Tungsten CNC Machining Service
Tungsten CNC Machined prototypes and production parts in days | AS9100D | ISO 9001:2015 | ISO 13485 | IATF 16949:2016 | ITAR Registered | Free standard shipping on all US orders
Tungsten CNC machining service turns pure tungsten, tungsten heavy alloys, and copper tungsten into dense, heat resistant parts (radiation shields, counterweights, and electrodes). Tungsten CNC machining service providers face a difficult metal, since pure tungsten stays hard and brittle at room temperature and chips under cutting forces. Edges crack under sudden loads, and hard grains wear carbide cutting edges quickly. Heavy alloys behave better, since nickel binders add ductility and form continuous chips.
Computer numerical control (CNC) milling, turning, and drilling suit heavy alloys, and precision grinding and electrical discharge machining (EDM) suit pure tungsten and fine features. Sourcing starts with a drawing, material grade, quantity, and tolerance list sent to a supplier experienced in refractory metals. Xometry accepts tungsten requests through CNC machining, under the “Other” material option. A manufacturing expert reviews each quote before production.
Ready to start an tungsten CNC project?
What is Tungsten CNC Machining?
Tungsten CNC machining is the computer controlled cutting, drilling, milling, or turning of tungsten to produce precise components. Tungsten (W) has a density of 19.3 g/cm³ and a melting point of 3,422°C (6,192°F), the highest of any metal. High density, hardness, and brittleness demand specialized tooling (sharp carbide inserts and diamond grinding wheels) and conservative machining parameters. Programmed toolpaths repeat each operation, producing identical parts across a production run. Tungsten heavy alloys add nickel and iron or copper binders, lowering density to 17.0 to 18.5 g/cm³ and improving machinability. Tungsten metal differs from tungsten carbide, a cobalt bonded ceramic metal composite used in cutting tools. Aerospace manufacturers order balance weights and ballast, and medical device makers order collimators and radiation shields. Electronics companies machine copper tungsten heat sinks and contacts, and industrial users machine EDM electrodes and boring bars. Each application sets the grade, process route, and inspection plan before cutting starts. Shops run tungsten jobs on the same mills, lathes, and inspection equipment used in standard CNC Machining Services.
How Is Tungsten Used in Precision Machined Parts?
Tungsten is used in precision machined parts that require high density, heat resistance, or wear resistance. Radiation shielding blocks and collimators rely on a high atomic number (74) to stop X rays and gamma rays in thin walls. Counterweights in aircraft control surfaces, helicopter rotors, and racing cars pack about 2.2 times the mass of equal steel volumes. Electrical contacts and EDM electrodes use copper tungsten, combining arc erosion resistance and conductivity. High temperature components (furnace heating elements, crucibles, and heat shields) use pure tungsten above 1,450°C, where heavy alloy binders melt. The application tdecides the tungsten grade, and the grade decides the machining method. Shielding parts in tungsten nickel copper (WNiCu) heavy alloy mill on standard equipment, and pure tungsten furnace parts need grinding or EDM. Required tolerances follow function, from loose ballast weights to collimator apertures held within microns.
What Makes Tungsten Difficult to Machine?
Tungsten is difficult to machine because of high hardness, high density, brittleness, and a high melting point. Conventional cutting causes rapid tool wear, concentrated heat at the cutting edge, and edge chipping. Hard tungsten grains abrade carbide inserts, shortening tool life compared to steel or aluminum jobs. Friction at the tool tip raises local temperatures, even though tungsten conducts heat at 173 W/m·K. Brittle edges break away when a tool enters or exits the cut, leaving chips on corners and hole entries. Dense blanks add inertia, so heavy workpieces load fixtures during fast axis moves. Manufacturers select tools, cutting conditions, and machining methods to hold accuracy and limit defects. Sharp positive rake carbide, light finishing passes, rigid setups, and grinding or EDM on critical features keep scrap rates low.
How Hard is Tungsten?
