Types of SLA Printing Technologies
Written byMegan Conniff
16 min read
Published May 19, 2026Updated October 30, 2026
Types of SLA Printing Technologies. Image credit: Shutterstock/MarinaGrigorivna
Stereolithography (SLA) printing technologies represent a category of additive manufacturing that uses light to cure liquid resin into solid three-dimensional objects. SLA printing stands as one of the earliest and most refined methods in the 3D printing ecosystem, producing parts with exceptional surface quality and dimensional accuracy, making it a preferred choice across engineering, medical, and consumer product industries.
SLA printing technologies vary by the light source and curing mechanism used, each offering distinct trade-offs in speed, resolution, and cost. The primary variations include laser-based SLA, which traces patterns using a focused UV laser; Digital Light Processing (DLP), which cures entire layers using a projected light image; and Masked Stereolithography (MSLA), which uses an LCD screen to mask UV light across the build platform. Beyond the three, Continuous Liquid Interface Production (CLIP) achieves high-speed printing through a continuous oxygen-inhibited zone, while Two-Photon Polymerization (2PP) reaches nanoscale resolution through simultaneous absorption of two photons in a focused laser beam. Understanding the differences between one SLA technology and another equips manufacturers and designers with the knowledge to select the right process for precision, throughput, and budget requirements.
1. Laser-Based SLA
Laser-based SLA is a photopolymerization process that uses a focused UV laser beam to selectively cure liquid resin layer by layer. The laser traces each cross-sectional pattern of the part directly onto the resin surface, solidifying it with high spatial accuracy. Layer thickness in laser-based SLA typically ranges from 25 to 100 micrometers, enabling fine surface detail and tight dimensional tolerances of ±0.127 mm or better on well-calibrated systems. The build platform descends incrementally after each layer, exposing fresh resin for the next pass. Laser-based SLA suits applications requiring high-fidelity prototypes, dental models, and intricate engineering components. The process is a foundational form of Laser-based SLA within the broader stereolithography family.
2. Digital Light Processing
Digital Light Processing (DLP) is a resin-based 3D printing process that projects a complete UV light image of each layer onto the resin surface simultaneously, rather than tracing point by point. A digital micromirror device (DMD) chip controls the light pattern, enabling full-layer exposure in a single flash, which significantly reduces print time compared to laser scanning systems. Resolution in DLP is determined by pixel size, typically ranging from 35 to 75 micrometers per pixel, depending on the projector and build area. DLP systems deliver consistent surface quality and are widely used for jewelry casting, dental appliances, and consumer product prototyping. The speed and layer-uniformity advantages position Digital Light Processing as a competitive mid-range photopolymerization technology.
3. Masked Stereolithography
Masked Stereolithography (MSLA) is a UV resin printing process that uses an LCD panel as a photomask, allowing UV light to pass through selectively and cure each layer across the entire build platform at once. The LCD screen defines the geometry of each layer by blocking or transmitting light at the pixel level, achieving XY resolutions as fine as 18 to 50 micrometers on modern consumer and professional systems. MSLA printers are generally more affordable than laser-based SLA or DLP units, with entry-level machines starting at [$150 to $500] and professional-grade systems reaching [$3,000 to $10,000]. The technology is common in dental, jewelry, and miniature figure production. The cost-to-resolution ratio makes Masked Stereolithography one of the most accessible photopolymerization methods available.
SLA printing technologies are precision-focused photopolymerization processes governed by how light is delivered and controlled during curing. Laser SLA traces geometry point by point for high accuracy and larger detailed parts, while DLP and MSLA cure entire layers at once for greater speed. CLIP enables continuous builds with higher throughput and smoother, more isotropic surfaces. Two-Photon Polymerization operates at the micro and nanoscale, achieving sub-micron resolution but with limited build volume and speed. Across all variants, the tradeoff between resolution, speed, and cost depends on the curing mechanism and optical system. In practice, SLA technologies are application-specific tools selected by feature resolution, production volume, and material constraints.
