ResourcesSheet10 Best Laser Cutting Machines
Industrial laser cutter. Image Credit: Shutterstock.com/Christian Delbert
April 26, 2024
 16 min read
Laser cutting is an advanced fabrication process that uses focused beams of light to precisely cut materials such as metals, glass, and concrete into desired shapes. It offers numerous advantages over traditional methods, such as higher accuracy, faster manufacturing speeds, greater flexibility in design options, and lower energy consumption. The machines used can range from budget-friendly engravers to large industrial lasers, depending on the application at hand. Some of the best laser cutting machines are: LaserPecker 2 Laser Engraver, Full Spectrum Laser Muse Core, and Flux Beamo 30 W.
1. LaserPecker 2 Laser Engraver
The LaserPecker 2 Laser Engraver features a highly precise focal lens, allowing users to achieve amazing detail on their projects without sacrificing speed or accuracy. The device also boasts an intuitive user interface which makes it easy to operate, with minimal setup time required and a working area of 100x100 mm. The LaserPecker 2 can be used on any type of material including wood, paper, leather, metals, and plastics. This laser engraver also has built-in safety features that protect the user from potential hazards associated with operating high-powered lasers. It costs around $1500.
2. Full Spectrum Laser Muse Core
The Full Spectrum Laser Muse Core features an impressive 40/45 W CO2 laser capable of working with any material such as wood, plastic, acrylics, and metals. It has a wide range of settings, for users to customize their projects, including speed, power output, and focus type. Its large engraving area makes it perfect for large-scale projects or intricate designs which can be created in minutes. This device comes with several safety features such as an automatic shut-off if the door is opened during operation to ensure user safety at all times. The price of the device is around $3000.
3. Flux Beamo 30 W
The Flux Beamo 30 W utilizes a high-performance beam of focused light to precisely cut materials such as wood, plastic, acrylics, and cardboard and also make engravings on metals, and more. The Beamo features an intuitive user interface with built-in controls that allow quick setup of project settings within minutes. The included software can easily design intricate shapes or detailed designs in no time at all. The device is equipped with several safety features such as an air filtration system that keeps dust out of the work area while simultaneously cooling down the surface during operation. The device can be purchased for $2195 on Profound3D.
4. Triumph Fiber Laser Cutter
The Triumph TR-F 1325 and TR-F 1530 are both fiber laser cutting machines that are capable of cutting a variety of metals including stainless steel, aluminum, carbon steel, and brass. They are equipped with a laser power range of 500-6000 W, allowing for precise and efficient cutting of materials with varying thicknesses. The TR-F 1325 has a working area of 1300x2500 mm, while the TR-F 1530 has a working area of 1500x3000 mm. Both of these fiber laser cutters are equipped with advanced control systems and software that allow for easy programming and operation. They are sold for $28000 and $36000 respectively.
5. Ten-High Upgraded Version CO2
Ten-High CO2 lasers have several upgraded versions, two of which are the CO2 300x400mm Laser Engraving Cutting Machine with USB port and the CO2 400x600mm Laser Engraving Cutting Machine with USB. Both machines are equipped with water-cooled CO2 laser tubes for stable and efficient laser output for longer periods. The upgraded versions are suitable for a wide range of engraving and cutting applications and are particularly well-suited for smaller projects or materials. The CO2 400x600mm machine costs $3621 while the CO2 300mmx400mm costs $2080.
6. Atomstack Portable Mini Laser Engraver
The Atomstack P7 M30 Portable Mini Laser Engraver is a compact and lightweight laser engraving and cutting machine that is suitable for a wide range of materials. It is equipped with a 30 W laser that can cut through wood up to 15 mm thick and acrylic up to 10 mm thick. The engraving area is 200x200 mm, providing plenty of space for your projects. This machine is capable of delivering a laser output of 4.5-5.5, allowing for precise and detailed engravings. The P7 M30 is portable and easy to use, making it a great choice for hobbyists and professionals alike. It is available for purchase on AliExpress for around $253.
7. Orion Motor Tech 40 W Laser Engraver and Cutter
The Orion Motor Tech 40 W laser engraver and cutter features an advanced CO2 laser tube for superior cutting accuracy and speed. It has adjustable power settings to ensure precise results on even the most delicate materials. The Orion Motor Tech also has a large working area of up to 300x200 mm, so it’s good for larger projects. This laser engraver and cutter comes equipped with intuitive LCD touchscreen technology which allows users to quickly adjust settings such as cut depth and speed. The device is sold for around $600 on Alibaba.
8. OMTech 70 W (AF1630-70)
The OMTech 70 W (AF1630) features multiple power levels, allowing for greater control over cuts, as well as an autofocusing system that ensures every cut is perfect every time. It has a maximum working area of 406x762 mm, a high-speed operating system, and robust construction. It also comes with easy-to-use software which makes designing projects simple and efficient. The OMTech 70W CO2 Laser Engraver/Cutter is sold for $2899 on Amazon.
