ResourcesInjection MoldingBasics of Plastic Injection Molding
Injection molded parts. Image Credit: luchschenF/Shutterstock.com
Explore the injection molding process and how it works.
 9 min read
 13 min read
Plastic injection molding is a popular manufacturing technique in which thermoplastic pellets are converted into high volumes of complex parts. The injection molding process is suitable for a variety of plastic materials and is a vital aspect of modern life—phone cases, electronic housings, toys, and even automotive parts would not be possible without it. This article will break down the basics of injection molding, describe how injection molding works, and illustrate how it is different from 3D printing.
What Are the Basics of Plastic Injection Molding?
The basics of plastic injection molding process includes creating the product design, making a tooling a mold to fit the product design, melting the plastic resin pellets, and using pressure to inject the melted pellets into the mold.
See a breakdown of each step below:
1. Creating the Product Design
Designers (engineers, mold maker businesses, etc.) create a part (in the form of a CAD file or other transferrable format), following fundamental design guidelines specific to the injection molding process. Designers should try to include the following features in their designs to help increase the success of a plastic injection mold:
  • Bosses for threaded inserts/fasteners
  • Constant or near-constant wall thicknesses
  • Smooth transitions between variable wall thicknesses
  • Hollow cavities in thick sections
  • Rounded edges
  • Draft angles on vertical walls
  • Ribs for supports
  • Friction fits, snap-fit joints, and other non-fastener joining features
  • Living hinges
Additionally, designers should minimize the following features to reduce defects in their designs:
  • Non-uniform wall thicknesses or especially thin/thick walls
  • Vertical walls with no draft angles
  • Sudden geometrical changes (corners, holes, etc.)
  • Poorly designed ribbing
  • Undercuts/overhangs
2. Making a Tooling Mold to Fit the Product Design
Highly skilled machinists and toolmakers, using the product design, fabricate a tooling mold for the injection molding machine. A tooling mold (also known as simply a tool) is the heart and soul of the injection molding machine. They are carefully designed to contain the negative cavity for the product design and additional features such as sprues, runners, gates, vents, ejector systems, cooling channels, and moving components. Tooling molds are made out of specific grades of steel and aluminum that can withstand tens of thousands (and sometimes hundreds of thousands) of heating and cooling cycles, such as 6063 aluminum, P20 steel, H13 steel, and 420 stainless steel. The mold fabrication process takes upwards of 20 weeks to complete, including both fabrication and approval, making this step the most extended aspect of injection molding. It is also the most expensive part of injection molding, and once a tooling mold is fabricated, it cannot be drastically changed without incurring additional costs.
3. Melting the Plastic Resin Pellets
After operators obtain the finished mold, it is inserted into the injection molding machine, and the mold closes, starting the injection molding cycle.
Plastic granules are fed into the hopper and into the barrel. The reciprocating screw is drawn back, allowing materials to slip into the space between the screw and the barrel. The screw then plunges forward, forcing the material into the barrel and closer to the heater bands where it melts into molten plastic. The melting temperature is kept constant as per the material specifications so that no degradation occurs in the barrel or in the mold itself.
4. Using Pressure to Inject the Melted Pellets Into the Mold
The reciprocating screw forces this melted plastic through the nozzle, which is seated within a depression in the mold known as a mold sprue bushing. The moving platen pressure fits the mold and the nozzle together tightly, ensuring no plastic can escape. The melted plastic is pressurized by this process, causing it to enter all parts of the mold cavity and displacing cavity air out through the mold vents.
FREE Injection Molding Principles E-Book
Injection Molding Machine Components
The components of an injection molding machine include hopper, a barrel, a reciprocating screw, heater(s), movable platen, a nozzle, a mold, and a mold cavity.
More information on each of the injection molding components in the list below:
  • Hopper: the opening where plastic granules are fed into the machine.
  • Barrel: the outer housing of the injection molding machine, which contains the reciprocating screw and the plastic granules. The barrel is wrapped in several heater bands and is tipped with a heated nozzle.
