ResourcesMaterialsShore A Hardness Scale: Definition, Uses, Types, Benefits, and Limitations
Thermoplastic (TPE). Image Credit: Shutterstock.com/Meaw_stocker
 9 min read
April 18, 2024
 12 min read
Durometer, or hardness, is a material property that describes a material’s tendency to resist localized deformation or indentation. The Shore A hardness (durometer) scale is one of many durometer scales used to measure material hardness. Shore A durometers range from 0 to 100 — the higher the durometer value, the harder the material. The Shore A scale is often used in the polymer industry to aid in material selection, ensure consistent quality products, and easily compare the hardness of materials. However, it’s important to note that the hardness values of two different scales, such as Shore D vs. Shore A, cannot be compared since measured hardness values are relative to other materials using the same scale.
The Shore A durometer scale is commonly used for soft to medium-soft materials such as vulcanized and natural rubber, TPEs (thermoplastic elastomers), flexible polyacrylics and thermosets, leathers, wax, and felt. This article will define the Shore A hardness scale,  its use in industry, its benefits, and its limitations.
What Is the Shore A Hardness Scale?
The Shore A hardness scale is a method used to characterize how resistant materials are to localized deformation or indentation. It is one of many scales used to measure the durometer (or hardness) of a material, typically of polymeric materials. The Shore A scale measures the hardness of a variety of materials — from soft rubbers, TPEs (thermoplastic elastomers), and silicones to semirigid plastics.
Hardness values determined using the Shore A scale are relative to the hardness of other materials that have been measured using the same scale. An empirical relationship between the depth of the indentation made in one material compared to a standard of 0 to 100% of the possible indentation depth, is used to report an empirical number known as Shore A hardness.
How Is the Shore A Hardness Scale Used in Industry?
The Shore A hardness scale is widely used in the polymer and plastics industry to characterize the hardness of various materials. Manufacturers use durometer testing as a quality check for manufactured products. For example, silicone hardness or rubber hardness can easily be measured and evaluated against manufacturing standards. Additionally, designers use the Shore A hardness scale to compare potential materials that may be suitable for an intended application. For more information, see our guide on What is Durometer.
What Types of Materials Can Be Tested Using the Shore A Hardness Scale?
Nonmetallic materials such as thermoplastics, thermosets, TPEs (thermoplastic elastomers), silicones, and more are the types of materials tested using the Shore A hardness scale. Shore A durometers range from 0-100, where soft materials like rubber bands have a hardness of approximately 20 A and harder materials like golf balls have a hardness of approximately 90 A. Therefore, nonmetallic materials harder than golf balls, such as certain types of wood, bone, and hard hats are incompatible with the Shore A scale.
What Are the Benefits of Using the Shore A Hardness Scale?
The benefits of using the Shore A hardness scale are listed below:
  1. Allows manufacturers to determine which material is sufficiently hard (or soft) for a particular application.
  2. Enables easy comparison of material hardness when using the same scale.
  3. Gives manufacturers a tool to perform statistical process control, thus ensuring consistent quality products.
What Are the Limitations of the Shore A Hardness Scale?
The limitations of using the Shore A hardness scale are listed below:
  1. Values cannot be accurately compared to hardness values obtained using other scales.
  2. Is only suitable for measuring non-metallic materials such as thermoplastics, thermosets, TPEs (thermoplastic elastomers), silicones, cellular materials, and waxes.
How Is the Shore A Hardness Scale Determined?
The Shore A hardness scale is determined by measuring the hardness of different materials and comparing their hardness values using the same hardness scale. The hardness of materials measured using the Shore A scale is relative to the hardness of other materials using the same scale. Hardness values are obtained by the amount of indentation observed when a particular indentation force is applied. Softer materials will have deeper indentations while harder materials will have shallower indentations. For example, a shopping cart caster with a Shore hardness of 90 A is harder than a gel insole with a hardness of 30 A. With enough materials measured using the same scale, the scale is determined by plotting the hardness of each material.
How Does Temperature Affect Shore A Hardness Measurements?
Most materials measurable by the Shore A hardness test will give lower hardness readings at higher temperatures, and higher hardness readings at lower temperatures. Suppliers of elastomeric products such as O-rings design their products to a specific Shore A hardness (e.g., Shore A 70), and report the temperature range in which the material retains an appropriate durometer level (neither too stiff nor too soft) to perform its function.
What Is the Range of Hardness Values on the Shore A Hardness Scale?
