Automotive Wire Harness: Components, Types, and Manufacturing
Written byMegan Conniff
20 min read
Published November 26, 2026
Automotive Wire Harness. Image credit: Shutterstock/Lucian Coman
Automotive wire harness assemblies are organized bundles of wires, terminals, and connectors that carry power and signals through a car. Automotive wire harness components include copper conductors, plated terminals, molded connector housings, protective sleeving, and mounting clips. One harness links the battery, engine control unit (ECU), sensors, lighting, and body controls along a single routed path. The assembly replaces loose wiring, which shortens installation time and protects circuits from vibration, heat, and abrasion.
Common types include engine, chassis, body, industrial, and aerospace or military harnesses, each built for a different operating environment. Engineering considerations cover electrical load, routing path, environment, and connector selection, since each choice affects cost and manufacturability. Production follows a defined flow of wire cutting, stripping, crimping, assembly on a harness board, and electrical testing. Supporting parts come from custom manufacturing, including CNC machined terminals, injection molded housings, 3D printed prototypes, and sheet metal brackets. Standards from SAE, ISO, IPC, and IATF govern wire quality, workmanship, and factory processes across the global supply chain. The sections below explain each topic in detail, from definitions and materials to testing procedures and manufacturer selection.
What Is an Automotive Wire Harness?
An automotive wire harness is an assembly that groups wires and cables into one organized unit. Terminals, connectors, tape, and sleeving hold the bundle together and connect each circuit to a component. Wire gauge, color, and length follow a drawing, so each unit leaves the factory identical. Carmakers choose a harness over loose wiring since the unit installs in one step. Workers on the assembly line clip a finished harness along the dashboard, door pillars, and floor pan instead of running separate wires. Sleeving and tape protect conductors from vibration and abrasion at sharp panel edges. Clips and grommets fix the routing, so wires stay clear of exhaust heat and moving parts. A connector with 24 pins joins 24 circuits at one mating point, which reduces loose joints. Troubleshooting becomes simpler, since labeled branches and numbered connector cavities point technicians to the faulty circuit.
What Is a Wiring Harness in a Car?
A wiring harness in a car is a bundled set of wires that routes power and signals from the battery to the engine, sensors, lighting, and controls. Power wires carry current from the 12 volt battery to the starter, fuel pump, headlamps, and cooling fan. Signal wires carry low current data from wheel speed sensors, oxygen sensors, and switches to the ECU. Older cars used point to point wiring, where each circuit ran on a separate wire from switch to load. The harness replaces that layout by grouping circuits into trunk lines with short branches to each component. Routing follows the body structure, passing through firewall grommets and door jambs. Modern vehicles use separate harnesses (engine, dashboard, body, door) joined by connectors. Wire sizes for signal and power circuits run from 0.35 to six square millimeters, whereas battery cables are larger. The wire gauge matches current demand to prevent overheating.
What Is the Difference Between a Wire Harness and a Cable Harness?
A wire harness differs from a cable harness in how the conductors are grouped and protected. A wire harness bundles separate insulated wires with tape, sleeving, or conduit, so each wire keeps its own insulation. A cable harness groups cables, where each cable holds insulated conductors under a shared outer jacket. Twisted pair and shielded cables (USB, Ethernet, coaxial) belong to the cable category. Cars use wire harnesses for power distribution, lighting, and sensor circuits that need flexible routing. Cable harnesses suit antenna feeds, camera links, and infotainment data, where shielding blocks electromagnetic interference. Industrial machines apply the same split, using wire harnesses in control panels and cable harnesses on robot arms and sensors. A vehicle harness includes jacketed cable runs inside a wire bundle when shielding is needed. Terminology varies by supplier, so the drawing defines the exact construction of each assembly.
Is a Wiring Loom for a Car the Same as a Wire Harness?
No, a wiring loom for a car is not the same as a wire harness. The term loom changes meaning, depending on region. British usage treats a wiring loom as the complete assembly of wires and connectors. American usage treats a wire loom as the protective sleeving, commonly corrugated split tubing of polyethylene or nylon. The terms overlap in practice. A British loom is the harness, whereas an American loom is a protective part of the harness. Buyers avoid confusion by asking whether a quote covers the full assembly or the sleeving alone. Split loom tubing wraps an existing bundle after assembly, whereas a harness arrives with terminals, connectors, and sleeving already installed. Drawings use the word harness to remove doubt, and listing the sleeving as a separate line item keeps costs clear.