4. Continuous Liquid Interface Production
Continuous Liquid Interface Production (CLIP) is a photopolymerization process that eliminates the traditional layer-by-layer stepping by maintaining a continuous liquid interface of oxygen-inhibited resin at the bottom of the build window. The oxygen-permeable membrane creates a "dead zone" where resin stays liquid, allowing the part to be pulled upward continuously while UV light cures the geometry in real time. CLIP operates at speeds 25 to 100 times faster than conventional SLA, reducing print times from hours to minutes for comparable geometries. Surface finish is smooth and isotropic, as the continuous process avoids visible layer lines. Aerospace, automotive, and medical device manufacturers adopt CLIP for production-grade runs. The speed and mechanical isotropy of Continuous Liquid Interface Production differentiate it from stepped-layer photopolymerization methods.
5. Two-Photon Polymerization
Two-Photon Polymerization (2PP) is an ultra-high-resolution additive manufacturing process that focuses a near-infrared femtosecond laser to a diffraction-limited focal point inside a photosensitive resin, triggering polymerization only where two photons are simultaneously absorbed. The nonlinear optical process confines the curing voxel to dimensions below 100 nanometers, producing structures with resolution far beyond the visible light diffraction limit. Feature sizes achievable with 2PP range from 100 nm to several micrometers, making it suitable for micro-optics, biomedical scaffolds, and MEMS fabrication. Build volumes are small, typically limited to a few cubic millimeters per session, and throughput is slower than DLP or MSLA. The nanoscale precision of Two-Photon Polymerization places it in a specialized tier of additive manufacturing reserved for microengineering and research applications.
What Is SLA 3D Printing?
SLA 3D Printing, or Stereolithography, is an additive manufacturing process that uses a UV light source to cure photopolymer resin into solid three-dimensional parts, layer by layer. Developed by Chuck Hull in 1984, stereolithography stands as the first commercialized 3D printing technology and remains a benchmark for surface finish and dimensional accuracy in resin-based manufacturing. The process begins with a digital 3D model sliced into thin horizontal cross-sections, each representing one cured layer. A UV laser or light source then traces or projects each cross-section onto the surface or base of a liquid resin vat, solidifying the material at that geometry. The build platform shifts by one layer thickness (typically 25 to 150 micrometers) after each cure cycle, progressively building the part from bottom to top or top to bottom depending on the machine configuration. Post-processing includes isopropyl alcohol (IPA) washing to remove uncured resin and UV post-curing to reach full mechanical properties. Part tolerances achievable through stereolithography reach ±0.1 to ±0.3 mm, with surface roughness values as low as Ra 1 to 2 micrometers on optimized systems. SLA 3D Printing offers exceptional precision, making it a preferred choice for industries requiring high-quality, intricate parts.
How Does the SLA 3D Printing Service Work Step by Step?
The SLA 3D printing service works step by step by following the six steps below.
  1. Upload and Review the 3D Model. A CAD file in STL or STEP format is submitted to the service provider. The file undergoes a geometry check for wall thickness, overhangs, and printability before production begins.
  2. Slice the Model. Slicing software divides the model into horizontal layers, 25 to 100 micrometers thick, generating toolpaths and support structure locations for the printer.
  3. Print the Part. The SLA machine exposes each resin layer to a UV laser or light source, curing the cross-section geometry. Layer-by-layer, the build platform descends or ascends until the full part is formed.
  4. Wash the Part. The freshly printed part is submerged in isopropyl alcohol (IPA) for 5 to 15 minutes to dissolve uncured resin from surfaces and internal channels.
  5. Post-Cure the Part. The washed part is placed in a UV curing chamber for 15 to 60 minutes, completing polymerization and achieving target mechanical properties such as tensile strength and hardness.