Tungsten is a very hard, dense metal, but hardness varies with purity, processing, and alloy composition. Pure tungsten measures near 350 HV to 450 HV in Vickers hardness, and worked rod and wire reach higher values. Tungsten heavy alloys under ASTM B777 measure about 24 HRC to 35 HRC, rising from Class 1 to Class 4. Tungsten carbide reaches 1,600 HV to 2,200 HV, which places it in a separate material class. Hardness alone fails to predict machinability, since pure tungsten fractures and heavy alloy shears across overlapping hardness ranges. Ductility, binder content, and grain structure decide how the metal responds to a cutting edge. Material certificates report hardness, density, and composition per lot. Grade specific data from the certificate guides tool selection, cutting speed, and depth of cut.
Which Tungsten Grades Are Best for CNC Machining?
The best tungsten grade depends on the part application, required density, mechanical properties, and manufacturing method. Pure tungsten (99.95% W) suits high temperature and electrical applications (heating elements, sputtering targets, and electron emitters). Tungsten heavy alloys suit dense, machinable components, since a nickel binder adds ductility. ASTM B777 sorts heavy alloys into Class 1 to Class 4, from 90% to 97% tungsten and 17.0 to 18.5 g/cm³. Tungsten nickel iron (WNiFe) grades offer the highest strength, and WNiCu grades stay nonmagnetic near magnetic resonance imaging (MRI) equipment. Copper tungsten (CuW) trades density to gain conductivity in EDM electrodes and heat sinks. Composition, strength, ductility, machinability, and availability guide the final selection. Heavy alloy plate and bar ship in common sizes, and pure tungsten blanks above standard press sizes need custom sintering.
What Are Tungsten Heavy Alloys Used for in Machined Parts?
Tungsten heavy alloys are used in machined parts that need high mass, radiation attenuation, or stiffness in a compact envelope. The alloys combine 90% to 97% tungsten and a nickel iron or nickel copper binder. Blending tungsten and binder metals into one material fits the standard Alloy Definition.
The uses of tungsten heavy alloys in machined parts are listed below.
- Counterweights: Heavy alloy counterweights add substantial mass within a compact space. Crankshafts, flywheels, and satellite ballast use machined weights to shift the center of gravity.
- Radiation Shielding: Heavy alloy shields attenuate X rays and gamma radiation in walls about 30% to 40% thinner than lead. Syringe shields, isotope containers, and radiotherapy collimators rely on the material.
- Vibration Control: Heavy alloy provides mass and stiffness in balancing and vibration damping parts. An elastic modulus of 310 GPa to 380 GPa, against 200 GPa in steel, damps chatter in boring bars and tool holders.
- Aerospace Components: Heavy alloy supports compact weighting and inertial applications. Gyroscope rotors, flight control balance weights, and center of gravity ballast use the alloy.
What Factors Determine the Machinability of Pure Tungsten and Tungsten Heavy Alloys?
The factors that determine the machinability of pure tungsten and tungsten heavy alloys are composition, hardness, microstructure, tooling, cutting parameters, and workholding. Each factor shifts tool life, surface finish, and scrap risk. Heavy alloys tolerate wider parameter windows than pure tungsten.
The factors that determine machinability are listed below.
- Composition: Binder content controls ductility and cutting behavior. A 90% tungsten Class 1 alloy cuts cleaner than a 97% tungsten Class 4 alloy.
- Hardness and Brittleness: Hard, brittle grades raise cutting forces and the risk of chipping or cracking. Pure tungsten below its transition temperature cracks at tool entry and exit.
- Microstructure: Grain size and processing route shape machining consistency. Swaged and rolled stock carries elongated grains that delaminate across the grain direction.
- Tooling: Tool material and geometry govern wear and cutting performance. Fine grain carbide and diamond wheels hold edges longest on tungsten.
- Cutting Parameters: Speed, feed rate, and depth of cut control heat and surface quality. Steady chip loads prevent rubbing, which accelerates edge wear.