9. LaserPecker Mini Desktop Laser Engraver
The LaserPecker Mini Desktop Laser Engraver is a versatile tool for laser engraving. This machine offers an easy-to-use interface, allowing users to create intricate designs quickly and accurately. It has adjustable power settings that allow you to customize your cuts depending on the material being used, as well as an autofocus feature that ensures perfect results every time. Additionally, it comes with software designed for use with this model—making designing complex patterns or logos incredibly simple. This is a relatively cheap device, sold for as low as $209.99.
10. 130 W Reci W4 CO2 Laser Tube Engraver and Cutter
The Reci W4 130 W CO2 Laser Tube Engraver and Cutter features an adjustable focus lens, an autofocusing system, and multiple power levels offering greater control over cuts. This laser tube engraver has a maximum working area of 1300x900 mm and includes software that makes designing jobs easy and efficient. The 130W RECI W4 CO2 Laser Cutter is sold for around $6008.
How To Choose the Best Laser Cutting Machine
When it comes to choosing the best laser cutting machine, there are a few key factors that need to be taken into consideration as listed below:
  1. Power: The higher the wattage of your machine, the more powerful and precise cuts you can achieve. This means that higher-wattage machines will be able to cut thicker materials with ease, whereas lower-wattage models may struggle with tougher jobs.
  2. Size: Make sure you choose a model with an appropriate working area for your projects; otherwise, you may find yourself limited in the tasks which can be completed.
  3. Features: Features such as autofocusing technology and adjustable power levels, provide greater control over cuts.
What Is the Best Laser Cutting Machine for Wood?
The best laser-cutting machine for wood is the 130 W Reci W4 CO2 Laser Tube Engraver and Cutter. This top-of-the-line engraver offers a range of features such as its precise cutting results, easy-to-use interface, and rugged construction. It can quickly cut through hardwoods, plywood, acrylics, and other materials with minimal effort. Two other types of laser cutters for wood applications include the Orion Motor Tech 40 W Laser Engraver/Cutter and the Glowforge Plus which uses a CO2 laser system of 40 W.
What Is the Best Laser Cutting Machine for Plastic?
The best laser-cutting machine for plastic is the Ten-High Upgraded Version CO2 400mmx600mm. It is specifically designed for engraving on organic materials, including acrylic, and has a carving depth of 0-2 mm, depending on the material.
What Is the Best Laser Cutting Machine for Metal?
The best laser-cutting machine for metal is the Triumph CNC Fiber Laser Cutting Machine, with a power output of 300-1500 W. This laser is powerful enough to engrave stainless steel, aluminum, copper, gold, silver, and plastic.
What Is the Best Laser Cutting Machine for Engraving?
The best laser cutting machine for engraving is the OMTech AF1630-70 laser engraver. It is an easy-to-use machine, capable of quickly and accurately cutting through most materials. This machine is perfect for anyone who wants to start repairing or crafting their own items. Other laser engravers include the xTool D1 Laser Engraver (10 W) which works at a speed of up to 8890 mm per minute and the Ten-HighUpgraded Version CO2 300mmx400mm water-cooled CNC engraving machine.
What Is the Most Affordable Laser Cutting Machine?
The most affordable laser cutting machine is the LaserPecker Mini Desktop Laser Engraver and Cutter. It is a small and budget-friendly desktop laser cutter and engraver sold for $209.99.
Is a Laser Cutting Machine a Worthwhile Investment?
Yes, a laser cutting machine is a worthwhile investment for those looking to create unique and intricate designs out of wood, metal, and other materials. This technology offers significantly higher precision than traditional cutting methods—like manual saws or routers—which makes it ideal for creating complex shapes with great accuracy. To learn more, see our guide on How Do Laser Cutters Work.
Can a Laser Cutting Machine Be Used as a Laser Engraver?
Yes, a laser cutting machine can be used as a laser engraver. Laser cutters are capable of producing precise and intricate designs on almost any type of material, including wood, metal, plastic, and more. The precision that these machines offer makes them well-suited for both cutting and engraving applications.
What Is the Difference Between Laser Cutting and Laser Engraving?
The main difference between laser cutting and laser engraving is the depth to which they affect the material. Laser cutting uses a high-powered beam of light that produces intense heat, allowing it to cut through materials such as wood, acrylic, metal, or plastics. The result is a precise cut with crisp edges and minimal wastage of material. Laser engraving, on the other hand, uses a lower-power beam that only affects the surface layer of the material. This results in an impression or mark being made on the surface without actually cutting all the way through it. Engraved designs are usually limited to 2D images such as logos and text but can also be used for 3D applications with complex patterns like molds or dies.
This article presented the ten best laser cutting machines, explained each of them, and discussed their various features. To learn more about laser cutters, contact a Xometry representative.
