Injection Molding vs. 3D Printing: Differences and Comparison
Written byKat de Naoum
Rebecca Piccoli
Updated byRebecca Piccoli
Published September 23, 2020Updated June 29, 2026
Comparing the benefits and price breakdown of two popular manufacturing types
An injection molded screw for manufacturing
As we see new and innovative technologies disrupt the manufacturing industry, it’s a good time for us to explore how older methods compare—and when both should be used. Two manufacturing processes that usually get weighed up against one another are injection molding and 3D printing, especially since each brings specific advantages, downsides, and budget considerations to the table.
While additive manufacturing has given many engineers and manufacturers pause, it’s not necessarily a solution for all companies’ needs. Here’s how these two compare financially and how they stack up in terms of what they can offer.
Injection Molding Definition and Comparison to 3D Printing
Injection molding is one type of manufacturing process that works by funneling molten plastic into molds of certain shapes and designs. They cool and you’re left with different parts — which can be pretty complex. This technique gels well with plastics and it’s cost-effective compared to a lot of other methods.
Need an Injection Molded Part?
How It Works
  1. First, the mold is shut and tonnage is applied to both halves or however many sections your mold is split into.
  2. Then, the plastic (or other material mixture) is heated into a molten hot state and injected into the mold.
  3. Once the right amount is in, the machine will apply pressure for a set time limit to the mold to make sure the plastic has reached every nook and cranny.
  4. Then the mold will go through a cooling phase where the plastic shape will harden.
  5. After it’s hardened and cooled down, the molds will be opened and the object will be ejected and continue on to get processed or finished.
In the diagram below, you can see a drawing of what some injection molding machines look like and how each component fits together.
What are the Advantages of Plastic Injection Molding Compared to 3D Printing?
Some of the advantages of plastic injection molding compared to 3D printing are:
  1. Plastic injection molding allows for repeatability, and produced parts have a smoother surface finish than 3D printing.
  2. Plastic injection molding can produce larger volumes of parts than 3D printing.
What are the Disadvantages of Plastic Injection Molding Compared to 3D Printing?
The disadvantage of plastic injection molding compared to 3D printing are:
  1. Plastic injection molding has a higher entry cost than 3D printing.
  2. It is expensive and time-consuming to make design changes, especially when there is a mistake to be rectified with plastic injection molding.
What Is 3D Printing?
This is a large family of technologies that use printers for additive manufacturing—and it’s forever advancing, becoming quicker, easier, and more affordable. It’s possible to make very complex parts and customized components through this layer-by-layer methodology. You can 3D print with almost any material, from plastics and polymers to glass and metal. It’s a popular choice for prototyping as the costs are pretty low once the machinery is taken care of.
How It Works
There isn’t a step-by-step guide that covers all types of 3D printing, as each machine operates differently and has its own way of creating parts. In general, these machines will lay down one layer of material at a time, cure it, and continue layering until the part is fully built.
"3D printing is a good process to prototype in and confirm ‘proof of concept.’ Although the initial tooling costs can be higher, injection molding becomes more cost-effective over large production runs, helping you achieve economies of scale. However, injection molding may be justified at low volumes if specific materials or mechanical properties are needed for testing purposes."
Kyra StawsonSenior Solutions Engineer
What are the Advantages of 3D Printing Compared to Plastic Injection Molding?
These are some of the advantages of 3D printing over plastic injection molding:
  1. 3D printing produces parts with a higher degree of tolerance than those of plastic injection molding.
  2. 3D printing can produce parts faster compared to plastic injection molding.
What are the Disadvantages of 3D Printing Compared to Plastic Injection Molding?
Some of the disadvantages of 3D printing over plastic injection molding:
  1. Plastic injection molding is suited for high-volume production compared to 3D printing.
  2. The 3D printers have smaller build areas compared to plastic injection molding machines. This limits 3D printers in producing large objects.
Comparison Table Between 3D Printing and Injection Molding
The table below will give you a look at how injection molding and 3D printing compare in different aspects and the pros and cons of each.
3D Printing vs. Injection Molding Comparisons
3D Printing vs. Plastic Injection Molding: Lead Cost Comparison
The break-even point hovers between 250 and 2,000 parts when it comes to finding the point at which injection molding and 3D printing are most cost-effective. To give you a better picture, we’ve analyzed a few case studies below. But before jumping into those, you’ll want to heavily consider the following factors when you’re deciding between these two types of manufacturing, as these tend to be the most important:
  • Surface design: The bigger the surface area the more you’ll have to pay and the longer it’ll take to create your part when it comes to 3D printing. This isn’t as much of an issue for injection molding.
  • Volume order: Like with any manufacturing process, the more volume you have, the less you usually have to pay per part. 3D printed parts tend to be more affordable (around 10% to 20% less) than injection molded parts when you have an order of 20,000 or less. The price seems to be on par when you hit 40,000 to 50,000 parts.