- Workholding: Stable fixturing reduces vibration and damage during machining. Soft jaws and full support under thin sections stop clamping cracks.
What Machining Methods Work Best for Tungsten?
The machining methods that work best for tungsten are CNC milling, CNC turning, precision grinding, EDM, and drilling. Heavy alloys suit chip forming methods on standard machines. Pure tungsten and fine features suit abrasive and thermal methods that avoid impact loads.
The machining methods that work best for tungsten are listed below.
- CNC Milling: CNC milling cuts heavy alloy plate into shielding blocks and collimator bodies.
- CNC Turning: CNC turning shapes heavy alloy bar into pins, rods, and counterweights.
- Precision Grinding: Precision grinding finishes pure tungsten and critical heavy alloy surfaces.
- Electrical Discharge Machining (EDM): EDM cuts slots, apertures, and cavities without contact forces.
- Drilling: Drilling forms holes in heavy alloy through carbide drills and peck cycles.
1. CNC Milling
CNC milling is a subtractive process that produces pockets, slots, and complex external features through rotating cutters on 3 axis and 5 axis machines. Heavy alloy plate mills cleanly, since the nickel binder forms continuous chips instead of fractured fragments. Sharp fine grain carbide end mills, moderate spindle speeds, and steady feeds hold edge quality on shielding blocks and collimator bodies. Climb milling and light finishing passes reduce exit burrs and edge chipping. Pure tungsten mills poorly, so shops limit milling to roughing before grinding or EDM. Rigid fixturing and constant tool engagement keep accuracy stable in tungsten CNC Milling.
2. CNC Turning
CNC turning is a lathe process that creates cylindrical parts and rotational features by rotating the workpiece against a fixed cutting tool. Heavy alloy bar turns into pins, rods, bushings, counterweights, and boring bar blanks. Positive rake carbide inserts and honed edges cut the alloy at speeds close to hardened steel. Live tooling adds flats, cross holes, and threads in the same setup, reducing handling of dense parts. Interrupted cuts chip pure tungsten, so turned pure tungsten parts get finish ground. Concentric diameters, shoulders, and grooves on round tungsten parts come from CNC Turning.
3. Precision Grinding
Precision grinding is an abrasive process that achieves accurate dimensions and fine surface finishes through rotating diamond or cubic boron nitride (CBN) wheels. Each pass removes a few microns of material, avoiding the impact loads that crack pure tungsten. Surface grinding flattens plates, and cylindrical grinding finishes pins and rods. Ground features hold the tightest tolerances on tungsten parts. Flood coolant controls wheel loading and surface heat. Pure tungsten furnace parts, sputtering targets, and sealing faces reach final size through Precision Grinding.
4. Electrical Discharge Machining (EDM)
EDM is a thermal process that produces intricate features in electrically conductive tungsten materials through controlled electrical sparks. Wire EDM cuts slots, apertures, and profiles, and sinker EDM forms blind cavities from a shaped electrode. No cutting force touches the workpiece, so brittle pure tungsten keeps sharp internal corners and thin ribs intact. Material removal runs slower than milling, so EDM fits features beyond the reach of milling cutters. Collimator slits, apertures, and complex pure tungsten profiles come from Electrical Discharge Machining (EDM).
5. Drilling
Drilling is a cutting process that creates holes through suitable tools and carefully controlled cutting conditions. Solid carbide drills at low feed rates produce holes in heavy alloy parts. Peck cycles clear chips and limit heat at the drill tip. Through tool coolant protects drill margins on deep holes. Exit chipping occurs at breakthrough, so backup plates or reduced exit feeds protect the hole edge. Thread milling replaces tapping in heavy alloy, since taps wear fast in the hard material. Mounting holes, dowel holes, and fastener patterns in shielding assemblies come from Drilling.
How to Cut Tungsten?
Tungsten is cut by matching the process to the grade and geometry, then controlling fixturing, tooling, and parameters. Heavy alloy cuts on saws, mills, and lathes, and pure tungsten favors abrasive cutoff wheels, grinding, and wire EDM. Inspection after each cut stops cracks from spreading into finished features.
