ResourcesSheetExtruded and Cast Acrylic: How to Laser Engrave and Cut Acrylic
Colorful cast acrylic sheets. Image Credit: Shutterstock.com/Roberto Sorin
Learn more about how to laser cut extruded and cast acrylic.
 13 min read
March 21, 2024
 1 min read
Laser cutting and engraving acrylic refers to a process where a CAD file is used as a guide to accurately cut a design from acrylic material. There are two types of acrylic material that are compatible with laser machines: cast acrylic (GS) and extruded acrylic (XT). Examples of the different types of acrylic sheets that can be cut with laser machines include: Plexiglass®, Plaskolite, Perspex®, and Acrylite®.
Cast acrylic refers to acrylic sheets created by pouring liquid acrylic into molds that can be configured into a variety of shapes and sizes. Cast acrylic is better than extruded acrylic for engraving but does not develop the same type of "flame-polished" edge that extruded acrylic does when it is laser cut.
CO2 lasers are the best machines for cutting and engraving acrylics. This is because the CO2 laser's wavelength (9 to 11 m) is readily absorbed by acrylics, causing the plastic material to vaporize where the laser hits it. It can even cut through clear acrylics. The optimal power, speed, airflow, and focal length of the laser machine will differ on a case-by-case basis. Settings will depend on the type of acrylic and the material thickness.
This article will discuss the steps in laser cutting and engraving extruded and cast acrylic. It will also present recommended machine settings, tips for successful cutting and engraving, and alternatives to cast or extruded acrylic for CO2 laser processing.
How to Laser Cut and Engrave Extruded Acrylic
Extruded acrylics are not recommended for engraving applications. Extruded acrylic materials are better suited for the fabrication of parts and shapes by CO2 laser cutting. The steps in laser cutting extruded acrylic are:
  1. Create the vector design. Vector files specify the points, curves, lines, and shapes that must be followed by the laser beam making the cut. A good vector design is a prerequisite for all laser-cutting procedures and has a direct impact on the quality of the finished item.
  2. Carefully plan the cutting sequence when cutting many components from a single sheet of acrylic. To prevent overheating, ample cooling time between each cut made in a segmented area is needed.
  3. Properly fixture the material on the worktable by elevating the material so that it is not in contact with the cutting table for optimal results. Lift the acrylic panel by using Epilog’s pin table or any other type of support. There will be far less backside reflection and grid markings left on the material following laser cutting as a result.
  4. Set the recommended initial values for critical laser cutter parameters such as power, speed, cutting frequency, and airflow. It’s also important to select the right lens, air nozzle, and set the focal point correctly before adjusting the laser settings. Cutting acrylic is best accomplished with high power and rather slow speed. For cutting acrylics the advised frequency is 5,000-20,000 Hz for GS materials and a maximum of 5,000 Hz for XT materials.
  5. Some refinement of the laser cutting parameters for your specific application may be necessary. It may be necessary to alter the cutting speed, laser frequency, and focal point to improve edge quality.
  6. Once your set-up and calibration runs are complete, you can start using your production material to make perfect customer parts with optically transparent edges.
How to Laser Cut and Engrave Cast Acrylic
Cast acrylics are best suited for laser engraving. The basic steps required to laser engrave cast acrylic are listed below:
  1. The laser engraver requires a vector design file to guide the engraving of the desired shape onto the work material. However, the design should still have minimal anchor points to ensure that the cutting process is uniform.
  2. The cutting sequence should be planned precisely to ensure that the laser engraving process is as succinct and runs as smoothly as possible.
  3. Acrylics engrave nicely with low power and high speed. The desired designs can be produced with a relatively low-power laser. If the power is too high, some deformation in the material may occur.
  4. Do a test run of the engraving settings before doing the final piece. This ensures that all parameters are accurately set up to meet customer requirements for dimensions and aesthetics.
  5. Complete the final etching step.
What Are the Differences Between General Part and Presentation Part Cutting for Acrylic?
