Aerospace Wiring Harness Guide: Parts, Types, Design, and Fabrication
Written byMegan Conniff
13 min read
Published November 26, 2026
Aerospace Wiring Harness. Image credit: Shutterstock/thanun vongsuravanich
An aerospace wire harness is an organized bundle of wires, terminals, connectors that carries power, signals through an aircraft. An aerospace wire harness replaces loose point to point wiring in the airframe, engines, cabin, cockpit. An Airbus A380 carries about 530 km (330 mi) of cable, so organized bundles keep installation, inspection manageable. Copper conductors in American Wire Gauge (AWG) sizes from 26 to 10 carry current, whereas insulation, shielding, sleeving protect the bundle. Terminals crimped onto wire ends lock into connector shells, completing each circuit.
Parts include wires, terminals, connectors, protective coverings, mounting hardware. Types range from engine, airframe, cabin harnesses to avionics, military assemblies. Engineering inputs cover electrical load, routing path, operating environment, connector selection. Fabrication runs from wire cutting, stripping through crimping, assembly on a harness board, continuity testing. Custom manufacturing supplies the supporting parts, including computer numerical control (CNC) machined contacts, injection molded housings, 3D printed prototypes, sheet metal brackets. Insulation resistance, continuity, pull testing catch crimp, pinout errors before installation.
What Does an Aerospace Wire Harness Do on an Aircraft?
An aerospace wire harness groups wires, cables into one organized unit that carries power, signals on an aircraft. Harnesses outperform loose wiring through easier installation, protection from vibration, abrasion, simpler troubleshooting. Technicians install one preassembled bundle through a fuselage in a single pass, instead of pulling hundreds of wires one by one. Printed wire identification, lacing, clamps let inspectors trace circuits against the build drawing. Sleeving, grommets shield bundles from airframe vibration, chafing at structural cutouts.
Why Do Aircraft Use a Wiring Harness Instead of Loose Wires?
Aircraft use a wiring harness instead of loose wires since one bundle routes power, signals among the power source, engines, avionics, sensors, lighting, controls. The harness replaces point to point wiring in the airframe, so one trunk carrying branches reaches each system. Bundling saves weight, since shared clamps, sleeving replace separate wire runs, a gain that lowers fuel burn. Separation rules keep redundant flight control circuits on different routes, so one harness failure leaves backups intact.
How Does an Aerospace Cable Harness Differ From a Wire Harness?
An aerospace cable harness differs from a wire harness in construction. A wire harness bundles insulated wires, whereas a cable harness groups cables under a shared outer jacket. Wire harnesses route power, discrete signals in airframes, cabin systems, lighting circuits. Cable harnesses group twisted pair, coaxial, fiber optic, shielded cables that carry avionics data, radio frequency signals. The outer jacket protects the cables from abrasion, moisture, electromagnetic interference. Hybrid assemblies join wire branches, cable branches in one bundle.
Are Wire Assemblies and Harness Assemblies the Same Thing in Aviation?
Yes, wire assemblies, harness assemblies are the same thing in aviation when the term names a finished unit. The words assembly, harness are used loosely, so a buyer means the sleeving, the bundle, or the finished unit, depending on the shop. Drawing numbers, part numbers settle the question, since a drawing defines wire lists, connectors, lengths. Quote requests name the item, the revision. Terms overlap, but a harness carries circuits, whereas sleeving protects the bundle.
What Parts Make Up an Aircraft Wire Harness?
An aircraft wire harness is made up of wires, terminals, connectors, protective coverings, mounting hardware. Wires carry current, whereas crimped terminals make the joint at each wire end. Connector shells, inserts hold contacts in fixed positions, so mating halves complete each circuit. Sleeving, tape, lacing cord, heat shrink protect the bundle, whereas clamps, grommets, standoffs secure routing. Each part fixes a failure point, so crimp quality, clamp spacing set field reliability.
Which Conductors and Insulation Does an Aircraft Wiring Harness Use?
