ResourcesSheetCollimated Beam: Definition, How It Works, Applications, and Benefits
Collimated beams in a laboratory.  Image Credit: Shutterstock.com/luchschenF
 15 min read
Rare-Earth Metals: Definition, Properties, Use, and Types
April 12, 2024
 13 min read
A collimated beam is a stream of light particles or other electromagnetic radiation that travel parallel to each other, without spreading out. The beam is focused in a single direction, and the energy is evenly distributed along its path. This unique property makes collimated beams useful in various fields, including scientific research, engineering, and medical applications. In this article, we will delve deeper into the definition of a collimated beam, how it works, and its applications.
What Is a Collimated Beam?
A collimated beam refers to a beam of light or other electromagnetic radiation that is parallel and uniform, with minimal divergence or spreading as they travel. In simpler terms, it is a beam of light that maintains its size and shape over long distances. The term "collimated" comes from the word "collimate," which means to make a parallel. Collimated beams are often achieved through the use of lenses or mirrors that help align the light rays to travel in parallel. In an ideal scenario, a perfectly collimated beam would not disperse or diverge with distance. However, due to the phenomenon of diffraction, it is not possible to achieve a beam with absolutely no spreading. Nonetheless, collimated beams maintain a high degree of parallelism, making them useful in applications where minimal spreading is desired, such as laser technology, optics,  imaging systems, and scientific research. This type of beam is commonly used in various applications such as laser technology, optics, imaging systems, and scientific research. It also has a few industrial uses as welding, cutting, engraving, or 3D-printing tool.
What Is the Other Term for Collimated Beam?
Other terms that have the same general meaning as “collimated beam” include "parallel beam" or “collimated light.”
What Is the Importance of Collimated Beams in Laser Cutting?
The collimated beam is important in laser cutting because it allows for precise and accurate cutting of materials. When the laser beam is collimated, it can maintain its intensity and focus over longer distances. It can then be focused through a focusing lens, resulting in sharp and well-defined cuts. This enables the laser cutter to produce intricate designs with high-quality finishes.
Furthermore, the collimated beam provides efficiency in the cutting process. By maintaining parallel rays, the laser energy remains concentrated, maximizing the cutting power and allowing for faster cutting speeds. The collimated beam also enables the laser cutter to propagate the beam over longer distances without significant beam spreading or loss of cutting performance. Collimated beams also offer flexibility in terms of adjusting the focal length and spot size, making them compatible with a wide range of materials. This versatility allows for the efficient cutting of various materials, including metals, plastics, fabrics, and composites. For more information, see our What is Laser Cutting Used For guide.
What Is the Purpose of a Collimated Beam?
The purpose of a collimated beam is to deliver a stream of light or other electromagnetic radiation in which all the particles travel in the same direction, parallel to each other, without diverging from their original paths. This is achieved by passing the beam of light through a collimator — a device that helps align and straighten the path of the beam. Collimated beams have several practical applications, including in scientific research, laser technology, medical imaging, and industrial processes like laser cutting and welding.
How Does Collimation Work?
Collimation works by directing light or other radiation through a lens or a set of lenses to make the rays from the source parallel to each other. When the light is collimated, the beam will remain focused over long distances. The collimation process begins with the light source, which emits light rays in various directions. These rays are directed through a collimator lens or a series of lenses, which refract and direct the light so that the rays become parallel.
How Is a Collimated Beam Produced Using a Lens?
A collimated beam can be produced using a lens by placing the light source at the focal point of a convex lens. The light rays emanating from the source are diverging, and the convex lens refracts the light rays into a parallel path. By placing a detector at this point, the light rays will appear to be parallel to each other, creating a collimated beam as shown in Figure 2 below:
Another method is to use a set of lenses, typically called a collimator lens system, to create a collimated beam. The light source is placed at one end of the system, and the lenses are arranged in such a way that they refract and focus the light to make the beam parallel. This method is commonly used in laser diodes, telescopes, and other optical devices that require a collimated beam as shown in Figure 3:
How Is a Collimated Beam Produced in a Laser Cutter?
In a laser cutter, a collimated beam is typically produced by passing the laser beam through a series of lenses or mirrors. These mirrors align and redirect the beam to a point where the beam is parallel and uniform in diameter. The first lens is used to collimate a diverging laser beam and create a parallel beam. This collimated beam is then directed towards the cutting head where it is focused again by another lens or mirror to a small spot size for cutting. This is called a focuser, as shown in Figure 4 below:
The focuser allows for adjustment of the beam's spot size at a specific working distance. It can either shrink or magnify the spot size to achieve the desired beam characteristics for a particular application.
