Silicone Compression Molding
Written byMegan Conniff
19 min read
Published November 26, 2026
Silicone Compression Molding. Image credit: Shutterstock/thanannopthanoch thongmam
Silicone compression molding is a manufacturing process that shapes solid silicone stock inside a heated mold under controlled pressure. The process cures a measured silicone charge into a flexible component designed to meet specific dimensional and performance requirements. Manufacturers use the method to produce gaskets, seals, diaphragms, keypads, and custom silicone parts. Material selection influences heat resistance, flexibility, chemical stability, and compression recovery. High consistency rubber (HCR) is a common material choice because its solid consistency supports preform preparation and cavity loading. Platinum-cured and peroxide-cured formulations provide different cleanliness and processing characteristics. Mold design, curing conditions, and post-curing requirements influence finished part quality. The manufacturing process also involves precision tooling, venting, dimensional inspection, and defect control. Medical, food-contact, automotive, and electrical applications require additional attention to material specifications and applicable standards. The following sections explain silicone grades, process steps, tooling options, performance properties, common products, and supplier selection criteria.
What Is Silicone Compression Molding?
Silicone compression molding presses solid silicone stock into a heated mold cavity until the material cures into a flexible, heat-resistant component. Manufacturers prepare a measured silicone charge and position it inside the mold before applying pressure. Heat activates the curing system and allows the material to develop its final elastomeric properties. The closed mold determines the component's shape, dimensions, and surface details. Controlled pressure helps distribute the silicone throughout the cavity. Venting features release trapped air and excess gases during compression. The process suits gaskets, seals, and components requiring consistent material properties. Silicone's flexibility and temperature resistance support applications across medical, automotive, electrical, and consumer product industries. Material grade, cavity design, and cure conditions determine the finished component's performance.
When Is Silicone Compression Molding a Better Choice Than Prototype Injection Molding for Low-Quantity Parts?
Silicone compression molding is a practical choice when low-quantity projects require simple tooling and limited initial investment. The process uses a measured silicone preform placed directly inside the mold cavity. Prototype injection molding requires equipment that delivers material through an injection system. Compression tooling generally has a simpler construction, which helps reduce initial tooling expenses. Short production runs also benefit from less complex machine setup. Injection molding offers controlled material delivery and repeatable cavity filling, although equipment and tooling costs are higher. Compression molding produces less runner-related waste because material enters the cavity directly. Actual waste depends on preform accuracy, flash formation, and mold design. Manufacturers compare order quantity, part geometry, lead time, and material requirements before selecting a process, including prototype injection molding.
Is Silicone Compression Molding Practical for High-Volume Production?
No, silicone compression molding is generally better suited to low- and medium-volume production than very high-volume manufacturing. Manual preform loading increases operator involvement during each cycle. Curing time also affects production output, particularly when thick components require longer heating periods. Automated loading systems reduce handling time but increase equipment investment. Injection molding offers faster automated material delivery for suitable high-volume applications. Compression molding remains practical when component geometry, material requirements, or tooling costs favor the process. Production planning must account for cavity count, cure time, and available press capacity.
What Silicone Materials Are Used in Compression Molding?
Silicone compression molding uses different elastomer grades and curing systems according to application requirements. High consistency rubber is a common choice because its solid form supports preform preparation and mold loading. Silicone compounds vary in hardness, tensile strength, tear resistance, and elongation. Platinum-cured and peroxide-cured systems provide distinct curing characteristics. Some formulations meet specific requirements for food contact, medical use, or electrical insulation. Material selection depends on operating temperature, chemical exposure, flexibility, and expected service life. Pigments and additives modify appearance or selected performance characteristics. Manufacturers review technical data sheets before approving a silicone grade. Proper material selection helps ensure that molded parts meet their intended application requirements.
What Is High Consistency Rubber and Why Is It Used for Compression Molding?
High consistency rubber (HCR) is a solid, putty-like silicone material used in compression molding and other elastomer manufacturing processes. Its consistency allows manufacturers to prepare measured preforms before loading a mold. HCR compounds are available across a broad range of Shore A hardness levels. Material hardness influences flexibility, sealing force, and resistance to deformation. Solid stock supports the production of thick sections and larger molded components. Operators cut or weigh the required charge according to cavity volume and part specifications. Proper preform sizing helps reduce excess flash and incomplete cavity filling. HCR is suitable for gaskets, seals, electrical components, and industrial rubber products.