What Are the Components of an Automotive Wire Harness?
The components of an automotive wire harness are wires, terminals, connectors, protective coverings, and mounting hardware. Wires carry current through stranded copper cores sized to the load. Terminals crimped onto wire ends form the electrical joint, and plating (tin, silver, gold) protects contact surfaces from corrosion. Connectors house the terminals in molded plastic bodies with locking latches and seals against water. Protective coverings (tape, braided sleeving, corrugated conduit, heat shrink) guard the bundle against abrasion, heat, and fluids. Mounting hardware (clips, grommets, cable ties, brackets) fixes the routing to the body and keeps bends above the minimum radius. Harnesses that feed a power distribution box add fuses, relays, and splices to protect circuits and join branches. Each component contributes to reliability when rated for the same current, temperature, and sealing level. A terminal sized for a 0.5 square millimeter wire fails when crimped onto a larger conductor.
What Materials Are Used in an Automotive Wiring Harness?
The materials used in an automotive wiring harness are copper conductors, polymer insulation, and braided or corrugated sleeving. Copper conducts well, and stranded copper survives flexing and vibration better than solid wire. Tinned copper resists corrosion, whereas aluminum alloy conductors cut weight in selected circuits. PVC insulation (SAE J1128 type GPT) suits passenger compartment wiring rated near 80 degrees Celsius. Crosslinked polyethylene (XLPE) insulation (types GXL, TXL) withstands 125 degrees Celsius in engine bays and resists oil. Silicone insulation handles 200 degrees Celsius near exhaust components and stays flexible in cold. Braided polyethylene terephthalate (PET) sleeving and corrugated nylon conduit shield the bundle from abrasion, fuel, and road splash. Heat, chemicals, and flexing steer the material choice. Engine bay wiring needs XLPE or silicone, whereas door hinge wiring needs fine stranded copper for repeated bending. Brake fluid and fuel exposure favors XLPE or fluoropolymer insulation.
How Does CNC Machining Make the Connectors and Terminals in an Automotive Wire Harness?
CNC machining makes the connectors and terminals in an automotive wire harness by cutting pins, sockets, and shells from metal bar stock. Terminal materials include free cutting brass (C36000), phosphor bronze, and copper alloys with plated surfaces. Swiss type lathes turn small round pins and sockets, whereas milling centers cut connector shells and bus bars. Machined contacts suit low volume or high current applications (electric vehicle battery connectors, sensor pins), whereas stamped terminals dominate high volume signal circuits. Tolerances on pin diameter and contact bore run near plus or minus 0.02 millimeters, which controls insertion force and contact resistance. Deburring removes sharp edges that damage seals and mating contacts. Plating follows machining, with tin for standard circuits, silver for high current paths, and gold for low voltage signal contacts. Dimensional inspection and plating checks follow each batch of precision parts made by CNC machining.
How Are Automotive Wire Harness Connector Housings Made With Injection Molding?
Automotive wire harness connector housings are made with injection molding by melting plastic pellets and injecting the melt into a steel mold. The mold shapes terminal cavities, locking latches, and seal grooves in one shot. Volume runs justify the tooling cost, since one multi cavity tool produces thousands of identical housings. Material selection matters since housings face engine bay heat, vibration, and flame exposure. Glass filled nylon 66 (PA66) melts near 260 degrees Celsius and holds strength under load. PBT absorbs less moisture than nylon and keeps dimensions stable, which suits sealed connectors. Flame retardant grades meet UL 94 V0 and FMVSS 302 limits for burn rate in vehicle interiors. Processors dry nylon pellets before molding to prevent voids and splay marks. Assemblers then add silicone seals, terminal position assurance (TPA) locks, and connector position assurance (CPA) latches. Mold temperature, hold pressure, and cooling time control dimensions and latch strength in injection molding.
Can 3D Printing Be Used to Prototype Automotive Wire Harness Components?
Yes, 3D printing can be used to prototype automotive wire harness components. Printed connector housings, cable clips, and routing fixtures let engineers test fit before tooling is committed. Stereolithography (SLA) resin captures fine latch detail, whereas selective laser sintering (SLS) produces tough nylon PA12 parts. Printed pegs, clamps, and branch labels adapt a harness board overnight. Revisions cost little at the prototype stage, since a revised file replaces a modified steel mold. Printed parts fall short of molded PA66 and PBT in heat resistance, flame rating, and latch fatigue life. Layer lines roughen sealing surfaces, so printed housings struggle to pass IP67 water ingress tests. Unit costs stay flat in printing, whereas molded housings fall sharply per part at volume. Production programs therefore treat early fit checks as the strongest use of 3D printing.
