The Weird Thing About Gauge
Written byGreg Paulsen
2 min read
Published September 18, 2020Updated August 6, 2026
How to think of Gauge in terms of measurement
When ordering raw material supplies, such as Aluminum or Stainless Steel stock, the sizes are specified in standard units such as inches, using whole numbers and decimals to define the shape. For example, If you order a waterjet cut blank of Aluminum 6061-T6 that is 4.50” x 4.25” x 8.00”, then there is a reasonable expectation to get material that size on delivery.
However, when it comes to sheet metal you will often hear materials referred to in gauge. What is a gauge anyways, and why is it such a strange unit of measurement?
Gauge was established in the first metal rolling mills of North America as a reference number, defined individually, which correlated with materials and thicknesses produced at that mill. Ultimately trade increased and these sizes became more agreed-upon, leaving the legacy that is used today. Also used for wire diameters, gauge units are more symbolic where they progressively represent thicker metal pieces the lower the number is, such as a 7 gauge piece of steel at 0.1793” or the thinner 22 gauge at 0.0299”.
Compared to modern systems, gauge units can get even more confusing because thickness varies between materials of the same gauge. This is because gauge is correlated with weight. Also, gauge is defined differently between ferrous metals like steel and non-ferrous metals like aluminum. So a 12 gauge plate of steel is over 0.020” thicker than the same gauge aluminum. The lookup table below can be helpful when discussing gauge when providing sheet metal services. Note that this list is not comprehensive, for example, gauge has moved up to 0.5000” which naturally makes it 0000000 gauge. Yes, that is seven zeros with no decimals or commas.
Try Our Sheet Metal Gauge Converter Tool
Gauge Measurements Across Different Metals
GaugeSteelGalvanizedStainlessAluminum
Gauge
3
Steel
0.2391 in. / 6.07 mm
Galvanized
Stainless
Gauge
4
Steel
0.2242 in. / 5.69 mm
Galvanized
Stainless
Gauge
5
Steel
0.2092 in. / 5.31 mm
Galvanized
Stainless
Gauge
6
Steel
0.1943 in. / 4.94 mm
Galvanized
Stainless
0.1620 in. / 4.11 mm
Gauge
7
Steel
0.1793 in. / 4.55 mm
Galvanized
Stainless
0.1875 in. / 4.76 mm
0.1443 in. / 3.67 mm
Gauge
8
Steel
0.1644 in. / 4.18 mm
Galvanized
0.1681 in. / 4.27 mm
Stainless
0.1719 in. / 4.37 mm
0.1285 in. / 3.26 mm
Gauge
9
Steel
0.1495 in. / 3.80 mm
Galvanized
0.1532 in. / 3.89 mm
Stainless
0.1563 in. / 3.97 mm
0.1144 in. / 2.91 mm
Gauge
10
Steel
0.1345 in. / 3.42 mm
Galvanized
0.1382 in. / 3.51 mm
Stainless
0.1406 in. / 3.57 mm
0.1019 in. / 2.59 mm
Gauge
11
Steel
0.1196 in. / 3.04 mm
Galvanized
0.1233 in. / 3.13 mm
Stainless
0.1250 in. / 3.18 mm
0.0907 in. / 2.30 mm
Gauge
12
Steel
0.1046 in. / 2.66 mm
Galvanized
0.1084 in. / 2.75 mm
Stainless
0.1094 in. / 2.78 mm
0.0808 in. / 2.05 mm
Gauge
13
Steel
0.0897 in. / 2.28 mm
Galvanized
0.0934 in. / 2.37 mm
Stainless
0.0940 in. / 2.39 mm
0.0720 in. / 1.83 mm
Gauge
14
Steel
0.0747 in. / 1.90 mm
Galvanized
0.0785 in. / 1.99 mm
Stainless
0.0781 in. / 1.98 mm
0.0641 in. / 1.63 mm
Gauge
15
Steel
0.0673 in. / 1.71 mm
Galvanized
0.0710 in. / 1.80 mm
Stainless
0.0700 in. / 1.78 mm
0.0570 in. / 1.45 mm
Gauge
16
Steel
0.0598 in. / 1.52 mm
Galvanized
0.0635 in. / 1.61 mm
Stainless
0.0625 in. / 1.59 mm
0.0508 in. / 1.29 mm
Gauge
17
Steel
0.0538 in. / 1.37 mm
Galvanized
0.0575 in. / 1.46 mm
Stainless
0.0560 in. / 1.42 mm
0.0450 in. / 1.14 mm
Gauge
18
Steel
0.0478 in. / 1.21 mm
Galvanized
0.0516 in. / 1.31 mm
Stainless
0.0500 in. / 1.27 mm
0.0403 in. / 1.02 mm
Gauge
19
Steel
0.0418 in. / 1.06 mm
Galvanized
0.0456 in. / 1.16 mm
Stainless
0.0440 in. / 1.12 mm
0.0360 in. / 0.91 mm
Gauge
20
Steel
0.0359 in. / 0.91 mm
Galvanized
0.0396 in. / 1.01 mm
Stainless
0.0375 in. / 0.95 mm
0.0320 in. / 0.81 mm
Gauge
21
Steel
0.0329 in. / 0.84 mm
Galvanized
0.0366 in. / 0.93 mm
Stainless
0.0340 in. / 0.86 mm
0.0280 in. / 0.71 mm
Gauge
22
Steel
0.0299 in. / 0.76 mm
Galvanized
0.0336 in. / 0.85 mm
Stainless
0.0310 in. / 0.79 mm
0.0250 in. / 0.64 mm
Gauge
23
Steel
0.0269 in. / 0.68 mm
Galvanized
0.0306 in. / 0.78 mm
Stainless
0.0230 in. / 0.58 mm
Gauge
24
Steel
0.0239 in. / 0.61 mm
Galvanized
0.0276 in. / 0.70 mm
Stainless
0.0200 in. / 0.51 mm
Gauge
25
Steel
0.0209 in. / 0.53 mm
Galvanized
0.0247 in. / 0.63 mm
Stainless
0.0220 in. / 0.56 mm
0.0180 in. / 0.46 mm
Gauge
26
Steel
0.0179 in. / 0.45 mm
Galvanized
0.0217 in. / 0.55 mm
Stainless
0.0190 in. / 0.48 mm
0.0170 in. / 0.43 mm
Gauge
28
Steel
0.0149 in. / 0.38 mm
Galvanized
0.0187 in. / 0.47 mm
Stainless
0.0160 in. / 0.41 mm
0.0126 in. / 0.32 mm
Gauge may seem archaic but it is used often enough that it's worth understanding the ins and outs.
picture of Greg Paulsen
