ResourcesSheetWhich Sheet Cutting Material Should I Choose?
Multiple materials
New to Sheet Cutting? Many first-time customers have a hard time deciding which material to choose. Aluminum 5052 or stainless steel 316? Black acrylic or acetal? Read on for valuable tips on selecting suitable material.
 1 min read
What Sheet Cutting Material Should I Choose?
Xometry offers dozens of materials for laser and waterjet cutting. They range from metals, plastics, foam, composite, and even wood. This list can be daunting, and each material available comes from different performance, cosmetic, or cost requirements.
If you are starting with sheet cutting, the truth is most projects can be a success with 6061 aluminum, 304 stainless, cold roll steel, or clear acrylic. Our customers have found that each of these four fills a unique niche. Read on to find why these four materials may become your go-tos as well!
Clear Acrylic
An inexpensive plastic used for decorative purposes and where high strength is not required.
Aluminum 6061
A good general purpose, high strength aerospace aluminum alloy.
304 Stainless Steel
A good general purpose stainless steel.
Cold Rolled Steel A366/1008
A strong general purpose steel with a clean surface finish.
Comparing Popular Sheet Cut Materials
Here's a chart that ranks the four materials against each other in terms of cost, appearance, and specific strength (also known as strength-to-weight ratio). Range: okay, good, better, best.
MaterialCostAppearanceSpecific Strength
Material
Clear Acrylic
Cost
Best
Appearance
Better
Specific Strength
Okay
Material
Aluminum 6061
Cost
Good
Appearance
Good
Specific Strength
Best
Material
Stainless Steel 304
Cost
Okay
Appearance
Best
Specific Strength
Good
Material
Carbon Steel
Cost
Better
Appearance
Okay
Specific Strength
Better
 It's worth noting that though we've ranked them against each other in terms of appearance, none of these materials look particularly bad. Stainless steel is more durable than aluminum, and thus holds its finish better. If you need a transparent material, then, of course, a metal won't work at all and you need a plastic like clear acrylic.
When should I choose cold roll steel?
Cold roll steel doesn't come out on top of any of the above categories, but it's still useful. Why? It is harder (good for sliding or wearing parts), denser, and can be welded more easily than the other materials. It's also magnetic.
When should I choose acrylic?
Acrylic is the least expensive of the materials on the list, in part because it can be laser cut. The metric thicknesses, like 3 mm (0.118 inches) and 6 mm (0.236 inches) are less expensive than their inch equivalents.
Other Sheet Material Substitutes
Not quite happy with those four? Here are some other suggestions!
If you are considering...But need...Try...
Aluminum 6061
But need...
Better formability (ability to bend the material into shape)
Try...
Aluminum 5052
Aluminum 6061
But need...
Better electrical conductivity
Try...
Copper 110
Clear Acrylic
But need...
Higher strength
Try...
Clear Polycarbonate, Acetal, or UHMW-PE
Stainless Steel 304
But need...
Maximum corrosion resistance (like in salt water environments)
Try...
Stainless Steel 316
Stainless Steel 304
But need...
Lower cost
Try...
Aluminum or one of the metallic appearance acrylics (Brushed Bright Nickel, for example)
Of course, there are a few materials we offer that that don't appear on any of these charts: various kinds of wood, leather, and fabric. If you're considering these, you probably already have a good idea of what you need.
Xometry sheet cutting services
Learn more about Sheet Cutting