What Are the Types of Automotive Wiring Harness?
The types of automotive wiring harness include engine, chassis, body, industrial, and aerospace or military harnesses. Construction and protection requirements differ by operating environment, since heat, fluids, flexing, and weight limits change from one location to the next. Industrial and aerospace types extend the category beyond road vehicles.
The types of automotive wiring harness are listed below.
  • Engine Harness: Engine harnesses connect the ECU, injectors, ignition coils, and sensors on the powertrain. Insulation uses XLPE or silicone to handle heat and oil. Corrugated conduit and braided sleeving add abrasion protection.
  • Chassis Harness: Chassis harnesses run along the underbody to the anti lock braking system (ABS) sensors, fuel pump, rear lighting, and suspension modules. Water, road salt, and stone impact demand sealed connectors and abrasion resistant conduit. Clips hold the routing along frame rails, away from the exhaust and moving suspension parts.
  • Body Harness: Body harnesses serve the cabin, including the instrument panel, doors, seats, airbags, and interior lighting. Branches pass through door jambs and firewall grommets, so flexing resistance matters. Lower temperatures allow PVC insulation in cabin circuits.
  • Industrial Harness: Industrial harnesses connect machinery, control panels, robots, and sensors in factories. Circuits run from 24 volts DC for control to 480 volts AC for motors, with high flex cables on moving axes. UL 758 appliance wiring material (AWM) and IP67 or IP69K connectors address factory conditions.
  • Aerospace and Military Harness: Aerospace and military harnesses prioritize low weight, flame resistance, and shielding. Fluoropolymer insulated wire to SAE AS50881 and military specifications is rated from 150 to 260 degrees Celsius. Quality systems (AS9100) require full traceability and test records.
What Does an Engine Wiring Harness Do in a Car?
An engine wiring harness in a car connects the ECU to the injectors, ignition system, and sensors. The ECU reads signals from crankshaft, camshaft, oxygen, coolant temperature, and manifold pressure sensors. Output wires then carry pulses to fuel injectors and ignition coils, which set fuel quantity and spark timing. Power and ground branches supply relays, sensors, and the cooling fan. Engine bay conditions are harsh, with temperatures near 125 degrees Celsius and constant contact with oil, fuel, and coolant. Harness makers respond with XLPE or silicone insulation, which resists heat and oil. Corrugated nylon conduit, heat shrink boots, and sealed connectors keep fluids and abrasion away from terminals. Heat shields and clips hold the routing clear of the exhaust manifold and turbocharger. Vibration from the crankshaft stresses crimps, so stranded conductors and strain relief extend service life. A failed engine harness triggers misfires, hard starting, or a check engine light.
What Is the Difference Between a Custom Automotive Wiring Harness and an Aftermarket Wiring Harness?
A custom automotive wiring harness differs from an aftermarket wiring harness in how the assembly is specified and built. A custom harness is built to a customer drawing that lists wire gauges, connectors, and branch lengths. An aftermarket harness is a ready made replacement or a universal kit (12 circuit, 21 circuit) for swaps and restorations. Fit favors the custom option, since each connector location and branch length matches the vehicle. Universal kits require trimming, splicing, and rerouting during vehicle installation. Custom builds carry setup costs for the drawing, harness board, and crimp tooling, but the per unit price falls at volume. Aftermarket kits cost less upfront and suit one off projects. Stocked kits ship in days, whereas custom orders take weeks for drawing approval, sampling, and production. Original equipment manufacturer (OEM) programs and race teams choose custom harnesses, whereas hobby builders choose aftermarket kits.
Are Industrial Wire Harnesses Built Differently From Automotive Ones?
Yes, industrial wire harnesses are built differently from automotive ones. Automotive circuits run at 12 volts, with 24 volts in trucks and 48 volts in mild hybrids. Industrial machines run from 24 volts DC for control circuits to 480 volts AC for motors. Sealing targets differ. Automotive connectors face road splash and engine fluids, whereas industrial connectors face washdown spray and dust (IP67, IP69K). Flexing demands vary. Robot cables bend millions of times in drag chains, whereas automotive harnesses stay fixed except at door hinges. Compliance rules diverge. Industrial builds follow UL 758, NFPA 79, and IEC 60204 for machinery wiring, whereas automotive builds follow ISO 6722, SAE J1128, and IATF 16949 quality systems. Panel wiring uses color coded conductors and numbered ferrules for field service. Automotive harnesses prioritize low weight and compact routing.