The steps to cut tungsten are listed below.
- Select the Method. Sawing, machining, grinding, and EDM each fit a different grade and cut geometry. Wire EDM suits pure tungsten profiles, and carbide tipped band saws suit heavy alloy blanks.
- Secure the Workpiece. Stable fixturing minimizes vibration and movement during the cut. Soft jaws and full support under the cut line prevent clamping cracks.
- Choose Suitable Tooling. Tools matched to the hardness and brittleness of the grade cut cleanly. Fine grain carbide, diamond wheels, and brass EDM wire cover the common tungsten jobs.
- Control Cutting Parameters. Grade specific speed, feed, and depth of cut recommendations limit heat and edge damage. Light finishing passes reduce exit chipping on pure tungsten.
- Inspect the Cut. Dimensions, surface condition, and signs of cracking or chipping get checked after cutting. Dye penetrant testing reveals fine cracks along pure tungsten edges.
What Are Design Guidelines for Machined Tungsten Parts?
The guidelines for machined tungsten parts are geometry rules that limit cracking, tool wear, and machining time. Brittle edges and slow cutting turn small geometry choices into large cost and lead time differences. Heavy alloy parts tolerate tighter geometry than pure tungsten parts.
The guidelines for machined tungsten parts are listed below.
- Wall Thickness: Thin walls crack or deform under cutting forces. Wall height kept below 10 times wall thickness limits chatter on unsupported features.
- Corner Radii: Practical internal radii replace sharp corners where function allows. Radii slightly larger than the cutter radius reduce chatter, and edge chamfers prevent chipping.
- Hole Design: Hole diameters and depths sized to standard drills avoid custom tooling. Depths within 4 times the diameter suit standard drilling, and deeper holes need peck cycles or EDM.
- Tolerances: Tight tolerances belong on functional features, and standard tolerances fit the rest of the part. Each tight callout adds grinding passes and inspection time.
- Part Geometry: Simple geometry reduces machining time and setups. Large parts split into bolted plates shorten sourcing time on oversize blanks.
- Material Selection: Pure tungsten or a heavy alloy follows performance and manufacturability needs. Heavy alloy fits shielding and weighting parts, and pure tungsten fits parts above 1,450°C.
What Tolerances and Finishes Can Tungsten Parts Achieve?
Tungsten parts can achieve precise dimensions and a range of surface finishes, depending on the material grade and manufacturing process. Milled and turned heavy alloy holds a standard ±0.005 in, and critical features reach sub ±0.001″, per drawing and GD&T callouts. Grinding and EDM support demanding features, and conventional CNC operations suit less specialized geometries. Part size, geometry, and inspection requirements shape the final values. Achievable tolerances and finishes get confirmed by the manufacturer before production.
Which Finishes Are Suitable for Tungsten Components?
The finishes suitable for tungsten components are machined, ground, polished, EDM, and protective coating finishes. Finish choice follows function, appearance, and dimensional limits. Tungsten resists oxidation at room temperature, so finishes focus on texture and on protecting heavy alloy binders against corrosion.
The finishes suitable for tungsten components are listed below.
- As-Machined: Machined surfaces keep tool marks near 1.6 µm to 3.2 µm Ra. The finish suits internal shielding and ballast parts.
- Ground Finish: Grinding improves dimensional control and surface quality to near 0.4 µm Ra. Ground faces suit sealing surfaces and precision fits.
- Polished Finish: Polishing reduces roughness below 0.2 µm Ra where smoother surfaces are required. Sputtering targets and medical components use polished faces.
- EDM Finish: EDM supports intricate geometries, and surface texture depends on spark energy settings. Skim passes reduce the recast layer and roughness.
- Protective Coatings: Nickel plating improves corrosion resistance on heavy alloy surfaces. Coatings need compatibility checks against the service environment.