  6. Remove Supports and Finish. Support structures are manually removed, and surfaces are sanded or primed to meet the required finish specification. SLA 3D printing service ensures the final part meets high-quality standards, ready for use in various applications.
What Materials Are Used in SLA Resin Printing?
Materials used in SLA Resin printing are listed below.
  • Standard Resin: Standard resin offers moderate tensile strength (40 to 65 MPa) and a smooth surface finish. It suits visual prototypes, display models, and concept verification parts where mechanical load is minimal.
  • Tough Resin: Tough resin is formulated to absorb impact and resist deformation, simulating ABS-like behavior with elongation at break values reaching 20 to 30%. Functional prototypes, snap-fit assemblies, and enclosures benefit from the material.
  • Flexible Resin: Flexible resin produces rubber-like parts with Shore A hardness ranging from 40 to 80, depending on formulation. Wearable components, gaskets, and grip interfaces are common applications.
  • High-Temperature Resin: High-temperature resin withstands heat deflection temperatures (HDT) of 200°C to 300°C after post-curing. Mold tooling, under-hood automotive components, and heat-resistant jigs rely on the material's thermal stability.
  • Biocompatible Resin: Biocompatible resin meets ISO 10993 or Class I/II medical device standards for skin or short-term mucosal contact. Dental splints, surgical guides, and hearing aid shells are produced with the material in dental and medical manufacturing environments.
  • Castable Resin: Castable resin burns out cleanly at temperatures reaching 700°C to 800°C, leaving no ash residue. Jewelry manufacturing and investment casting workflows use the material as a pattern medium in SLA Resin printing.
How Do Different SLA Technologies Compare in Performance and Cost?
A performance and cost comparison from laser-based SLA to DLP, MSLA, CLIP, and 2PP reveals distinct trade-offs across accuracy, throughput, and investment. Laser-based systems lead in accuracy for large-format parts, DLP balances speed and resolution for mid-scale production, and MSLA delivers the lowest entry cost. CLIP prioritizes speed for production runs, while 2PP serves nanoscale research applications at the highest cost per part.
The comparison across key performance indicators is shown in the table below.
What Are the Advantages and Disadvantages of SLA Printing Technologies?
The advantages and disadvantages of SLA printing technologies are listed below.
Advantages
  • High Dimensional Accuracy: SLA systems achieve tolerances of ±0.1 to ±0.3 mm, making the process reliable for precision prototypes and medical components where geometry fidelity is critical.
  • Smooth Surface Finish: Layer lines in SLA parts measure Ra 1 to 2 micrometers on calibrated systems, reducing the need for extensive post-processing compared to filament-based methods.
  • Wide Material Range: Photopolymer resin formulations cover standard, tough, flexible, high-temperature, biocompatible, and castable variants, addressing a broad range of end-use requirements.
  • Fine Feature Resolution: MSLA and DLP systems reach XY resolutions as fine as 18 to 35 micrometers, enabling intricate lattice structures, thin walls, and detailed text on small parts.
Disadvantages
  • Material Cost: SLA resins range from [$50 to $400+] per liter, depending on formulation, significantly higher than FDM filament priced at [$20 to $80] per kilogram.
  • Post-Processing Requirements: Every SLA part requires IPA washing and UV post-curing before use, adding 30 to 90 minutes of handling time per build.
  • Resin Brittleness: Standard SLA resins exhibit low impact resistance, with notched Izod values often below 20 J/m, limiting suitability for load-bearing or impact-prone applications without tougher formulations.
  • Limited Build Volume: Most desktop SLA systems offer build volumes from 130 × 80 × 200 mm to 290 × 163 × 400 mm, restricting the production of large single-piece components.
What Industries Use SLA 3D Printing Technologies?
Industries that use SLA 3D printing technologies are listed below.
  • Healthcare and Medical Devices: SLA produces patient-specific anatomical models, surgical guides, and prosthetic sockets with tolerances reaching ±0.1 mm. Hospitals and medical device firms use biocompatible resins meeting ISO 10993 standards for direct patient contact applications.