An aircraft wiring harness uses copper conductors, fluoropolymer insulation, braided shielding or sleeving. Insulation options include polytetrafluoroethylene (PTFE) rated near 200 °C (392 °F), ethylene tetrafluoroethylene (ETFE) rated near 150 °C (302 °F), cross linked polyethylene (XLPE) rated near 125 °C (257 °F). Silver plated, nickel plated copper conductors suit engine zones above 200 °C (392 °F). Hydraulic fluid, fuel, deicing fluid demand chemical resistant jackets, whereas flexing demands stranded conductors. Braided shielding blocks electromagnetic interference.
How Do CNC Milling and CNC Turning Shape Connector Shells and Contact Pins for Aerospace Cable Assemblies?
CNC milling, CNC turning shape connector shells, contact pins in aerospace cable assemblies by cutting parts from solid metal. Shells are milled from aluminum or stainless steel bar, whereas pins, contacts are turned from copper alloy rod. Terminals, contacts are plated copper alloys, using gold over nickel on signal contacts. Tight tolerances near ±0.025 mm (±0.001 in) keep contacts aligned in shells. Plating thickness near 1.27 µm (50 microinches), bore diameters, concentricity are inspected on parts produced through CNC milling.
Why Is Injection Molding, Including Overmolding, Used for Aircraft Connector Housings?
Injection molding, including overmolding, is used in aircraft connector housings since the process produces repeatable plastic parts in volume. Overmolding seals a connector to its cable, forming a strain relief, moisture barrier at the cable exit. Resin choice matters, since nylon offers toughness, polybutylene terephthalate (PBT) offers dimensional stability, polyetheretherketone (PEEK) holds strength near 250 °C (482 °F). Flame retardant grades meet Underwriters Laboratories (UL) 94 V-0. Volume runs of housings come from injection molding.
Can 3D Printing, Such As Selective Laser Sintering, Prototype Aircraft Harness Clips and Routing Fixtures?
Yes, 3D printing, including selective laser sintering (SLS), prototypes aircraft harness clips, routing fixtures before tooling is committed. Selective laser sintering fuses nylon powder layer by layer, producing connector housings, cable clips, routing fixtures without support structures. Test fits on a mockup, airframe section confirm clearances within days. Printed nylon parts show lower strength, heat resistance than molded PBT, PEEK, so final production uses injection molding. Prototype clips, fixtures are produced through 3D printing.
What Kinds of Aerospace Wiring Harness Exist?
Kinds of aerospace wiring harness include engine, airframe, cabin, avionics, military assemblies. Construction, protection requirements differ by operating environment, from a pressurized cabin at 22 °C (72 °F) to an engine nacelle above 200 °C (392 °F). Heat, vibration, fluids, flexing cycles, electromagnetic interference decide the insulation, shielding, sleeving, connector choices.
The kinds of aerospace wiring harness are listed below.
  • Engine Harness: An engine harness links the full authority digital engine control (FADEC) unit, ignition, sensors, fuel metering units to the airframe wiring. Cables run near hot sections, so PTFE insulation, nickel plated copper conductors, fire sleeves resist 260 °C (500 °F). Oil, fuel resistant jackets block fluid attack, whereas sealed connectors keep moisture out. Strain relief, vibration clamps protect terminals from fatigue on the engine casing. Redundant sensor circuits follow separate routes.
  • Airframe Harness: An airframe harness runs through the fuselage, wings, tail, landing gear bays, linking flight controls, hydraulics sensors, fuel system probes, external lighting. Routing follows separation rules, keeping redundant flight control circuits apart. Wings flex in flight, so stranded conductors, service loops absorb motion. Moisture, deicing fluid reach landing gear areas, so sealed connectors, abrasion resistant sleeving protect the circuits. Clamps hold the bundle 13 mm (0.5 in) from hydraulic lines, structure.
  • Cabin Harness: A cabin harness serves passenger areas, linking seat power outlets, reading lights, galley equipment, lavatories, in flight entertainment, cabin lighting. Cable runs follow ceilings, sidewalls, floor beams, so flat, lightweight bundles save space. Flame retardant insulation, low smoke jackets meet cabin flammability rules under Title 14 of the Code of Federal Regulations (CFR) Part 25. Power outlets run on 115 volt alternating current.