What Is the Difference Between Platinum-Cured and Peroxide-Cured Silicone?
Platinum-cured silicone uses a platinum-based catalyst to initiate crosslinking, whereas peroxide-cured silicone relies on an organic peroxide curing agent. Platinum-cured compounds generally provide low volatile residue and good cleanliness. The curing system is suitable for applications requiring controlled extractables and minimal odor. Peroxide-cured silicone releases reaction byproducts during curing. Post-curing helps remove residual volatile substances from peroxide-cured components. Platinum-cured materials generally cost more than comparable peroxide-cured formulations. Food-contact and medical applications require verification against the relevant material and regulatory requirements. The selected cure system influences processing conditions, cleanliness, and final material properties.
Can Compression Molded Silicone Be Made in Custom Colors?
Yes, compression molded silicone is available in custom colors through the addition of compatible pigments. Manufacturers mix color concentrates into the silicone stock before preform preparation. Pigment selection influences color consistency and material compatibility. Custom color matching relies on approved references and controlled mixing procedures. Medical applications require pigments that meet the relevant material safety requirements. Food-contact components need colorants suitable for the intended contact conditions. Production samples help confirm the finished color before larger batches begin. Pigment concentration must remain within the compound manufacturer's recommended limits.
How Is Silicone Compression Molded Step by Step?
Silicone compression molding follows a controlled sequence of preform preparation, mold loading, press closure, curing, and demolding. Each stage influences the finished component's dimensions, surface quality, and mechanical properties. Manufacturers prepare solid silicone stock according to the required cavity volume. The measured charge enters the mold before the press closes. Heated platens transfer thermal energy through the mold during curing. Pressure distributes the silicone across the cavity and supports accurate part formation. Temperature and cure time depend on the selected compound and component thickness. Venting releases trapped air and reduces the risk of incomplete filling. Proper demolding and flash removal prepare the part for inspection and finishing.
What Are the Steps in the Silicone Compression Molding Process?
The silicone compression molding process works by following a sequence of material preparation, mold loading, curing, and finishing steps. First, manufacturers measure and prepare the silicone preform according to the mold cavity volume and material specifications. Second, the operator places the preform inside the open mold cavity, positioning the material to support even distribution. Third, the press closes the mold and applies controlled pressure through the heated platens. Fourth, heat activates the silicone curing system, allowing the material to crosslink inside the cavity. Fifth, mold vents release trapped air and gases during compression, reducing the risk of voids. Sixth, the operator opens the press after the specified cure cycle and removes the molded component. Lastly, excess flash is trimmed before the component undergoes visual inspection and dimensional verification.
What Is Post-curing and Why Do Silicone Parts Need It?
Post-curing is an additional heating stage that helps remove volatile substances and stabilize selected silicone properties after molding. Manufacturers place molded components inside a controlled oven for a specified period. The process is particularly relevant to certain peroxide-cured silicone compounds. Residual curing byproducts and volatile substances can affect odor and extractables. Post-curing helps reduce these substances and improve material stability. The treatment can also influence compression set and other physical properties. Medical and food-contact applications may require post-curing according to material specifications or regulatory expectations. Required temperature and duration depend on the silicone grade and component design. Manufacturers follow validated processing instructions to avoid thermal damage or unwanted property changes.
Can Silicone Parts Be Compression Molded Without a Mold Release Agent?
Yes, silicone parts can often be compression molded without an added mold release agent. Silicone generally releases from polished steel surfaces when mold design and processing conditions are suitable. Cavity finish influences friction and part removal. Mold coatings can further support release during repeated production cycles. Deep cavities and complex geometries create additional demolding challenges. Certain silicone formulations also have different release characteristics. Manufacturers assess the mold surface, part geometry, and compound behavior before selecting a release method. A trial run helps determine whether an external release agent is necessary.
What Tooling Is Used for Silicone Compression Molding?
Silicone compression molding uses a precision mold, heated platens, and supporting fixtures to shape and cure the material. The mold contains the cavity that determines the finished component's geometry. Heated platens transfer heat into the mold during the curing cycle. Hydraulic presses supply the force required to close the tooling. Mold alignment features help maintain accurate closure across the parting line. Venting channels allow trapped air and gases to escape during compression. Surface finish influences part appearance and release behavior. Supporting fixtures help organize preforms and molded components during production. Tooling design affects flash control, dimensional accuracy, and repeatability.
