CapabilitiesTube Bending ServicesAmerican Samoa
Tube Bending Services for American Samoa
High Quality American Samoa Tube Bending and tube fabrication services for metallic pipe and tube stock to meet your needs.
Massive Network Capacity
Quality assurance
Your American Samoa Tube Bending Service
Our project managers and experts personally review and manually quote each tube bending project to ensure we meet your unique needs while providing a fast and easy manufacturing experience.  Review our capabilities in the sections below to learn more about the different tube bending machines and techniques.
Tube Bending Capabilities in American Samoa
  • Roll Tube Bending
  • Rotary Draw Tube Bending
  • Mandrel Tube Bending
  • Compression Bending
Compression Bending With compression bending, the tube or pipe is clamped in place, and force is directly applied, which creates the bend. This process is primarily utilized for single bend applications. No internal support is used with compression bending, which typically produces an oval cross-section and may result in crushing of the bend. Bends generally are limited to angles of 120 degrees or less.
Material Options
American Samoa Tube Bending Material Options
Tube and Pipe Materials
MaterialRound TubePipeRectangular TubeSquare Tube
Material
Round Tube
  • Aluminum 6061
  • Aluminum 6063
  • Aluminum 2024
Pipe
  • Aluminum 6061
  • Aluminum 6063
  • Aluminum 6101
Rectangular Tube
  • Aluminum 6061
  • Aluminum 6063
Square Tube
  • Aluminum 6061 *
  • Aluminum 6063 *
Material
Steel
Round Tube
  • Alloy Steel 4130
  • Cold Roll Steel A513
Pipe
  • Mild Steel A500
Rectangular Tube
  • Mild Steel A500
  • Mild Steel A513
Square Tube
  • Mild Steel A500
  • Mild Steel A513
Material
Stainless Steel Tubes
Round Tube
  • Stainless Steel 304
  • Stainless Steel 316
Pipe
Rectangular Tube
Square Tube
Material
Brass
Round Tube
  • General Purpose Brass Tubing**
Pipe
  • Brass 230
Rectangular Tube
  • Brass 272
  • Brass 385
Square Tube
  • Brass 272
  • Brass 385
Material
Copper
Round Tube
  • Copper 101
  • Copper 122
Pipe
Rectangular Tube
Square Tube
Material
Titanium
Round Tube
  • Titanium Grade 2
Pipe
Rectangular Tube
Square Tube
tube bending near American Samoa
Ready to start your tube bending quote?