  • Avionics Harness: An avionics harness links flight computers, cockpit displays, navigation, communication radios, flight data recorders. Shielded twisted pair cables carry Aeronautical Radio, Incorporated (ARINC) 429 data, whereas coaxial cables carry radio frequency signals. Shield terminations, grounding rules limit electromagnetic interference, lightning induced transients. Backshells, gaskets seal shields at connector shells. Tight bend radii, short stub lengths protect signal quality on data buses. Fiber optic links carry high speed data in newer aircraft.
  • Military Harness: A military harness meets defense platform requirements, shielding against electromagnetic pulses, surviving shock, vibration, salt fog, sand. MIL-DTL-38999 circular connectors resist corrosion, mate in a quarter turn. Armored sleeving, metal conduit stop abrasion in combat vehicles, fighter aircraft. Test programs follow MIL-STD-810 environmental methods, MIL-STD-461 emissions limits. Traceability records follow each lot from wire spool to delivery. Operating temperatures run from −55 °C to 125 °C (−67 °F to 257 °F).
What Role Does an Engine Harness Play in Aircraft Wiring?
An engine harness plays the role of linking the engine controls, ignition, sensors to cockpit instruments, airframe systems. The FADEC unit reads shaft speed, temperature, pressure signals, then adjusts fuel flow within milliseconds. Heat resistance matters, since engine bays reach 260 °C (500 °F) near turbine sections. Oil, fuel resistant jackets, sealed connectors block fluid attack, whereas fire sleeves protect branches during flame exposure. Vibration clamps, strain relief loops protect terminals from engine casing fatigue.
How Do Custom Aerospace Cables Compare With Stock Aircraft Harnesses?
Custom aerospace cables compare to stock aircraft harnesses through fit, cost, lead time. A custom cable is built to a specific drawing, whereas a stock harness is a ready made or replacement unit. Custom cables match routing lengths, connector clocking to the aircraft, whereas stock units need field trimming. Stock harnesses cost less per unit, whereas custom builds spread tooling, qualification costs across the order. Stock units ship in days, whereas custom cables take weeks.
Do Military Wire Harnesses Need Different Construction Than Commercial Aerospace Ones?
Yes, military wire harnesses need different construction than commercial aerospace ones in operating environment, shielding, vibration load, compliance standards. Defense platforms face sand, salt fog, shock loads above 30 g, whereas airliners face pressurized cabin conditions, scheduled maintenance. Military shielding blocks electromagnetic pulse, radar interference, using braided shields, metal conduit, 360 degree backshells. Compliance follows MIL-STD-810, MIL-STD-461, whereas commercial work follows Federal Aviation Administration (FAA) rules, RTCA DO-160 test methods. Military builds add lot traceability, counterfeit part controls.
How Do Engineers Lay Out an Aerospace Wiring Harness?
Engineers lay out an aerospace wiring harness from four inputs (electrical load, routing path, environment, connector selection). Electrical load sets wire gauge, from 22 AWG at 5 A to 12 AWG at 25 A. Routing paths set branch lengths, bend radii near 10 times the cable diameter, clamp spacing near 300 mm (12 in). Environment, connector selection set insulation, sealing, tooling, which drive manufacturability, cost. Standard terminals, fewer branches lower cost, since each unique part adds inventory, crimp setups.
What Information Goes on an Aircraft Harness Build Drawing?
An aircraft harness build drawing carries wire gauges, colors, lengths, pin assignments, connector part numbers, branch layout. A wire list names each wire (W12, 20 AWG, white, 1,250 mm (49.2 in)). Pin tables map each contact to a connector cavity, so assemblers insert wire W12 into cavity A3. Branch layout shows breakout points, dimensions in millimeters, tolerances near ±13 mm (±0.5 in), lacing locations. The drawing gives builders, inspectors the build instructions, test limits, revision history, military specification callouts.
How Do Laser Cutting and Sheet Metal Fabrication Shape Harness Brackets and Junction Boxes?