How Is a Silicone Compression Mold Cavity Cut Through Wire EDM?
Wire electrical discharge machining (EDM) cuts precise profiles into conductive mold materials through controlled electrical discharges. The process uses a thin wire electrode to remove material from hardened tool steel. Wire EDM supports intricate internal profiles and narrow features that are difficult to machine through conventional cutting methods. Mold makers use the process to produce detailed cavity sections and accurate parting-line features. Controlled cutting parameters help achieve tight dimensional tolerances. Surface finish depends on the selected machining settings and finishing requirements. Accurate cavity geometry supports consistent molded part dimensions. Manufacturers combine wire EDM with milling, grinding, and polishing to complete the mold.
How Do Sheet Metal Fabrication Fixtures Such As Preform Trays and Deflashing Guards Support a Silicone Molding Line?
Sheet metal fabrication fixtures support silicone molding operations by organizing materials, improving handling, and protecting operators. Preform trays keep measured silicone charges separated before mold loading. Storage racks organize tooling accessories and finished components. Deflashing guards help contain trimming debris and reduce exposure to sharp tools. Fabricated fixtures can be designed around the dimensions and workflow of a specific production line. Cutting operations create the required sheet profiles. Bending and forming produce trays, brackets, covers, and protective guards. Proper fixture design supports orderly handling and consistent production routines through sheet metal fabrication.
Can Metal 3D Printing Make Mold Inserts for Short Silicone Production Runs?
Yes, metal 3D printing can produce mold inserts for selected short-run silicone molding applications. Additive manufacturing builds metal features layer by layer from a digital design. The process supports internal channels and complex geometries that require extensive conventional machining. Printed inserts can reduce tooling development time for certain designs. Surface roughness may require machining or polishing before production use. Dimensional accuracy depends on the printing process, material, and post-processing method. Wear resistance and service life also depend on the selected metal and operating conditions. Manufacturers evaluate insert tolerances, finish, and durability before using printed tooling.
What Properties Make Silicone Suitable for Seals and Gaskets?
Silicone suits seals and gaskets because it combines flexibility, temperature resistance, and good environmental stability. The material retains useful elastomeric properties across a broad operating temperature range. Low-temperature flexibility helps seals maintain contact during cold conditions. Compression set indicates how well silicone recovers after prolonged compression. Good weathering resistance supports outdoor applications. Silicone also offers resistance to ozone and ultraviolet exposure. Material hardness influences sealing force and contact pressure. Compound selection depends on chemical exposure and operating conditions. Manufacturers assess the complete service environment before specifying a silicone grade.
What Temperature Range and Durometer Can Silicone Parts Achieve?
Silicone parts support a broad service temperature range, although the exact limits depend on the selected compound. Many general-purpose silicone grades operate across ranges near -50°C to 200°C. Specialized formulations provide different temperature capabilities according to their composition. Shore A hardness commonly ranges from very soft grades near 10A to harder compounds above 70A. Softer silicone supports flexible seals and cushioning applications. Harder grades provide greater resistance to deformation under load. Durometer influences the force required to compress a seal against its mating surface. Designers select hardness according to sealing pressure, geometry, and expected movement. Material data sheets provide the appropriate operating limits for each grade.
What Standards Apply to Medical and Food-Grade Silicone Molding?
Medical and food-grade silicone molding involves material requirements and testing standards that address safety, biological response, or food-contact suitability. Each standard covers a different aspect of material evaluation. Certification or compliance claims depend on the exact compound, finished product, and intended application.
The standard apply to medical and food-grade silicone molding are listed below.
  • FDA food-contact requirements: FDA regulations identify conditions under which certain materials are suitable for specific food-contact applications. Manufacturers must verify the relevant regulatory provisions and intended conditions of use. A silicone compound is not automatically compliant merely because it is labeled food-grade.
  • USP Class VI: USP Class VI evaluates material responses through specified biological tests. The classification is frequently requested for materials used in medical and pharmaceutical applications. Compliance applies to the tested material under the relevant evaluation conditions.
  • ISO 10993: ISO 10993 provides a framework for evaluating the biological safety of medical devices. Testing requirements depend on the type and duration of patient contact. Manufacturers assess the finished device and its material composition according to the applicable parts of the standard.
  • LFGB: LFGB is a German food and feed law framework that includes requirements relevant to food-contact materials. Testing may assess migration and other material characteristics. Compliance depends on the applicable test requirements and intended use.