“General cutting” parts are parts that don’t require a cosmetic finish. The aesthetic details of these parts are not the top priority. The type of cut used to produce general cutting parts is termed separation cuts. In this case, you want to operate at the highest speed and power possible when cutting the acrylics with the laser.
Presentation parts, on the other hand, refer to parts that should have polished edges for presentation purposes. Here, cast acrylic will yield better cutting results than extruded acrylic, however, both materials operate on the same principle. This type of cut is termed quality cut, and as the name suggests, the cut quality is very important for superior aesthetics.
What Is the Fastest Acrylic Laser Cutting Speed for Presentation Parts?
The cutting speed for presentation parts is dependent on the desired cut quality, the power of the cutting machine, and the thickness of the material. For quality cuts, a lower cutting speed is required to ensure that the cut has no burrs, is flat, and is perpendicular. Figure 1 below shows the difference between “quality cut” cutting speeds and “separation cut” cutting speeds for different material thicknesses:
quality and separation cut cutting speeds chart
Line chart showing the difference between quality cut and separation cut cutting speeds.
Image Credit: https://howtolaser.com/
There is a linear relationship between the cutting speed and the laser power. In other words, a 200 W laser will take twice as long to cut through a given thickness as a 200 W laser, given that the thickness falls within the cutting range of both machines. As a general rule, presentation cuts are made with high power and low speed. The lower the speed, the nicer the edge. However, if too low a  speed is used, the cut part might not be dimensionally accurate due to too much material being cut away by the heat.
One of the advantages of extruded acrylic for laser-cut applications is that it melts at a lower temperature than cast acrylic, and thus does not require as much laser power as the cast material.
What Is the Best Laser Power for Acrylic Laser Cutting With General Parts?
The best laser cutting power level to use for general part cutting of acrylics (separation cutting) varies depending on the thickness of the material and the type of acrylic whether extruded or cast. For general-purpose cuts, the user can, within the range of the manufacturer's recommended settings, choose to either maximize speed (using the minimum power that will cut through the full material thickness), or to minimize power level, slowing the speed to a rate that makes the cut possible.
What Is the Best Laser Power For Acrylic Laser Cutting With Presentation Parts?
The best laser power for presentation parts is dependent on the thickness of the part being cut. For precision, or quality cuts,  higher power, and lower speed are advised.
Does The Type of Acrylic Affect the Speed and Power Required for Laser Cutting?
Yes, the type of acrylic being cut affects the laser speed and power requirements. Cast acrylic requires more power to cut a given material thickness because it has a higher melting point than extruded acrylic. The cutting speed, on the other hand, must be selected based upon the laser power level, the quality requirements for the cut, and the thickness of the work material.
How Does Acrylic Sheet Thickness Affect Laser Cutter Power Requirements?
The thicker the acrylic sheet, the higher the power requirement. The thickness of the sheet that needs to be cut has a significant impact on the amount of laser power needed to cut acrylic. As a general rule of thumb, 10 W of power is required for every 1 mm of acrylic sheet thickness. Lower power levels can be used, as long as the cut speed is slowed down to allow enough energy input to melt and cut the material. However, if the power is just too low for even a slower speed to compensate for the low power, then the cut quality may be insufficient for the application.
What Is the Best Setting for Laser Cutting Acrylic?
Laser cutter settings should use the machine manufacturer's recommendations as a starting point. The final settings will depend on material thickness, type of acrylic being cut, and part appearance requirements. Meeting the customer's requirements efficiently and economically may drive adjustments to laser power level, cutting speed, frequency, and focal point size. Listed below are some recommended starting point settings:
  1. Power: As a general guideline, you can cut 1 mm of acrylic material thickness for every 10 W of laser power. Peak power is the secret to being able to cut through thin materials very quickly and thick materials with considerably higher cut quality.
  2. Frequency: The most appropriate laser frequency value will vary based on the material and the type of cut you're trying to produce. For example: for cutting with a flame-polished edge (quality cut), high frequencies (20 to 25 kHz) are typically used for cast acrylic, while low frequencies (2–5 kHz) are typical for extruded acrylic.