  • Reciprocating screw: the corkscrew component that conveys and pressurizes the plastic material as it melts through the barrel.
  • Heaters: also known as heating bands, these components provide thermal energy to the plastic granules, turning them from a solid form to a liquid. form.
  • Movable Platen: The moving component connected to the mold core that applies pressure to keep both mold halves airtight and also releases the mold core when revealing the finished part.
  • Nozzle: the heated component that provides a standard outlet for molten plastic into the mold cavity, keeping both temperature and pressure as stable as possible.
  • Mold: the component or components that contain the mold cavity and additional supporting features like ejector pins, runner channels, cooling channels, vents, etc. At a minimum, molds are separated into two halves: the stationary side (closer to the barrel) and the mold core (on the moving platen).
  • Mold Cavity: the negative space that, when filled with molten plastic, will shape it into the desired final part plus supports, gates, runners, sprues, etc.
Below is an image of typical injection molding machine diagram:
Injection molding machine.
Image Credit: Wikipedia
How Does Injection Molding Work?
Once the plastic has filled the mold including its sprues, runners, gates, etc., the mold is kept at a set temperature to allow uniform solidification of the material into the part shape. A holding pressure is maintained while cooling to both stop backflow into the barrel and reduce shrinking effects. At this point, more plastic granules are added to the hopper in expectation of the next cycle (or shot). When cooled, the platen opens and allows the finished part to be ejected, and the screw is drawn back once more, allowing material to enter the barrel and start the process over again.
The injection molding cycle works by this continuous process—closing the mold, feeding/heating the plastic granules, pressurizing them into the mold, cooling them into a solid part, ejecting the part, and closing the mold again. This system allows for the rapid production of plastic parts, and upwards of 10,000 plastic parts can be made in a workday depending upon the design, size, and material.
For more information, see our guide on the injection molding process.
The diagram below illustrates the four essential steps of the injection molding process:
processing cycle injection molding process
Processing cycle of the conventional injection molding process.
Image Credit: Processing cycle/ResearchGate.net
How to Choose the Best Plastic for Plastic Injection Molding?
Choosing the right plastic for plastic injection molding can be difficult—there are thousands of options in the market from which to choose, many of which will not work for a given goal. Luckily, an in-depth understanding of the desired material properties and intended application will help narrow the list of potential options into something more manageable. When considering the application, it is important to keep in mind the following questions:
  • Where will the part be used?
  • How long is its operational lifespan?
  • What stresses are involved in the application?
  • Does aesthetics play a role, or is the performance of paramount importance?
  • What are the budget constraints on the application?
Similarly, the questions below are useful when determining the desired material properties:
  • What are the mechanical and chemical characteristics needed from the plastic?
  • How does the plastic behave when heating and cooling (i.e., thermal expansion and shrinkage, melting temperature range, degradation temperature)?
  • What interactions does the plastic have with air, other plastics, chemicals, etc.?
Included below is a table of the common injection molding plastics, each with its own set of advantages and general industry applications:
MaterialGeneral Industry ApplicationAdvantages
Material
Polypropylene (PP)
Commodity
Advantages
- Chemical resistant, impact resistant, heat resistant, sturdy
Material
High Density Polyethylene (HDPE)
Commodity
Advantages
- Chemical resistant, impact resistant, cold resistant, and sturdy
Material
Polystyrene
Commodity
Advantages
- Impact resistant, moisture resistant, flexible
Material
Polyethylene (PE)
Commodity
Advantages
- Leach resistant, recyclable, flexible
Material
High Impact Polystyrene (HIPS)
Commodity
Advantages
- Cheap, easily formed, colorful, customizable
Material
Polyvinyl Chloride (PVC)
Commodity
Advantages
- Sturdy, impact resistant, flame resistant, insulative
Material
Acrylic (PMMA, Plexiglass, etc)
Engineering
Advantages
- Impregnable (glass, fiberglass, etc.), heat resistant, fatigue resistant
Material
Acrylonitrile Butadiene Styrene (ABS)
Engineering
Advantages
- Sturdy, temperature resistant, colorful, chemically safe
Material
Polycarbonate (PC)
Engineering
Advantages
- Impact resistant, optically clear, temperature resistant, dimensionally stable
Material
Nylon (PA)
Engineering
Advantages
Material
Polyurethane (TPU)
Engineering
Advantages
- Cold resistant, abrasion resistant, sturdy, good tensile strength
Material
Polyetherimide (PEI)
Performance
Advantages
- High strength, high rigidity, dimensionally stable, heat resistant
Material
Polyether Ether Ketone (PEEK)
Performance
Advantages
- Heat resistant, flame retardant, high strength, dimensionally stable
Material
Polyphenylene Sulfide (PPS)
Performance
Advantages
- Excellent overall resistances, flame retardant, harsh environment resistant
Does Product Design Affect the Type of Plastic to Be Used in Plastic Injection Molding?