Can Silicone Parts Be Sterilized Without Losing Their Properties?
Yes, suitable silicone grades tolerate common sterilization methods without significant loss of performance. Steam autoclaving uses high-temperature saturated steam to sterilize compatible components. Ethylene oxide sterilization uses a gas-based process at controlled operating conditions. Gamma irradiation exposes components to ionizing radiation for sterilization. Material response depends on the silicone formulation, exposure level, and number of cycles. Repeated sterilization can affect selected mechanical or visual properties. Manufacturers verify the chosen grade through testing under the intended sterilization conditions. Product specifications must identify the approved method and exposure limits.
What Products Are Made by Silicone Compression Molding?
Silicone compression molding produces flexible components used across medical, automotive, electrical, food-processing, and consumer product industries. Common products include keypads, gaskets, diaphragms, seals, and protective covers. Manufacturers also produce baby product components and kitchenware from suitable silicone compounds. Medical applications use molded silicone parts for selected fluid-handling and equipment systems. Automotive applications require seals and grommets that tolerate temperature changes and environmental exposure. Electrical products use silicone components for insulation and moisture protection. Product geometry and material grade depend on the intended operating conditions. Compression molding supports custom shapes and different component thicknesses. The process remains useful for specialized silicone products across a broad range of applications.
What Are Common Silicone Compression Molded Parts?
Silicone compression molded parts include flexible components used for sealing, protection, control, and consumer product functions. Silicone's heat resistance and elasticity support different product designs. Material grade and hardness depend on the component's operating requirements.
Common molded silicone products are listed below.
  • Keypads: Silicone keypads provide flexible buttons for electronic devices and control panels. Molded designs support tactile response and integrated key shapes. Conductive carbon pills or printed contacts can provide electrical switching functions.
  • Gaskets: Silicone gaskets create seals between adjoining surfaces to limit fluid, air, or dust passage. Compression molding supports custom profiles and thicknesses. Heat resistance and flexibility make silicone suitable for selected industrial and appliance applications.
  • Diaphragms: Silicone diaphragms flex under pressure changes inside pumps, valves, and control systems. Their elasticity supports repeated movement during operation. Material thickness and hardness influence pressure response and service life.
  • Baby product components: Silicone compression molding produces selected bottle parts, pacifier components, and feeding accessories. Suitable grades provide flexibility and resistance to repeated cleaning. Food-contact requirements must be verified for the intended product.
  • Medical seals: Medical equipment uses silicone seals to prevent leakage and protect selected interfaces. Material selection depends on biological contact, sterilization exposure, and operating conditions. Testing and documentation help verify suitability for the intended medical application.
  • Kitchenware: Silicone compression molding produces baking molds, spatulas, grips, and other kitchen accessories. Heat resistance supports use in selected cooking environments. Food-contact suitability depends on the compound and applicable regulatory requirements.
How Is Silicone Bonded or Molded Onto Metal Inserts?
Silicone is bonded to metal inserts through surface preparation, suitable bonding agents, and controlled molding conditions. Manufacturers clean metal surfaces to remove oil, dust, and other contaminants. Primers or adhesives improve bonding between silicone and the selected metal substrate. Insert geometry can include holes, grooves, or undercuts that support mechanical retention. Operators position each insert inside the mold before loading the silicone preform. Heat and pressure cure the silicone around the insert during molding. Bond strength depends on surface condition, primer compatibility, and curing parameters. Manufacturers verify the bond through suitable adhesion or mechanical testing. Design reviews help identify interface features that improve long-term attachment.
Are Silicone Compression Molded Seals Used in Automotive and Electric Vehicle Connectors?
Yes, silicone compression molded seals are used in automotive and electric vehicle connectors. Seals and grommets protect electrical interfaces from moisture, dust, and other contaminants. Silicone's temperature resistance supports applications exposed to engine heat and changing environmental conditions. Under-hood connectors require materials that retain flexibility during thermal cycling. Electric vehicle battery systems use sealing components to protect selected electrical interfaces. Seal geometry must match connector dimensions and compression requirements. Material selection depends on temperature exposure, fluid contact, and electrical system specifications. Manufacturers verify sealing performance through application-specific testing.
What Tolerances and Defects Should You Plan for?