  • Dental: Dental labs and clinics use SLA and MSLA to print crown and bridge models, clear aligner molds, and implant surgical guides. Digital dental workflows cut model production time from days to under 24 hours.
  • Aerospace and Defense: Aerospace engineers use SLA for aerodynamic wind tunnel models, tooling masters, and functional verification prototypes. The surface accuracy of SLA parts supports computational fluid dynamics (CFD) correlation studies.
  • Automotive: Automotive designers use SLA prototypes for form and fit validation of interior trim, lighting bezels, and under-hood housings before committing to injection molding tooling.
  • Jewelry and Consumer Goods: Jewelry manufacturers use castable SLA resin patterns for investment casting of gold, silver, and platinum pieces, replacing traditional wax carving with digital design workflows.
  • Education and Research: Universities and R&D laboratories use SLA to produce microfluidic devices, optical components, and experimental apparatus at resolutions not achievable with filament-based printers.
How Is SLA Used in Rapid Prototyping and Manufacturing?
SLA is used in rapid prototyping and manufacturing by producing dimensionally accurate, smooth-surface parts from digital CAD files within hours, compressing design iteration cycles that once required days or weeks of machining or molding. The process accepts design revisions without tooling changes, allowing engineering teams to test multiple geometry variants in a single sprint. Lead times from file submission to finished part on professional SLA systems range from 24 to 72 hours, depending on part complexity and build volume.
SLA serves as a bridge technology between design validation and full-scale production in the manufacturing context. Investment casting patterns, injection mold inserts, jigs, and fixtures produced through SLA carry tolerances of ±0.1 to ±0.3 mm, sufficient for short-run production use. The CLIP variant of SLA extends the technology further into production by achieving per-part throughput rates comparable to low-volume injection molding. Medical device manufacturers, dental labs, and aerospace suppliers integrate SLA into production workflows where part complexity and geometry accuracy outweigh the per-part resin material cost.
What Are the Differences Between SLA and Other 3D Printing Technologies?
The differences between SLA and other 3D printing technologies lie in the materials, methods of curing, and the resulting surface finish and mechanical properties. Resin-based photopolymerization in SLA yields finer surface finishes and tighter tolerances than extrusion or powder-bed processes, at the cost of material brittleness and post-processing steps.
A comparison of SLA and other 3D printing technologies is shown in the table below.
How Does SLA Compare to FDM and SLS Printing Methods?
SLA, compared to FDM and SLS printing methods differ most in surface finish, material options, and mechanical isotropy. SLA delivers the smoothest surfaces and finest resolution at the cost of resin brittleness and mandatory post-processing. FDM offers the lowest material and equipment cost with thermoplastic durability, but visible layer lines. SLS produces isotropic nylon parts without support structures, but at a higher per-part cost and rougher surfaces. The key differences lie in surface quality and the complexity of post-processing when SLA is compared to FDM.
A comparison of SLA, FDM, and SLS printing methods is shown in the table below.
What Are the Key Factors To Consider When Choosing an SLA Printer?
To consider the key factors when choosing an SLA printer, follow the seven steps below.
  1. Assess the Required XY Resolution. Identify the smallest feature size the application demands. Desktop MSLA printers reach 18 to 35 µm per pixel for dental and jewelry work, while standard laser SLA systems range from 140 to 200 µm for larger industrial parts.
  2. Evaluate Build Volume. Match the printer's build platform to the largest part or batch size needed. Consumer MSLA units offer volumes near 130 × 80 × 200 mm, while industrial laser SLA systems reach 750 × 650 × 550 mm or larger.
  3. Confirm Resin Compatibility. Check whether the printer uses open or proprietary resin cartridges. Open-resin systems reduce consumable cost and expand material options, including third-party tough, castable, and biocompatible formulations.