  • Tooling costs: When you’re looking at the costs of iterating products, 3D printing comes out on top as far as affordability goes. It’s much more expensive to change the designs (and thus the molds) of injection molded parts.
Now, we’ll take a look at a couple of product production examples we’ve priced out using our Instant Quoting Engine at Xometry. This looks at the cost of creating a drone leg, potentiometer knob, and junction housing and how their prices compare depending on quantity when you 3D print them or create them through injection molding.
Example 1: Drone Leg Pricing
  • The bounding box is 146.69 mm x 139.57 mm x 33.00 mm (5.775 in x 5.495 in x 1.299 in).
  • The drone’s leg geometry means it'll cost around $32 for one part or $24 per part for 250 parts through selective laser sintering (SLS). HP Multi Jet Fusion is a little less expensive per part after 250 units.
  • The price per unit with injection molding hits break-even pretty fast, so scaling is doable and cost-effective. Think $3 per part at quantities over 8,000 — far cheaper than 3D printing.
  • After 250 units, it’s better to look at injection molding for speed and cost-effectiveness.
See the graph below to see how different 3D printing methods and injection molding prices compare:
Example 2: Potentiometer Knob Pricing
  • We’re looking at a potentiometer knob with a bounding box of 16.81 mm x 15.20 mm x 15.20 mm (0.662 in x 0.598 in x 0.598 in)—it’s around the size of a thimble for reference.
  • Because it’s so tiny, the cost of 3D printing remains competitive with injection molding until you hit 2,000 units.
  • At around 30 units, you’ll want to consider HP MJF printing over SLS. This would equal out to about $3.45 per unit and is great if you’re looking to stick with lower quantities.
  • When you need more than 2,000 units, injection molding will save you thousands of dollars, as it costs around $0.80 per unit (without tooling).
Take a look at the graph below, which compares methodologies for making a potentiometer:
Example 3: Junction Housing Pricing
  • This example looks at junction housing with a bounding box of 215.84 mm x 172.44 mm x 68.18 mm (8.498 in x 6.789 in x 2.684 in).
  • Because junction housing has a pretty large surface area, you’ll get higher costs from the get-go, even with 3D printing. You can expect a little over $200 per part made from nylon with SLS. Then at 30 units, you’ll get a better cost with CNC machining.
  • Urethane casting and HP MJF offer better prices between 30 and 250 units, but injection molding ends up being the cheapest if you have a large quantity.
  • It can cost around $10,000 in tooling but after 250 units, it’s still cheaper to use injection molding.
Take a look at the graph below for the price breakdown between methods and costs:
3D Printing vs. Plastic Injection Molding: Speed Comparison
An injection molding machine will not be useful until the mold is ready for production. This causes a delay that 3D printing technology can capitalize on in terms of speed. But once the mold has been designed, injection molding becomes the best choice. The setup allows more parts to be produced in a shorter period of time.
3D Printing vs. Plastic Injection Molding: Volume Comparison
3D printing is a slower process, so fewer parts can be produced compared to plastic injection molding (with a functional mold). Plastic injection molding makes large-scale production of parts possible.
3D Printing vs. Plastic Injection Molding: Materials Comparison
When it comes to the materials for the design and build process, both offer a wide range of materials. It should be noted that the specific material needed depends on what is being made.
What are the Mutual Alternatives to 3D Printing and Plastic Injection Molding?
One mutual alternative to 3D printing and plastic injection molding is:
  • Vacuum Forming: Vacuum forming technology uses a vacuum to stretch a heated sheet (heated to its glass transition temperature) over the surface of a mold. At this temperature, it becomes soft (not melted) and malleable. Vacuum forming is similar to 3D printing, in that they are both used for the rapid prototyping of designs. Also, vacuum forming and plastic injection molding produce parts with good tolerance.
What are the Similarities Between 3D Printing and Plastic Injection Molding?
Some similarities between 3D printing and plastic injection molding are:
  1. In both 3D printing and injection molding, the thermoplastics are heated to the melting temperature.
  2. A large range of materials is readily available for both processes.
What are the Other Comparisons for 3D Printing Besides Plastic Injection Molding?
Another comparison for 3D printing is:
  • 3D Printing vs. CNC Machining: This is a subtractive manufacturing process that involves the removal of materials from a solid workpiece until the final object is formed. Like 3D printing, CNC machining can also produce functional parts.
What are the Other Comparisons for Plastic Injection Molding Besides 3D Printing?
Another comparison for plastic injection molding is:
  • Plastic Injection Molding vs.Compression Molding: Compression molding uses a two-part mold, where molds are heated to help cure the product while also heating the charge before compression. Like plastic injection molding, compression molding also produces plastic parts using heat and pressure.
Frequently Asked Questions About Injection Molding and 3D Printing