Yes, material selection absolutely depends on the product design, both in the application and in complexity. For example, designs calling for bendable sections/living hinges will require a strong yet flexible plastic like polypropylene. Similarly, structural parts that must be resistant to chemicals, abrasions, etc. should prioritize plastics like PEEK, Nylon, and others within these families.
Is 3D Printing the Same as Plastic Injection Molding?
No, 3D printing is a separate set of processes from injection molding. With 3D printing, the material is deposited in a layer-by-layer process guided by a 3D model of the desired part. With injection molding, molten plastic is injected into a mold cavity under high pressure, creating a part all at once. Both processes are considered to be "Additive Manufacturing".
In 3D Printing, Supports for overhangs and voids are also printed with the part, as well as additional features to reduce warping and other defects. 3D printing is a lengthy process, taking at minimum several hours, and can take a few days depending upon the size and complexity of the printed object. 3D printed parts are commonly produced out of thermoplastics, but other possible materials include thermosets, impregnated plastics, ceramic powder, and metal/alloy powder.
In Plastic Injection Molding, plastic injection molds come out with suitable surface quality and are essentially ready for application (with only sprues, runners, gates, and minor defects to manage). Thermoplastics are generally the preferred material used in injection molding, though newer injection molding processes can accept thermosets, impregnated materials, some metal powders, and some types of ceramics.
What Is the Difference Between 3D Printing and Injection Molding?
With 3D printing, the material is deposited in a layer-by-layer process guided by a 3D model of the desired part, while with injection molding, molten plastic is injected into a mold cavity under high pressure, creating a part all at once. To learn more, see our guide on 3D Printing vs. Plastic Injection Molding.
Below is a list of comparisons between 3D Printing and Injection molding using key metrics:
ParameterInjection Molding3D printing
Parameter
Materials
Injection Molding
Thermoplastics, some specialty materials in newer machines
3D printing
Thermoplastics, thermosets, metals, ceramic, impregnated materials
Parameter
Cost
Injection Molding
High initial investment cost, low cost per-part
3D printing
Medium to high initial investment cost, medium to high cost per part
Parameter
Production volume
Injection Molding
1000s-10,000s parts per workday
3D printing
1-10 parts per workday
Parameter
Lead times
Injection Molding
Slow initial lead times for mold creation, fast production lead times
3D printing
Fast overall lead times
Parameter
Part size
Injection Molding
Highly variable (both very small and large parts possible)
3D printing
Restricted by build space, parts are generally no bigger than a cubic meter
Parameter
Waste
Injection Molding
Low/no waste, and waste can be reground back into stock
3D printing
High waste output
Parameter
Design changes
Injection Molding
Difficult, changes are slow
3D printing
Very easy, rapid changes possible
This article presented the basics of injection molding to explain how it works, the materials that can be used, and how the process differs from other techniques such as 3D printing. We hope this article helped readers understand this manufacturing process and how it can add immense value to manufacturing capacity, given a few key considerations.
