An Overview of Injection Molded Surface Finishes
Written byGreg Paulsen
Published October 7, 2020Updated May 14, 2025
Xometry offers SPI injection molding finishes and Mold-Tech and VDI injection molding finish options for polished, matte, to textured molded parts.
A common question we hear at Xometry is, "What do your molded parts look like?" The answer is: however you want it! Xometry has access to a diverse marketplace of molding suppliers and all standard mold finishing options. Our mold finishes include SPI, MoldTech, VDI (EDM), and others. Mold finishes can range from glossy to matte to even patterned. Finishes applied to the surface of the mold cavity transfer to the surface of the molded part. For example, a mold surface that is polished to be reflective will make a reflective (or transparent) part. Mold finishes are different from finishes for CNC machined, or 3D printed parts, where each component is treated individually. Adding a finish or texture can change the tool's price depending on the process required, but it does not alter the price of the individual parts.
The most common finishes used include those from the Society of the Plastics Industry (SPI), which are a set of standard mold finishes starting from heavily polished (SPI A) to semi-gloss (SPI B) to fine and coarse matte (SPI C and SPI D). Where polished textures can increase a parts' cosmetic reflection or transparency on transparent polymers, matte finishes can help provide more subdued tones and even help prevent fingerprints on handled products (e.g., your laptop's frame and keyboard).
Injection molded finishes guide: SPI, Mold-Tech, and VDI 3400
Get your Free Xometry Injection Molding Finishes Card
Submit Your Request
Society of Plastics Industry (SPI) Mold Finishes
Standard SPI Injection Molding Finishes
SPI FinishDescriptionTypical ApplicationsSurface Roughness (Ra µm)
SPI Finish
SPI A-1
Description
Grade #3, 6000 Grit Diamond Buff
High polish or transparent parts, optically clear
0.012 - 0.025
SPI Finish
SPI A-2
Description
Grade #6, 3000 Grit Diamond Buff
0.025 - 0.050
SPI Finish
SPI A-3
Description
Grade #15, 1200 Grit Diamond Buff
High-to-medium polish parts, non-optical lenses
0.050 - 0.100
SPI Finish
SPI B-1
Description
600 Grit Paper
Medium polish parts
0.05 - 0.10
SPI Finish
SPI B-2
Description
400 Grit Paper
Medium polish parts
0.10 - 0.15
SPI Finish
SPI B-3
Description
320 Grit Paper
Medium - low polish parts
0.28 - 0.32
SPI Finish
SPI C-1
Description
600 Stone
Low polish parts
0.35 - 0.40
SPI Finish
SPI C-2
Description
400 Stone
Low polish parts
0.45 - 0.55
SPI Finish
SPI C-3
Description
320 Stone
Low polish parts
0.63 - 0.70
SPI Finish
SPI D-1
Description
Dry Blast Glass Bead
Satin finish
0.80 - 1.00
SPI Finish
SPI D-2
Description
Dry Blast #240 Oxide
Dull finish
1.00 - 2.80
SPI Finish
SPI D-3
Description
Dry Blast #24 Oxide
Dull finish
3.20 - 18.00
Mold-Tech Textured Finishes
Standex Engraving Mold-Tech is a standardized mold texturing option typically used for commercial or saleable goods. Mold-Tech is serialized in four series, A through D. Most commonly the Mold-Tech Series A finishes are used on products as it has a range of fine to coarse matte finishes that do not require laser, masked chemical etching, or other engineered texturing processes. Mold-Tech finishes are categorized by their serial number and texture depth. A more aggressive draft angle is needed with Mold-Tech because mold texturing has more coarse features than SPI finishes, it is recommended to add 1.5° of draft for every 0.001" of texture depth.
Mold-Tech A Finishes
Common Mold-Tech Injection Molding Finishes
Mold-Tech Serial NumberTexture Depth (inch)ApplicationMinimum Draft
MT-11010
0.001"
Application
Dull matte finish
Minimum Draft
1.5°
MT-11020
0.0015"
Application
Coarse matte finish
Minimum Draft
2.25°
MT-11030
0.002"
Application
Coarse matte finish
Minimum Draft
3°
VDI 3400 Surface Finish (known as VDI surface finish) refers to the mold texture standard Verein Deutscher Ingenieure (VDI), the Society of German Engineers. The VDI 3400 surface finish is mainly processed by Electrical Discharge Machining (EDM) when mold machining. VDI is an international standard for mold texturing of matte surfaces. The EDM surface gives a fine-to-coarse grain depending on the selection. VDI is not the same as Mold-Tech, which is applied through various techniques from manual finishing to laser etching to chemical etching with patterns. However, some textures may have near equivalencies, such as SPI D-3, VDI 33, and MT-11020, all looking very similar. In similar aspects, VDI 12 and SPI C-1 are equivalent.
VDI (EDM) Mold Texture Values
Common VDI Injection Molding Finishes
VDI ValueDescriptionApplicationsSurface Roughness (Ra µm)
VDI Value
VDI 12
Description
600 Stone
Applications
Low polish parts
0.40
VDI Value
VDI 15
Description
400 Stone
Applications
Low polish parts
0.56
VDI Value
VDI 18
Description
Applications
Satin finish
0.80
VDI Value
VDI 21
Description
Dry Blast # 240 Oxide
Applications
Dull finish
1.12
VDI Value
VDI 24
Description
Applications
Dull finish
1.60
VDI Value
VDI 27
Description
Applications
Dull finish
2.24
VDI Value
VDI 30
Description
Dry Blast # 24 Oxide
Applications
Dull finish
3.15
VDI Value
VDI 33
Description
Applications
Dull finish
4.50
VDI Value
VDI 36
Description
Applications
Dull finish
6.30
VDI Value
VDI 39
Description
Applications
Dull finish
9.00
VDI Value
VDI 42
Description
Applications
Dull finish
12.50
VDI Value
VDI 45
Description
Applications
Dull finish
18.00
Unless otherwise specified, an injection molded part will typically have an SPI B-2 default finish to enable better part release from the mold and remove tool marks. Surface finishes can be applied to some or all faces; for example, an opaque molded part can have a custom outer surface. The interior, non-cosmetic surface, can remain default. Multiple finishes and texturing can be applied to a single tool cavity if required. Transparent parts are typically polished on both sides to achieve the highest clarity.
Xometry offers a wide variety of surface finishes and additional mold textures to ensure that your parts meet all of their structural and cosmetic requirements. Learn more about our injection molding service.
picture of Greg Paulsen