  4. Calculate Total Cost of Ownership. Factor in equipment price ([$150 to $250,000+]), resin cost ([$50 to $400] per liter), maintenance, and replacement components (LCD screens, FEP films) to determine the true per-part production expense.
  5. Check Layer Thickness Range. Confirm the printer supports the layer thickness needed for the application, typically 25 to 100 µm for detail work and up to 150 µm for faster structural prints.
  6. Review Post-Processing Requirements. Determine whether the workflow includes a dedicated wash-and-cure station. Wash and cure units add [$30 to $500] to the setup cost but are necessary for consistent part quality.
  7. Verify Software and File Format Support. Confirm that the slicer software supports STL, OBJ, or STEP imports and provides control over support density, exposure settings, and layer parameters for the target resin.
What Is the Future of SLA and Stereolithography Technologies?
The future of SLA and stereolithography technologies is directed toward faster throughput, expanded material libraries, and tighter integration with digital manufacturing workflows. Continuous printing methods (CLIP and similar oxygen-inhibition approaches) are advancing to reduce print time per part by 50 to 100 times compared to stepped-layer SLA, moving photopolymerization closer to injection molding cycle rates for small geometries. New resin formulations are extending SLA into high-performance material categories, including ceramic-loaded resins for firing into alumina parts, silicone-based photopolymers, and resins with heat deflection temperatures exceeding 300°C. Hybrid systems combining multi-material jetting with SLA photopolymerization are under active development, targeting simultaneous printing of rigid and flexible regions in a single build. MSLA systems are advancing through higher-resolution monochrome LCD panels, with 8K screens yielding pixel sizes below 20 µm at commercially accessible price points below [$1,000]. Industrial SLA platforms are incorporating inline quality inspection through laser scanning and vision systems to detect layer defects in real time. The convergence of faster curing, new materials, and process monitoring is positioning stereolithography for expanded roles in additive manufacturing production environments.
Can SLA Printing Achieve Industrial-Level Production Quality?
Yes, SLA printing achieves industrial-level production quality in specific part categories and production volumes. Industrial SLA systems from manufacturers operating large-format platforms produce parts with dimensional tolerances of ±0.1 to ±0.2 mm and surface roughness values below Ra 2 µm, meeting the quality thresholds required for aerospace, medical device, and automotive supplier certifications. Dental laboratories run MSLA and DLP printers in validated production environments, printing hundreds of patient-specific models and surgical guides per day with consistent accuracy. CLIP-based systems produce functional elastomeric and rigid parts at rates of thousands of units per week for consumer product and footwear manufacturers, competing directly with short-run injection molding on per-part cost at volumes below 10,000 units. Limitations remain in maximum part size, resin brittleness relative to engineering thermoplastics, and UV degradation of photopolymer mechanical properties over time. SLA serves better as a prototyping or bridge production method than a primary mass manufacturing process for large-volume structural components requiring thermoplastic or metal performance.
Is SLA Better Than Other 3D Printing Methods for High-Detail Parts?
Yes, SLA is the leading 3D printing method for high-detail parts where surface finish and geometric accuracy are the primary requirements. Laser-based SLA, DLP, and MSLA systems achieve XY resolutions from 18 to 200 µm and surface roughness values of Ra 1 to 2 µm, outperforming FDM (Ra 10 to 30 µm) and SLS (Ra 8 to 15 µm) in surface quality without additional finishing. Fine features (0.2 to 0.5 mm wall thickness), sharp edges, and embossed text are reliably reproducible on calibrated SLA systems, making the process the standard in dental, jewelry, and micro-component manufacturing. Scenarios where SLA excels include clear or translucent optical prototypes, orthodontic models, hearing aid shells, and consumer product appearance models intended for photography or functional fit checks. FDM outperforms SLA in impact resistance and material toughness for structural applications, and SLS outperforms SLA in producing complex geometries without support structures. The resolution and finish capability of SLA printing remain unmatched among widely accessible additive manufacturing methods for fine-detail output.