What Are Some Typical Applications of Collimated Beams?
Collimated beams have a wide range of applications, including:
1. Laser Technology
Collimated beams are essential in laser technology, where they are used in laser cutting, welding, drilling, and marking. A collimated laser beam can maintain its beam diameter over long distances, allowing for precise and accurate laser processing. They are fundamental in laser technology, serving multiple critical functions in the generation, manipulation, and application of laser light. Collimated beams are used for: laser beam generation, beam propagation, laser beam manipulation, and optics and beam delivery.
2. Optical Communication
In optical communication, collimated beams are used to transmit data through optical fibers. Optical communication relies on the transmission of information through the use of light signals, typically in the form of laser beams. The collimated beam's ability to maintain its diameter allows for efficient data transmission over long distances without significant signal loss. Collimated beams play a crucial role in optical communication systems, particularly in fiber optic networks. They are used in: fiber optic transmission, fiber optic amplification, free-space optical communication, and optical alignment.
3. Medical Imaging (CT and PET Scans)
Collimated beams play a crucial role in medical imaging, particularly in computed tomography (CT) and positron emission tomography (PET) scans. In CT scans, collimated beams help to produce accurate and detailed images of the human body. In CT imaging, a collimated X-ray beam is used to acquire multiple cross-sectional images (slices) of the body, which are then reconstructed to create a three-dimensional representation. Collimated beams are utilized in CT scans for: consistent radiation, improved spatial resolution, artifact reduction, and dose optimization.
Collimators are an integral part of the PET imaging system. Collimators in PET scanners are used to improve the spatial resolution and sensitivity of the imaging process. Collimators are utilized in PET scans for: sensitivity enhancement, spatial resolution improvement, and background reduction.
4. Astronomy (Telescopes)
Collimated beams are used in astronomy in a variety of ways. Collimated beams are used in the proper functioning of optical systems. Collimation ensures that the light entering the telescope remains focused and does not scatter or diverge before reaching the detector or eyepiece. It helps maintain the quality and sharpness of the image formed by the telescope. Additionally, collimated beams are used for reflective telescopes, refractive telescopes, astronomical imaging, and calibration and alignment of telescopes.
5. Industrial Inspection
Collimated beams are used in industrial inspection systems to inspect the quality of manufactured products. The collimated beam can provide precise and accurate measurements of product dimensions, surface quality, and defects. They are also used for accurate imaging and analysis. Some uses of collimated beams in an industrial inspection are: dimensional measurements of objects or components, non-destructive testing methods, and laser profiling.
6. Spectroscopy
Collimated beams are extensively used in spectroscopy to accurately analyze the interaction of light with matter and obtain valuable information about the properties of substances. Some examples of its uses are: sample illumination, beam alignment, measuring of absorption and transmission properties of samples, and in the studying of emission and fluorescence properties of samples.
7. Microscopy
Collimated beams are used in microscopy to provide a well-focused and stable light source for imaging. By using a collimated beam, microscopes can produce high-resolution images with minimal distortion or aberration. Examples of the uses of collimated beams in microscopy are: illumination, laser scanning microscopy, and optical tweezers.
How Does the Quality of a Collimated Beam Affect the Performance of a Laser Cutter?
The quality of the collimated laser beam plays a significant role in determining the performance of a laser cutter. A high-quality collimated beam has several advantages, including improved cutting speed, precision, and accuracy. A laser beam can be precise (with low variability) but not accurate (if it consistently measures values away from the true value). Conversely, a laser beam can be accurate (with measurements close to the true value) but not precise (if the measurements are widely scattered or inconsistent). Ideally, a laser beam should exhibit both high precision and high accuracy for reliable and meaningful measurements.
A well-collimated beam minimizes the beam divergence, ensuring that the laser ray does not spread out as it travels. This results in a smaller focal spot size, which allows for the precise cutting of materials with high accuracy. Additionally, a well-collimated beam reduces the occurrence of unwanted reflections or refractions, leading to clean cuts and reduced material damage.
How Is a Collimated Beam Used to Achieve Precise Cuts in Laser Cutting?
The collimated laser beam is focused into a small spot on the material to be laser cut, resulting in a very narrow, precise cut. The beam is focused by a lens or a series of lenses to produce a high-intensity spot with a diameter as small as a few micrometers. This high-intensity spot vaporizes or melts the material at the point of contact, allowing for precise cuts.
What is the Role of Collimated Beams in Gas Lasers?