How Much Does Tungsten CNC Machining Cost?
Tungsten CNC machining costs vary by material grade, part complexity, production volume, and required precision. Tungsten raw material costs far above steel or aluminum, and suppliers sell blanks by weight. Dense blanks raise material cost per part before cutting starts. Slow cutting, short tool life, and grinding or EDM steps add machine hours over common metals. A reliable estimate accounts for raw material, machining time, tooling, finishing, inspection, and delivery requirements. Pure tungsten parts cost above heavy alloy parts of the same geometry, since grinding and EDM replace faster milling. Exact pricing comes from a custom quote, since tungsten requires manual review.
How Can You Source Custom Tungsten Machining Services?
You can source custom tungsten machining services by defining requirements, evaluating supplier expertise, checking capabilities, requesting quotes, and verifying quality. Tungsten narrows the supplier pool, since few shops stock refractory metals and run grinding and EDM equipment. A structured sourcing process cuts quote rounds and production surprises.
The steps to source custom tungsten machining services are listed below.
- Define Requirements. Technical drawings, material grades, quantities, and tolerances form the request package. ASTM B777 class callouts remove grade ambiguity on heavy alloy parts.
- Evaluate Expertise. Supplier experience machining pure tungsten or tungsten heavy alloys predicts yield and scrap. Past tungsten work (shielding, collimators, or counterweights) signals process knowledge.
- Check Capabilities. CNC machining, grinding, EDM, finishing, and inspection capabilities get confirmed against the part features. Missing grinding or EDM capacity forces subcontracting and adds lead time.
- Request Quotes. Quotes compare pricing, lead times, tooling requirements, and material availability. Itemized quotes separate material, machining, finishing, and inspection costs.
- Verify Quality. Quality systems, material certifications, and inspection reports confirm conformance. International Organization for Standardization (ISO) 9001 certification and CMM reports document process control.
Where Can We Source Custom Tungsten Machining?
Custom tungsten machining can be sourced from specialized CNC manufacturers, precision grinding companies, and advanced machining suppliers that handle refractory metals. The right supplier shows proven work on the required tungsten grade, component geometry, and tolerances. Heavy alloy shielding fits shops running standard mills and lathes, and pure tungsten parts need grinding and EDM specialists. Qualified suppliers compete on technical capability, material sourcing, quality documentation, lead time, and total cost. Material sourcing matters, since heavy alloy plate and pure tungsten blanks come from a small group of powder metallurgy producers. Manufacturing marketplaces route each job to a vetted shop holding the right equipment and alloy experience. Xometry quotes tungsten manually after buyers select CNC machining, choose "Other" under materials, and name the alloy. A partner network experienced in critical tungsten components handles production through Xometry.
What Is the Typical Lead Time of Tungsten Machining?
Tungsten machining lead time runs from 1 to 2 weeks for heavy alloy parts cut from stocked material. Pure tungsten parts needing grinding or EDM take longer, and so do parts needing oversize sintered blanks. Expedited options shorten delivery when material sits in stock.
Should a Large Tungsten Part Be Redesigned as Bolted Plates to Shorten Lead Time?
Yes, a large tungsten part should be redesigned as bolted plates to shorten lead time when the assembly meets the structural and functional requirements of the component. Smaller plates come from standard stock, skipping the custom pressing and sintering runs of oversize blanks. Plates fit standard machines, shorten roughing cycles, and pass through inspection on standard CMMs. Handling gets safer, since a 300 mm cube of heavy alloy weighs about 470 kg. Joint strength depends on fastener size, thread engagement, and plate thickness. Shielding assemblies need stepped or overlapping joints, since straight seams leave radiation leak paths. Fastener holes remove shielding mass, so heavy alloy screws or plugs restore attenuation. Dowel pins hold alignment, and flatness callouts on each plate control stacked assembly tolerances. Steel fasteners expand about 2.5 times faster than heavy alloy plates, loosening joints under thermal cycling. Joint strength, alignment, fastener compatibility, thermal behavior, and assembly tolerances get evaluated before the part changes.