How Is an Automotive Wire Harness Designed?
An automotive wire harness is engineered from four inputs, namely electrical load, routing path, environment, and connector selection. Electrical load sets the wire gauge, since current and allowable voltage drop determine conductor size. A 20 ampere circuit needs a conductor near 2.5 square millimeters, whereas a 0.5 ampere sensor circuit works with 0.35 square millimeters. Routing path comes from the 3D vehicle model, which fixes branch lengths, bend radii, and clip locations. Environment sets insulation, sleeving, and sealing, based on temperature, fluids, vibration, and electromagnetic interference. Connector selection depends on pin count, current rating, sealing, and mating cycles. Engineers choose standard connector families and common wire colors to limit part variety. Fewer splices, shorter branches, and thinner wire where loads permit cut copper weight and cost. Branches that cross tight spaces raise assembly time and the risk of pinched wires. Early reviews with the manufacturer catch costly features before the drawing is released.
What Does an Automotive Wire Harness Drawing Include?
An automotive wire harness drawing includes wire gauges, colors, lengths, pin assignments, connector part numbers, and the branch layout. The wire list names each circuit by number, gauge, color, insulation type, and the cavity at each end. Connector views show cavity numbers, keying, and the terminal and seal part number for each position. The layout view draws the trunk and branches to scale, with dimensions from each breakout to each connector face. Length tolerances, tape and sleeving callouts, clip positions, and labels complete the view. A bill of materials (BOM) and revision block control the exact parts and drawing issue. The drawing acts as the build instruction for the factory floor. Operators read it at the harness board, where a full scale print guides wire placement, branch angles, and tape wraps. Test engineers derive the netlist from the wire list, so the continuity tester checks each pin against the intended circuit.
How Does Sheet Metal Fabrication of Brackets and Enclosures Protect an Automotive Wire Harness?
Sheet metal fabrication of brackets and enclosures protects an automotive wire harness by fixing the routing and shielding wires from heat and abrasion. Brackets hold the harness at set points, which prevents sagging and chafing against edges. Junction boxes and enclosures house splices, fuses, and relays away from water and dust. Heat shields in aluminum or stainless steel deflect radiant heat from exhaust manifolds and catalytic converters. Guards and cable trays cover wires near moving parts and sharp panel edges. Fabricators produce the parts by laser cutting flat blanks, bending them on a press brake, and punching clip holes. Common materials include galvanized steel, 304 stainless steel, and 5052 aluminum from 0.8 to three millimeters thick. Deburred edges and rolled flanges prevent insulation cuts, and zinc plating or powder coating resists corrosion. Accurate bend angles and hole positions keep clips aligned with the harness drawing in sheet metal fabrication.
How Is an Automotive Wire Harness Manufactured?
An automotive wire harness is manufactured through wire cutting, stripping, crimping, assembly on a harness board, and testing. Production is largely manual, guided by a harness board that holds the layout at full scale. Automatic machines cut wire to length, strip insulation, and crimp terminals at high speed. Operators then insert terminals into connector cavities until the locks click. Wires are laid on the board along pegs and clamps that set each branch. Taping, sleeving, and clip installation protect the bundle before the harness leaves the board. Electrical testers check continuity, shorts, and pin placement against the netlist. Inspectors verify dimensions, labels, and workmanship against IPC/WHMA-A-620 criteria. Operators pack the finished harnesses in labeled bags or trays for shipment to vehicle assembly plants. Traceability labels link each harness to its production lot and test record. Changeovers from one part number to the next require new board layouts, crimp tooling, and first article approval.
What Are the Steps in Cable Harness Assembly?
The steps in cable harness assembly run from cutting and stripping to continuity testing. To know the steps in cable harness assembly, follow the six steps. First, machines cut each wire to the length on the drawing and strip the insulation from each end. Waterproof connectors need silicone wire seals slid on before the crimp. Second, crimp presses attach terminals to the stripped ends, and operators check crimp height and pull force. Third, operators insert the terminals into connector housings until the locks seat. Fourth, wires are laid and bundled on the harness board along pegs that set the branch angles and lengths. Splices join branches at set points, and ultrasonic welding or crimped sleeves form the joint. Fifth, operators wrap the bundle in tape or sleeving and add clips, grommets, and labels. Heat shrink tubing seals splices and connector backs. Lastly, a test board checks continuity, shorts, and pin placement against the netlist before packing.