  3. Speed: The laser cutting thickness and speed settings in Tables 1 and 2 below show the maximum speed and optimal speed for different laser power and material thickness:
Table 1: CO2 Laser Cutting Settings Chart for Maximum Speed
Power (W)3mm5mm8amm10mm15mm20mm25mm30mm35mm
Power (W)
25
3mm
8
5mm
4
8amm
1
10mm
15mm
20mm
25mm
30mm
35mm
Power (W)
40
3mm
15
5mm
8
8amm
4
10mm
3
15mm
20mm
25mm
30mm
35mm
Power (W)
60
3mm
20
5mm
10
8amm
5
10mm
4
15mm
2
20mm
25mm
30mm
35mm
Power (W)
80
3mm
25
5mm
12
8amm
9
10mm
6
15mm
3
20mm
1.5
25mm
0.5
30mm
35mm
Power (W)
100
3mm
30
5mm
15
8amm
10
10mm
7
15mm
4
20mm
2
25mm
0.8
30mm
0.3
35mm
Power (W)
130
3mm
35
5mm
17
8amm
12
10mm
8
15mm
5
20mm
3
25mm
1
30mm
0.5
35mm
0.2
Power (W)
150
3mm
40
5mm
21
8amm
15
10mm
11
15mm
7
20mm
4
25mm
1.8
30mm
0.8
35mm
0.4
Power (W)
180
3mm
45
5mm
25
8amm
18
10mm
16
15mm
9
20mm
5
25mm
2.5
30mm
1.3
35mm
0.6
Power (W)
200
3mm
55
5mm
30
8amm
25
10mm
20
15mm
11
20mm
7
25mm
5
30mm
3
35mm
1
Table Credit: https://artizono.com/
Table 2: CO2 Laser Cutting Settings Chart for Optimal Speed
Power (W)3mm5mm8mm10mm15mm20mm25mm30mm35mm
Power (W)
25
3mm
5
5mm
2
8mm
10mm
15mm
20mm
25mm
30mm
35mm
Power (W)
40
3mm
10
5mm
5
8mm
2
10mm
15mm
20mm
25mm
30mm
35mm
Power (W)
60
3mm
15
5mm
7
8mm
3
10mm
2
15mm
0.8
20mm
0.3
25mm
30mm
35mm
Power (W)
80
3mm
20
5mm
8
8mm
5
10mm
3
15mm
1.5
20mm
0.5
25mm
0.2
30mm
35mm
Power (W)
100
3mm
25
5mm
10
8mm
6
10mm
4
15mm
2
20mm
0.7
25mm
0.3
30mm
35mm
Power (W)
130
3mm
30
5mm
12
8mm
8
10mm
5
15mm
3
20mm
1
25mm
0.4
30mm
0.3
35mm
Power (W)
150
3mm
35
5mm
15
8mm
10
10mm
7
15mm
4
20mm
1.5
25mm
0.8
30mm
0.5
35mm
0.1
Power (W)
180
3mm
40
5mm
18
8mm
12
10mm
10
15mm
6
20mm
2
25mm
1.2
30mm
0.8
35mm
0.3
Power (W)
200
3mm
45
5mm
25
8mm
15
10mm
13
15mm
8
20mm
4
25mm
3
30mm
1.5
35mm
0.7
4. Nozzle Size and Airflow: Manage airflow onto the material surface to ensure that acrylic is cut smoothly. Always use the nozzle with the widest diameter while cutting acrylic, and if at all feasible, reduce the air assist to no more than 0.2 bar.
5. Focal Point:  When a material is thicker than 6 mm, shift the focal point of the laser to a point about one-third of the material thickness below the laser impact surface. This will improve the perpendicularity of the cut edge.
What Are the Acrylic Projects for Laser Cutting?
Laser-cut and laser-engraved acrylic materials can be used for a wide range of projects. Here are a few examples of industrial laser-cut/engraved applications:
  1. Advertising: LED wall-mount logos, indoor and outdoor signs.
  2. Building Materials: Stylish, transparent stairways and balconies;  windows.
  3. Automotive: Windshields, headlamp covers, dashboard indicator covers.
  4. Household Merchandise: Fish tanks, chandeliers, drawer separators, cutlery, baking and cooking tools, food containers, coasters, storage bins, and organizers are some examples of household items made from acrylics.
