Resources3D Printing DesignAll About Direct Metal Laser Sintering (DMLS) 3D Printing
Rebecca Piccoli headshot
Published September 23, 2020
Updated July 22, 2025
Learn more about this process for creating metal parts using a 3D printer.
DMLS part
Direct laser metal sintering (DMLS) has been used by many manufacturers since the late 1990s to make complex metal parts that can’t easily be produced with the likes of stamping or extrusion. This 3D printing process is complex in and of itself, but it’s also a unique technology that’s hard to find an alternative for when it comes to specific components. Whether you’re considering having your own products printed through DMLS, or simply just intrigued by the concept, read on to find out all about this manufacturing method.
What is Direct Metal Laser Sintering 3D Printing?
DMLS is a form of 3D printing, and it uses powder-bed fusion technology to work. It shoots a high-powered fiber laser beam at a single layer of metal powder, which then fuses together onto the previous thin layers. It continues this process until the metal part is fully printed.
You might be wondering where the “sintering” part comes in, as it doesn’t seem to occur. This is actually a misnomer that happened after the translation of DMLS. In Germany (where this tech was created), it was called Direktes Metall-Laser-Schmelzen, schmelzen meaning “to melt.” When translated into English, the “S” became sintering, but because of this slight confusion, you’ll sometimes find this process called direct metal laser melting.
"It's a very difficult process. It's one of those processes where you're not only creating geometry, but you're creating the material. So I often equate that to if you imagine your Hewlett Packard printer that's on your desk, if you still have one of those, imagine that actually creating the paper as well. So, we're doing so many things inside of of a printing printing process that it makes it difficult for some people to comprehend. And with DMLS, it's on an off-the-charts scale."
Matthew Schmidt,
Senior Solutions Engineer
When was DMLS Technology Invented?
Direct Metal Laser Sintering (DMLS) technology was invented in 1995 when a German company called EOS (Electro Optical Systems) first commercialized it. EOS owns the DMLS trademark.
What is Direct Metal Laser Sintering Used for?
Direct Metal Laser Sintering (DMLS) is used for the serial manufacture of complex industrial metal components that cannot be made economically - or at all - with other metal manufacturing technologies, such as CNC machining or metal injection molding. When parts are manufactured using traditional subtractive processes, they often need to be assembled from multiple components. However, DMLS 3D printing can create a monolithic part that eliminates the inherent weaknesses and complexities of assembled parts. DMLS printing is most often used in the aerospace, medical, turbomachinery, and automotive industries.
How Does DMLS 3D Printing Work?
Now that you get the gist, we’re going to get more into the nitty gritty of the DMLS process. The start of the process involves the fiber laser beam, which can have up to 1,000 W of power. It begins scanning the cross-section of a part layer and starts melting the powder particles together.
While there is often one laser beam, some machines have the capacity to shoot out four beams at a time, which quadruples how quickly the process moves along. Usually, a DMLS printer will scan and laser at a speed of around 7 m/s.
Once the first layer is finished, the bed moves down, and another layer of metal powder is put down. Then, the system will fill the printing chamber with an inert gas to prevent the part from oxidizing during the rest of the printing process. After this takes place, the melting of the next layer occurs until the part is complete.
The quality and accuracy of the print comes down to how good the laser and optical components of the printer are. Normally the focal point is between 40 to 100 microns in diameter—which means the smallest feature you can get is 40 microns.
In the picture below, you can get a good idea of how a DMLS printer looks and what components are featured.
DMLS Schematic
DMLS Schematic
How Fast is DMLS 3D Printing?
The speed of a Direct Metal Laser Sintering printer is limited by how quickly the optical mirrors can be repositioned. This speed is often referred to as the “scanning speed.”  It indicates how quickly the laser can move across the powder bed to melt the metal particles. DMLS printers have a scanning speed of ~7 m/s. The largest DMLS machines have four lasers and can thus print in four locations simultaneously. This dramatically improves machine productivity and print speed.
How Accurate is Direct Metal Laser Sintering?
The accuracy of a laser-based powder-bed fusion printer depends primarily on the quality of the optical components and the accuracy of its laser. The typical fiber laser used on DMLS machines has a focal point from 40 to 100 microns in diameter, depending on the machine. This means that the smallest theoretical feature size is 40 microns.
What Materials are Used in the DMLS 3D Printing Process?