Why Choose Xometry for Tungsten CNC Machining Services?
Frequently Asked Questions About Tungsten CNC Machining Services
How Much Does It Cost to Machine Tungsten Parts?
The cost of machining tungsten parts depends on the material, dimensions, machining method, and order quantity. Small, complex, tight tolerance parts carry a higher unit cost than simple parts produced in larger batches. Setup, programming, and first article inspection spread across the batch, so unit cost falls as quantity rises. Standard stock sizes cut material waste on an expensive metal. Heavy alloy in place of pure tungsten lowers machining hours when the application allows. A quotation request includes a technical drawing, material specification, quantity, tolerance requirements, and desired finish. Complete inputs return accurate pricing and lead time on the first quote.
What Tolerances Can Machined Tungsten Parts Hold?
Machined tungsten parts can hold tolerances set by grade, feature geometry, dimensions, and machining process. Heavy alloy cuts predictably, so milled features hold tighter values than brittle pure tungsten features. Precision grinding and specialized machining achieve tighter tolerances than general cutting operations. Thin walls, long features, and edges in chipping zones limit tolerance in pure tungsten. Tool wear shifts dimensions across long runs, so shops measure parts and offset tools during production. Engineering drawings specify critical dimensions, datum references, and geometric tolerances (flatness, position, and parallelism). Inspection requirements (coordinate measuring machine (CMM) reports or first article inspection) belong on the drawing. Suppliers confirm feasibility during quoting, before material gets ordered.
Tungsten is a very hard, dense metal, but hardness varies with purity, processing, and alloy composition. Pure tungsten measures near 350 HV to 450 HV in Vickers hardness, and worked rod and wire reach higher values. Tungsten-heavy alloys under ASTM B777 measure about 24-35 HRC, increasing from Class 1 to Class 4. Tungsten carbide reaches 1,600 HV to 2,200 HV, which places it in a separate material class. Hardness alone fails to predict machinability, since pure tungsten fractures and heavy alloy shears across overlapping hardness ranges. Ductility, binder content, and grain structure decide how the metal responds to a cutting edge. Material certificates report hardness, density, and composition per lot. Grade specific data from the certificate guides tool selection, cutting speed, and depth of cut.
Why is Tungsten Difficult to Machine?
Tungsten is difficult to machine because its mechanical properties resist material removal, and pure tungsten and brittle grades pose the toughest challenge. Pure tungsten sits below a ductile to brittle transition near 200°C to 400°C, so room temperature cuts fracture the metal instead of shearing it. Powder metallurgy leaves a layered grain structure that splits along grain boundaries under cutting loads. High cutting forces deflect thin features, and localized heat at the tool tip softens cutting edges. Sudden mechanical stress (interrupted cuts, tool chatter, or hard clamping) cracks brittle workpieces and chips tools. Honed edges and positive rake angles reduce cutting forces on entry and exit. Stable fixturing in soft jaws spreads clamping loads and damps vibration. Controlled feeds, steady chip loads, and flood coolant improve surface quality and dimensional accuracy.
Can Tungsten Be Machined to Fine Features?
Yes, tungsten can be machined to fine features through suitable tooling, controlled cutting parameters, and specialized processes. Small holes below 1 mm in diameter shift from drilling to EDM drilling or laser drilling. Narrow slots and sharp internal corners come from wire EDM, where corner radii track the wire diameter near 0.1 mm. Precise contours and thin ribs in pure tungsten come from precision grinding, which removes material in thin layers without impact loads. Pinholes from 10 µm to 50 µm in thin collimator sheet come from laser drilling, since short pulses vaporize the metal before heat spreads. Feature size depends on the material grade, part geometry, tooling, and the risk of cracking or chipping. Heavy alloy walls hold near 0.5 mm, and pure tungsten walls need about 1 mm to resist breakage. Feature limits get confirmed by the supplier before drawings are finalized.