  5. Awards: Trophies and plaques.
  6. Architecture: Models of buildings.
  7. Jewelry: Earrings/buttons/pendants.
  8. Packaging: Containers/boxes.
  9. Toys: Puzzles and mazes.
  10. Personalized Items: Flashy business cards, bookmarks, table numbers, wall art, and stationery.
What Are the Alternatives to Acrylic for Laser Cutting?
There are several alternatives to acrylic for laser cutting. Other plastics that can be laser cut include:
  1. Fluoropolymers
  2. Delrin®
  3. Polycarbonate
  4. Mylar
  5. Polyimide
What Are the Common Mistakes Made When Laser Cutting Acrylic?
The following is a list of some of the common mistakes made when laser cutting acrylic:
  1. Using the incorrect settings for acrylic type. The settings of the laser need to be adjusted depending on the type of acrylic and the desired edge finish.
  2. The lens of the laser cutter plays a big role in determining the accuracy of the cuts, and should be selected accordingly.
  3. Spacing of cuts incorrectly. It’s very easy to not leave enough space between cut paths. This can lead to the design not being cut accurately.
What Are the Beginner Tips for Laser Engraving Acrylic Sheet (Plexiglass®)?
The following list shares some beginner tips for laser engraving of Plexiglass® sheets:
  1. Remove the protective paper covering on the side you want to engrave, but leave the other side in place to protect against bumps and scratches.
  2. Make sure you understand the best settings for the type of acrylic you are using.
  3. Engrave the back side of the acrylic sheet for a see-through effect, but remember to mirror your desired image.
  4. Change your settings to engrave from the bottom upwards. This avoids some of the debris being blown over sections that have already been engraved.
Which Laser Cutter Is Best for Acrylic Laser Cutting?
The best laser cutter for acrylic laser cutting is a high-power CO2 laser with a wavelength of 10.6 m. Laser light wavelengths between 9 and 11 um are readily absorbed by acrylics, causing the plastic material to melt or vaporize. As a result, CO2 lasers can even cut through clear acrylic sheets.
The light from a diode laser, on the other hand, will travel through clear acrylic without significantly altering the acrylic workpiece. A low-power diode laser machine can, however, be used to engrave acrylic and it can even provide good cutting results after several passes. Fiber lasers can also be used to engrave plastics like acrylic, but they are not ideal. The following is a list of currently available laser cutters that can produce high-quality results with acrylic, depending on the laser strength, performance, and material capacity:
  1. OMTech AF2028-60
  2. Glowforge Pro
  3. Full Spectrum Laser Muse Core
Why Is Plexiglass® Better for Acrylic Laser Cutting?
Some plastics, like Plexiglass®, lend themselves more to cutting than others. The best results are obtained with acrylic (PMMA) plexiglass and polypropylene. This is because it can generate cuts with smooth edges without any scorch marks.
This article presented extruded and cast acrylic, explained what they are, and discussed how to laser cut each of them. To learn more about extruded and cast acrylic, contact a Xometry representative.
  1. PLEXIGLAS® and ACRYLITE® are registered trademarks of Röhm, the company owned by the German inventor of PLEXIGLAS®, Otto Röhm.
  2. OPTIX®, FABBACK®, DURAPLEX®, and VIVAK® are registered trademarks of Plaskolite, LLC.
  3. PERSPEX® is a trademark of PERSPEX INTERNATIONAL LIMITED.
  4. OMETCH® is a registered trademark of Yabin ZHAO.
  5. Glowforge® is a registered trademark of Glowforge Inc.
  6. FULL SPECTRUM LASER® is a registered trademark owned by FULL SPECTRUM, LLC.
  7. DELRIN® is a registered trademark owned by DuPont Polymers, Inc.
  8. Mylar® is a registered trademark of the DuPont - Teijin Corporation.