How Does a Prototype Automotive Wire Harness Differ From a Production Harness, and Where Does Rapid Prototyping Fit?
A prototype automotive wire harness differs from a production harness in quantity, tooling, and process maturity. Prototype builds validate fit and routing in small quantities (five to 20 units) on a vehicle or test buck. Technicians hand crimp terminals with bench tools and revise the drawing after each fit trial. Production harnesses use frozen drawings, dedicated crimp tooling, and validated processes (PPAP under IATF 16949). Production runs measure output in thousands of units, and cost per unit drops with automated cutting and crimping. Prototypes carry higher cost per unit, since setup, engineering time, and manual labor spread across few harnesses. Prototype wire lists change as trials reveal conflicts, whereas production lists change through formal engineering change notices. Surrounding parts (housings, clips, brackets) must match the harness during trials. Printed and machined stand ins for tooled housings and brackets come from rapid prototyping.
Can an Automotive Wire Harness Be Fully Automated?
No, an automotive wire harness cannot be fully automated. Cutting, stripping, and crimping run on automatic machines, but final routing and assembly remain largely manual. Wire processing machines handle thousands of terminals per shift with consistent strip length and crimp height. Harness complexity blocks full automation, since a single vehicle needs dozens of branches, 3D routing, and mixed connector styles. Flexible wires lack stiffness, so robots struggle to grip, route, and seat them in connectors. Trim level variants change the wire list from one order to the next. Automation reaches further in selected steps, including automatic taping, ultrasonic splicing, and robotic connector insertion on simple products. Fully automatic harness lines remain rare, whereas production plants keep skilled operators at the harness board. Labor cost drives harness plants toward regions with skilled manual assembly capacity.
How Do You Choose Automotive Wire Harness Manufacturers?
You choose automotive wire harness manufacturers by comparing quality certifications, testing capability, prototyping support, lead time, and volume capacity. Quality certifications (IATF 16949, ISO 9001) show a documented process for defect prevention and traceability. Testing capability covers 100 percent electrical testing, crimp pull checks, and cross section analysis. Prototyping support shortens development, since quick turn samples let engineers confirm fit before release. Lead time covers quoting, sampling, and production, and a supplier with local stock of wire and terminals responds faster. Volume capacity matters when programs scale from 500 to 50,000 harnesses per year. Boards, operators, and tooling must scale with the volume. Engineering support (drawing review, cost reduction, alternate connector sourcing) adds value before the first order. Material traceability, quality records, and a clear change control process protect the program during revisions. Supplier audits and sample reports (first article inspection) confirm capability before award.
What Certifications, Such As IATF 16949, Should Automotive Wire Harness Manufacturers Have?
Automotive wire harness manufacturers should have quality certifications (IATF 16949, ISO 9001, IPC/WHMA-A-620). IATF 16949 is the automotive quality management standard from the International Automotive Task Force. The standard builds on ISO 9001 and adds defect prevention, supplier control, and core tools (APQP, PPAP, FMEA). Car manufacturers expect IATF 16949 from direct suppliers of production parts. ISO 9001 sets the quality management baseline for industrial and non automotive work. IPC/WHMA-A-620 defines workmanship criteria for crimps, soldering, routing, and labeling in three classes. Automotive customers commonly specify Class 2 or Class 3 acceptance. ISO 14001 covers environmental management, and ISO 45001 covers workplace safety. UL recognition for wire and components confirms flame and electrical safety ratings. Accredited registrars issue each certificate after an audit, and annual surveillance audits keep it valid. The certificate signals a repeatable process, whereas a single good sample proves little.
How Do You Test an Automotive Wiring Harness Before Installation?
You test an automotive wiring harness before installation by running continuity, insulation resistance, and pull tests. A continuity test checks each wire from terminal to terminal against the netlist. The tester flags opens, shorts, and swapped pins before the harness reaches the vehicle. A test board with mating connectors holds the harness and runs the check in seconds. Insulation resistance tests apply 500 volts DC to detect leakage from wire to wire. Pull tests measure the force needed to extract a crimped terminal, using a force gauge. Customer specifications set minimum pull values by wire size, in newtons. Crimp height measurement and microsection checks confirm barrel compression and strand capture. Visual inspection confirms labels, sleeving, and connector locks (TPA and CPA) before the harness is released. Testing catches crimp and pinout errors early, when rework costs minutes instead of vehicle line stoppages.