Gas lasers utilize collimated beams by employing specific optical components within the laser system. A collimating lens, typically a converging lens, is used to focus and align the beam, bringing it to a parallel configuration. By meticulously arranging and aligning these optical components, gas lasers can generate and control collimated beams, enabling their use in a wide range of applications such as laser cutting, engraving, scientific research, and telecommunications.
What Function Does the Collimated Beam Serve in Fiber Lasers?
In a fiber laser, the collimated beam is important for transmitting the laser light through the fiber optic cable. The fiber laser works by amplifying the light signal passing through the fiber optic cable, which produces a high-power beam that can be used for cutting, welding, and other applications. The collimated beam is used to keep the light signal focused and aligned as it travels through the fiber optic cable, which ensures that the laser beam remains powerful and precise. Without a collimated beam, the light signal would diverge as it travels through the fiber optic cable, leading to a weaker and less precise laser beam. For more information, see our guide on What is a Fiber Laser.
Is a Collimated Beam Also Used in Laser Welding?
Yes, collimated beams are also used in laser welding. In laser welding, a high-power laser beam is focused onto the workpiece to melt the materials to be joined and create a weld. Collimated beams are used to ensure that the laser beam maintains its focus over a longer distance, which is important for welding applications that require a greater depth of field. This allows for precise and accurate welding with minimal distortion or damage to the surrounding material.
What Are the Benefits of Using Collimated Beams?
There are several benefits of using a collimated beam, including:
  1. Increased Precision: The beam's parallel nature ensures that the energy is concentrated in a small area through the focusing lens, resulting in higher precision and accuracy in devices like laser cutters. The collimator keeps as much of the beam's energy intact by keeping all the energy headed in the same direction until it can reach the focusing lens and be concentrated. It is a way to avoid leaking energy.
  2. Reduced Divergence: The beam maintains its size over longer distances, making it ideal for long-distance applications.
  3. Reduced Energy Loss: The parallel nature of a collimated beam minimizes energy loss as the beam travels. This results in greater energy efficiency and a longer operating life for the laser.
  4. Versatility: Collimated beams can be used in a wide range of applications, including: laser cutting, welding, drilling, and marking, as well as medical, scientific, and industrial applications. Collimated beams can also be used in various laser types, including gas lasers, fiber lasers, and solid-state lasers.
  5. Reduced Beam Distortion: Collimated beams can help reduce beam distortion, which can occur due to atmospheric turbulence or other environmental factors. This results in better beam quality and more reliable results.
What Are the Limitations of Using Collimated Beams?
Here are some limitations of using collimated beams:
  1. Complexity: Generating collimating a beam of electromagnetic radiation can be a complex process that requires precise alignment of optical components, which can make it difficult to implement in certain applications.
  2. Cost: Technology that makes use of collimated beams of electromagnetic energy, whether light, electrons, or x-rays, is sophisticated and expensive. This may limit access to the instruments or equipment in some cases, but in many cases, no better alternative exists, and the advantages of such technology outweigh the costs.
  3. Beam Quality: While collimated beams have high beam quality, it can be difficult to maintain this quality over long distances or when passing through different mediums, which can result in beam degradation.
Are Collimated Beams Susceptible to Diffraction?
Yes, collimated beams are susceptible to diffraction. Diffraction refers to the bending or spreading of waves when they encounter an obstacle or a slit that is comparable in size to their wavelength. Collimated beams, even though they are highly parallel and have minimal divergence, can still experience diffraction when they pass through small apertures or lenses. The amount of diffraction that occurs depends on the wavelength of the radiation and the size of the aperture or lens. Diffraction can cause the beam to spread out and lose its collimation, which can affect its performance.
Are Collimated Beams Affected by Atmospheric Turbulence?
Yes, collimated beams can be affected by atmospheric turbulence. As the beam travels through the atmosphere, it can encounter changes in refractive index caused by variations in temperature, pressure, and humidity. These changes in refractive index cause the beam to bend or scatter, leading to distortion or degradation of the beam's collimation. The effect is refraction or loss of parallelism or collimation. Its cause in this case is atmospheric turbulence.  This can be a significant limiting factor for the range and accuracy of laser systems that rely on collimated beams, such as remote sensing or laser communications. However, there are techniques such as adaptive optics that can be used to mitigate the effects of atmospheric turbulence on collimated beams.
Can Collimated Beams Be Produced With Zero Divergence?
No, collimated beams cannot be produced with zero divergence. The defining characteristic of a collimated beam is that its rays are parallel and do not diverge significantly. If a beam had infinite divergence, it means that the rays would spread out in all directions and no longer remain parallel.
This article presented collimated beams, explained what they are, and discussed its various applications. To learn more about collimated beams, contact a Xometry representative.