Laser cutting, sheet metal fabrication shape harness brackets, junction boxes by cutting, bending, forming flat sheet. Brackets, guards hold harness routing in place, shielding bundles from heat, abrasion. Junction boxes house splices, relays, terminal blocks inside sealed aluminum enclosures, 1.0 mm to 2.0 mm (0.04 in to 0.08 in) thick. Aluminum 6061, 5052 sheet suits lightweight brackets, whereas stainless steel suits fire zone guards. Flat brackets, panels start through Laser cutting.
How Are Aerospace Wire Harnesses Fabricated From Start to Finish?
Aerospace wire harnesses are fabricated from start to finish through wire cutting, stripping, crimping, assembly, testing. Machines cut wire to length within ±1 mm, strip 3 mm to 8 mm (0.12 in to 0.31 in) of insulation, crimp terminals. Workers route wires on a harness board, a full size print of the drawing that holds connectors, branches in position. Production is largely manual, since flexible, branching bundles resist full automation.
What Are the Fabrication Steps for an Aircraft Wire Harness, and Where Do Assembly Services Come in?
First, machines cut wire to length, strip 6 mm (0.24 in) of insulation. Second, crimp tools press terminals onto conductors at a set crimp height. Third, assemblers insert contacts into connectors until retention clips lock. Fourth, workers bundle wires on the harness board. Fifth, tape, sleeving, lacing cord cover the bundle. Sixth, testers run continuity checks. Lastly, outside assembly services cover the mechanical parts around the harness, not the harness itself.
How Does a Prototype Harness Build Differ From a Production Run?
A prototype harness build differs from a production run in volume, validation scope, fit checks, production readiness. Prototype builds validate fit, routing in one to 10 samples. Prototype molding of housings confirms clearances before production tooling is finalized. Prototype lead time runs days, whereas production tooling, process validation take weeks. Surrounding components in early builds come from Rapid prototyping.
The differences from a prototype harness build to a production run are shown in the table below.
Can Aerospace Wire Harness Fabrication Be Automated for High-Volume Production?
Yes, aerospace wire harness fabrication is automated in part, since machines handle cutting, stripping, crimping. Wire processing machines reach 1,000 wires per hour, holding length within ±1 mm. Final routing, assembly remain largely manual, since branching, flexible bundles resist robotic handling. Connector insertion, lacing, sleeving, inspection need hand dexterity, vision checks, so assemblers perform the steps. Aerospace harnesses run in low quantities per part number, so manual boards stay economical. Automated cutting, crimping cells support high-volume production.
What Should Buyers in Aerospace and Defense Check Before Picking Wire Harness Manufacturers?
Buyers in aerospace and defense check quality certifications, testing capability, prototyping support, lead time, volume capacity before picking wire harness manufacturers. Certifications prove a documented quality system, export compliance, workmanship criteria. Testing capability covers continuity, insulation resistance, dielectric withstand, pull testing on each shipped unit. Prototyping support shortens qualification, since a supplier that builds samples in days, then scales to volume, avoids requalification. Lead time, volume capacity, quoted tolerances decide the match to programs in Aerospace and defense.
Which Certifications, Such As AS9100D and ITAR Registration, Do Aerospace Harness Suppliers Need?
Aerospace harness suppliers need AS9100D certification, International Traffic in Arms Regulations (ITAR) registration on defense work. AS9100D extends International Organization for Standardization (ISO) 9001 quality management, adding configuration control, risk management, counterfeit part prevention. The Association Connecting Electronics Industries (IPC), Wire Harness Manufacturers Association (WHMA) standard IPC/WHMA-A-620 sets workmanship criteria in three classes, led by Class 3 high reliability. ITAR registration signals export compliance, since the U.S. Department of State controls defense article manufacturing, technical data.
How Does Quality Assurance Testing Check an Aircraft Wiring Harness Before Installation?
Quality assurance testing checks an aircraft wiring harness before installation through continuity, insulation resistance, pull testing. Continuity testing confirms each pin connects to the correct pin, using a test board that reads open, short, miswired circuits. Insulation resistance testing applies 500 volts direct current, expecting readings above 100 megohms. Pull testing loads crimped contacts to a set force, about 36 N (8 lbf) on 20 AWG wire. Tests catch crimp, pinout errors early, before installation in an airframe.