There are plenty of different materials you can choose for your DMLS prints. We’ve laid out the most commonly seen choices below:
  • Aluminum alloys (AlSi10Mg): This material is also used in casting, but it’s great for DMLS builds that are designed to have thin walls and fine features. Its good mechanical and thermal properties also make it a popular choice.
  • Inconel 718: This trademarked superalloy is made of nickel and is popular for aerospace uses because of its great corrosion resistance and strength at high temperatures.
  • Titanium (Ti6Al4V): This alloy is great for uses like implants because it’s biocompatible and has excellent corrosion resistance and mechanical properties.
  • Stainless steel (316L): You’ll find this popular steel used for DMLS printing, too. Because of its great corrosion resistance, it often gets turned into parts of acid-producing facilities and other industrial applications.
  • Copper: Its pure form, as well as alloys like CuCP and CuCrZr, can all be printed through DMLS. You’ll usually find it made into heat exchangers and induction coils because of its thermal and conductivity properties.
  • Case-Hardening Steel (20MnCr5): As its name says, this kind of steel can be hardened, which is ideal for DMLS printed parts that need to have serious wear resistance (like gear wheels).
  • Cobalt-Chrome (CoCr): If you’d like the same corrosion resistance and great strength at high temperatures without the nickel content of Inconel 718, this is the material for you.
The following image shows a stainless steel part we printed through DMLS.
Stainless steel part made by Xometry with DMLS 3D printing.
Uses for DMLS and Part Creation
For complex metal parts that can’t as easily be made through other common manufacturing processes (like CNC machining or metal injection molding), DMLS comes in handy. Manufacturers often turn to it for products that’ll be used in the aerospace, medical, turbomachinery, and automotive industries. It’s possible to create separate parts as well as monolithic components that don’t need to be assembled down the road.
Parts being made in a DMLS machine
FAQs
Here are a few answers to some of the most common questions we get asked about DMLS printing.
What are the Advantages of Direct Metal Laser Sintering?
There are plenty of upsides to using a DMLS printer for your products. The main advantages are that it can print parts using a variety of metals and even mixtures of plastic and metal. Its high resolution also makes it easier to create very small, detailed portions of components.
What are the Disadvantages of Direct Metal Laser Sintering?
We can’t give you all the information on this handy 3D printing type without mentioning a couple of little snags. These printers need support materials while they’re printing parts because of how heavy metal can be. Parts are also subject to internal stresses because of how hot the manufacturing process is. Lastly, DMLS printers are strong, but have much lower power lasers than SLM or EBM printers. Therefore, they’re not the best for products that need to be printed quickly and have high layers.
What is the Difference Between DMLS and SLM 3D Printing?
Both of these 3D printing types involve using powder-bed fusion technology. The main difference is that SLM printing often uses even more high-powered lasers than DMLS and is better for high quantities of products. DMLS is best for smaller production runs and parts that require complex details.
What is the Difference Between DMLS and EBM 3D Printing?
Both DMLS and EBM are powder-bed fusion printing technologies. The key difference is that EBM makes use of an electron beam to melt the metal powder. EBM also prints inside a vacuum chamber that enables it to print with materials with very high melting temperatures without the risk of oxidation. DMLS gets around this challenge by printing in an inert gas atmosphere.
What is the Best Metal 3D Printer?
There are three leaders in the metal 3D printing space. Their flagship machines are listed below:
  1. SLM Solutions: The NXG XII 600 is a metal printer with an extremely high production rate. It is specifically designed for serial production. This machine allows metal printing to be a true contender to subtractive technologies like CNC machining.
  2. EOS: The M 100 is a highly accurate printer that can produce parts made from a wide range of materials. It makes use of a fiber laser with a focal point diameter of 40 microns. The M 100 can therefore produce highly accurate parts.
  3. GE Additive: The EBM Q20 Plus is an EBM (Electron Beam Melting) machine specifically designed for producing high-quality aerospace components.GE owns the technology behind EBM 3D printing. This technology can print metal parts made from materials with very high melting temperatures. The EBM process produces parts with negligible residual stresses reducing the need for expensive post-processing
Aside from DMLS printing, our team at Xometry has numerous other 3D printing services we offer to businesses. Get a free quote from our website for options such as plastic 3D printing, fused deposition modeling, selective laser sintering, and carbon DLS.
  1. Inconel® is a registered trademark of Huntington Alloys division of Special Metals Corp., Huntington, WV.