The Shore A hardness scale ranges from 0 to 100. Harder materials have higher Shore A values than softer materials. For instance, a rubber band has a hardness of approximately 20 A while a shoe sole has a hardness of approximately 70 A.
What Are Examples of Materials That Use the Shore A Hardness Scale?
The types of applications that use the Shore A hardness scale are shown in Table 1 below:
Table 1: Shore A Hardness of Typical Materials
MaterialShore A Hardness
Material
Gummy candy
Shore A Hardness
10 A
Material
Marshmallow
Shore A Hardness
10 A
Material
Rubber band
Shore A Hardness
20 A
Material
Gel shoe insole
Shore A Hardness
30 A
Material
Bottle nipple
Shore A Hardness
40 A
Material
Shoe sole
Shore A Hardness
70 A
Material
Tire tread
Shore A Hardness
70 A
Material
Golf ball
Shore A Hardness
90 A
Material
Shopping cart wheels
Shore A Hardness
90 A
What Does 70 Shore A Mean?
70 Shore A means the hardness of a material is measured as “70” on the Shore A hardness scale. A tire tread is an example of a material with a 70 A hardness.
What Does 85 Shore A Mean?
85 Shore A means a hardness of “85” using the Shore A scale. A hardness of 85 A would be harder than a material with 70 A. A tire tread has a hardness of 70 A while a leather belt can have a hardness of 85 A.
What Does 90 Shore A Mean?
90 Shore A is a hardness measurement of “90” using the Shore A hardness scale. Shore 90 A hardness is much harder than 70 A and 85 A. Materials with 90 A are rigid and cannot be deformed by hand. An example of a material with a 90 A hardness is a caster on a shopping cart or a golf ball.
What Are Examples of Shore A Scale Standards?
The Shore A scale and Shore D scale overlap at higher values of the Shore A scale and lower values for the Shore D scale. Lower values of the Shore A scale overlap with the Shore 00 scale. The Shore D scale starts at approximately 60 A while the Shore 00 scale maxes at about 70A. Figure 1 is an example of a Shore hardness comparison chart:
comparison of shore hardness
Shore hardness comparison chart.
Image Credit: https://www.researchgate.net/
It is important to note that hardness values should only be used as a point of reference if being compared on the same scale. Do not compare Shore A values with Shore D values to make material selections, as the slope of hardness values from 0 to 100 differ greatly between the two scales. For instance, Shore A 50 is not the same as Shore D 50. Some examples of materials whose hardness can be expressed with either the Shore A and Shore D scales are listed below:
  1. A tire tread can have a hardness of 70 A(~10 D).
  2. A leather belt can have a hardness of about 80 A (~40 D).
  3. A golf ball can have a hardness of 90 A(~50 D).
Can the Shore A Hardness Scale Measure the Hardness of a Rubber Tire?
Yes, the Shore A hardness scale can be used to measure the durometer of a rubber tire. A rubber tire has a hardness of about 65 to 70 A.
Is the Shore Hardness of 95 A Equal to the Shore Hardness of 45 D?
Yes, a Shore hardness of 95 A is roughly equal to a Shore hardness of 45 D. While the two hardness values are roughly equivalent, they should not be assumed to be the same. This is because hardness values using the Shore A scale are relative to other materials on the same scale. While there is some overlap between Shore A and Shore D scales, the measurement scales for both scales have a maximum value of 100. Hard materials with a Shore A value over 100 will always produce a hardness value of 100 A. To obtain an accurate comparison between two materials, measure material hardness using the same scale.
Does Shore D Measure Harder Materials Than Shore A Scale?
Yes, the Shore D scale measures materials that are harder than those measured with the Shore A scale. Shore D is typically used for medium-soft to very-hard materials that have a hardness greater than about 50 A. While there is some overlap between the possible hardness values that can be measured using the two scales, hardness values from the two scales should not be compared head-to-head.
What Is the Difference Between the Shore A Hardness Scale and the Shore D Hardness Scale?
The differences between the Shore A scale and the Shore D scale lie in the acquired hardness value of a material due to the shape of the indenter used for testing. The shape of the indenter for Shore A tests is a flat cone with sides sloping up at 35° from the horizontal. The Shore D indenter is a sharp cone point measured at 30° from the horizontal. The Shore A scale is suitable for elastomers, rubbers, and soft plastics while the Shore D scale is suitable for hard rubbers and thermoplastics.
This article presented shore A hardness scale, explained what it is, and discussed its benefits and uses. To learn more about shore A hardness scale, contact a Xometry representative.
