damping capacity, making it suitable for applications such as: engine blocks, pipes, and automotive components. Ductile iron, also known as nodular or spheroidal graphite iron, offers higher strength, toughness, and ductility, making it ideal for applications requiring greater load-bearing capabilities.
4. Zinc
Zinc is commonly used in die casting due to its low melting point, excellent flow characteristics, and dimensional stability. It is often chosen for casting intricate shapes and thin-walled components. Zinc castings find applications in various industries, including: automotive, electronics, and consumer products.
5. Steel
Steel is a strong and durable casting material used for applications that require high strength, wear resistance, and impact resistance. It is suitable for heavy-duty components subjected to harsh conditions, such as: machinery parts, construction equipment, and tools. For more information, see our guide on What Makes Up Steel.
6. Copper Alloys
Copper alloys, such as bronze and brass, are popular casting materials known for their excellent electrical conductivity, corrosion resistance, and thermal conductivity. They are commonly used in: electrical and plumbing components, decorative items, and musical instruments.
7. Lead Alloys
Lead alloys are utilized in certain casting applications, primarily due to their low melting point and malleability. They are used in specialized industries, including: radiation shielding, battery manufacturing, and certain industrial applications. It is important to note that the use of lead is carefully regulated due to its potential environmental and health concerns.
What Are the Industrial Applications of Casting?
The industrial applications of casting are diverse and extensive. Here is a list of common applications:
  1. Chemical Process Equipment: Employed in the production of chemical process equipment such as: reactors, heat exchangers, and pumps.
  2. Automobile Casting: Produces engine blocks, cylinder heads, transmission cases, and other critical components.
  3. Plant Machinery: Casting plays a crucial role in the manufacturing of various components. Plant machinery refers to a wide range of equipment used in industries such as: manufacturing, power generation, oil & gas, and shipbuilding. Some specific applications of casting in plant machinery include: impellers, casings, and valve bodies.
What Are Examples of Casting Products?
Casting is a versatile manufacturing process that produces a wide range of products for various industries. Here are some examples of casting products:
  1. Hydrants, used for water supply systems.
  2. Firefighting equipment such as: fire hydrants, couplings, and fittings.
  3. Plumbing components like: pipe fittings, valves, and connectors.
  4. Components for military vehicles and transportation equipment, such as: engine parts, brackets, and structural elements.
  5. Electrical hardware components, including: electrical enclosures, connectors, and terminal blocks.
  6. Precision machinery parts, such as: gears, housings, and brackets.
How Durable Are Casting Products?
Cast metal products, especially those that have undergone heat treatment, are durable. Depending on the metal alloy and application, their service life might range from a few months to several decades. Once the service life of a casting ends, the cycle begins again. It is collected by a scrap yard, recycled, and recast into a new object.
Does the Casting Product's Thickness Vary?
Yes, the thickness of casting products can vary. The casting process allows for the production of components with varying wall thicknesses, depending on the design requirements and the capabilities of the casting method. Different sections of casting can have different thicknesses to achieve the desired strength, weight, and functionality of the final product.
What Is the Future of Casting?
The future of casting holds significant potential with the integration of advanced technologies. Optical measuring systems, such as the ATOS 3D Digitizer, are revolutionizing the industry by enabling efficient and accurate measurement of complex surfaces. These systems eliminate the laborious and time-consuming nature of traditional measuring methods, providing full-field measurements and faster validation. Embracing such technological advancements will enhance productivity, quality control, and overall efficiency in the casting process.
Is Casting Still Used Today?
Yes, casting is still widely used today in various industries. It remains a popular manufacturing process for creating complex metal components with excellent strength and durability. Casting methods, such as: sand casting, investment casting, and die casting, continue to be essential in sectors like: automotive, aerospace, and construction.
What Are the Advantages of Casting?
Advantages of the casting process include:
  1. Ability to produce complex shapes easily.
  2. Versatility—a wide variety of metals and other materials can be cast.
  3. Cost-effectiveness, especially for small quantities.
  4. Capability to produce large-sized castings up to 200 tons.
  5. Cost and time savings compared to other manufacturing methods.
  6. Suitable for materials that cannot be mechanically worked.
  7. Simplifies the production of large and heavy components.
What Are the Disadvantages of Casting?
Disadvantages of the casting process include:
  1. The surface finish may require additional finishing operations.
  2. Limited mechanical properties compared to wrought materials.
  3. The possible presence of casting defects like porosity.
  4. The dimensional accuracy of castings can be compromised due to shrinkage during the solidification process.
  5. High initial tooling and equipment costs for certain casting methods.
  6. The casting process is typically restricted to metals with lower melting points.
Is Casting Expensive?
Yes, casting can be expensive due to various factors. The cost of casting includes: tooling costs, such as mold and fixture expenses, as well as the unit cost of the material used, which can be higher for stainless steel. Additionally, factors like complexity, volume, and required finishing operations can impact the overall cost of casting. The mold cost of stainless steel casting typically ranges from $1,200 to $2,500.
This article presented casting, explained it, and discussed its various types and how it works. To learn more about casting, contact a Xometry representative.
