Injection Molding Services for New York
High Quality Injection Molding serving New York | Our skilled engineering team guides you through every step of the molding process.
Your New York Injection Molding Service: Plastic Prototypes and Production Parts
Xometry injection molding is a highly customized service providing on-demand prototype and production molding for New York. We take a customer-first approach which means we find the right injection molding supplier within our manufacturing supplier network to mold the parts the way you need them—without design compromises—at the right price point. We offer expert consultation on each injection mold quote and project managers on every order to move your parts from design to production. Our team has experience across industries, including medical, automotive, aerospace, consumer goods, and more. First-time buyers receive $500 off their first mold with Xometry.
- Improve reliability: Metal inserts will assure the function of threads and mitigate wear and tear over the part’s life.