Silicone compression molding involves dimensional variation caused by material shrinkage, tooling conditions, and process settings. Silicone compounds contract during cooling and curing, which influences final component dimensions. Post-curing can introduce additional dimensional changes. Mold cavities require suitable allowances based on the selected material grade. Part geometry and thickness affect heat transfer and shrinkage behavior. Flash, voids, tearing, and under-cure are common defects that require process control. Accurate preform preparation supports consistent cavity filling. Proper venting reduces trapped air during compression. Inspection and production trials help identify dimensional and quality issues before full production.
How Much Does Silicone Shrink After Compression Molding and Curing?
Silicone shrinkage after compression molding depends on the compound, curing conditions, and component geometry. Mold shrinkage occurs as the material cools and completes its transition into a cured elastomer. The selected silicone grade influences the amount of dimensional contraction. Post-curing can cause additional shrinkage through the removal of volatile substances and continued material stabilization. Thick sections may respond differently from thin sections due to variations in heat transfer. Mold designers account for expected shrinkage when establishing cavity dimensions. Trial parts provide measured results that support tooling adjustments. Manufacturers verify critical dimensions after the required curing and post-curing stages. Material supplier data provides an initial reference, but production testing confirms actual results.
What Causes Voids, Tearing, and Under-Cure in Silicone Parts?
Voids, tearing, and under-cure in silicone parts result from material preparation issues, inadequate venting, incorrect processing conditions, or poor demolding practices. Trapped air or gases create voids inside the molded component, particularly when venting is insufficient or preform placement is inaccurate. Excessive demolding force and sharp mold features cause tearing, especially around deep cavities and delicate sections. Under-cure occurs when temperature or cure time falls below the compound's processing requirements. Incorrect material preparation can further affect curing performance and finished part quality. Incomplete filling occurs when the preform weight is insufficient or material distribution is uneven. Low mold temperature can restrict silicone flow before curing begins. Manufacturers reduce defects through accurate preform measurement, suitable vent design, controlled platen temperature, and proper demolding techniques.
How Do You Choose a Silicone Compression Molding Supplier?
Choosing a silicone compression molding supplier requires reviewing material expertise, tooling capabilities, quality controls, and production capacity. Available silicone grades determine whether the manufacturer supports the required application. Certifications and material documentation help verify compliance expectations. Tooling capabilities influence cavity accuracy and design flexibility. Prototyping support helps validate components before production tooling is finalized. Production capacity must match the expected order volume and delivery schedule. Inspection procedures provide evidence of dimensional and material quality. Communication practices influence project coordination and design revisions. A suitable supplier demonstrates the technical ability to meet the component's specifications.
How Does Rapid Prototyping Shorten Development of a Custom Silicone Part?
Rapid prototyping shortens custom silicone part development by allowing engineers to assess design features before production molds are completed. Prototype parts help verify fit, dimensions, and assembly compatibility. Printed models can identify geometry issues that require design changes. Prototype tooling can provide early samples for selected functional evaluations. Engineering reviews identify potential manufacturing problems before final mold construction. Early testing reduces the likelihood of expensive mold revisions. Material differences must be considered when prototypes use substances other than the intended production silicone. Final performance verification requires samples made from the approved production compound. A structured prototype stage supports more informed tooling decisions.
When Should You Use Silicone Casting Instead of Compression Molding for First Prototypes?
Silicone casting suits very small prototype quantities when quick samples are needed without dedicated production tooling. A 3D printed master can form the pattern used to create a casting mold. The method supports early evaluation of shape, fit, and selected functional features. Casting generally requires less initial tooling investment than a production compression mold. Material properties depend on the selected casting silicone and curing system. Cast samples do not automatically match the mechanical performance of compression-molded production parts. Compression molding provides better alignment with the intended production process when the same compound and tooling conditions are used. Engineers compare prototype purpose, required material properties, quantity, and lead time before choosing a method, including silicone casting.
Can a Silicone Compression Molding Supplier Help With Design Changes After the First Samples?
Yes, an experienced silicone compression molding supplier can support design changes after initial samples are reviewed. Engineering feedback identifies geometry features that affect mold filling, demolding, and dimensional accuracy. Design-for-manufacturability reviews help address potential production issues. Mold adjustments can correct cavity dimensions, parting-line details, and vent locations. Revised samples allow engineers to evaluate the effect of each change. Sample approval confirms whether the updated design meets the required specifications. Documented revisions reduce confusion before production begins. Early collaboration helps limit rework and supports a smoother transition into manufacturing.
