How Does a Hydraulic System Work
Written byMegan Conniff
19 min read
Published November 24, 2026
How Does a Hydraulic System Work. Image credit: Shutterstock/Ilya Platonov
A hydraulic system works by using pressurized fluid to transmit force from one point to another, enabling machines to perform heavy mechanical tasks with precision and control. The hydraulic system operates on Pascal's Law, which states that pressure applied to a confined fluid transmits equally in all directions, allowing a small input force to generate a significantly larger output force at the actuator. Hydraulic systems appear in excavators, aircraft landing gear, industrial presses, and injection molding machines because the fluid medium delivers a consistent, controllable force regardless of load orientation.
Hydraulic systems are used in machines because they produce far greater force-to-size ratios than purely mechanical or pneumatic alternatives, with operating pressures commonly ranging from 1,000 psi to 5,000 psi in industrial equipment. The system type determines the application, with open-center, closed-center, and hydrostatic configurations each serving distinct operational requirements. A pump, reservoir, control valves, actuator, and hydraulic fluid form the core methodology through which energy converts into mechanical motion. The primary benefits include high power density, smooth speed control, overload protection through pressure relief valves, and the ability to transmit force over long distances without mechanical linkages.
1. Pump Pushes Fluid From Reservoir
A hydraulic pump draws fluid from the reservoir and forces it into the system, converting mechanical energy into hydraulic flow. Gear, vane, and piston pumps generate flow rates from 1 GPM to over 100 GPM, depending on system size. Without continuous fluid displacement from the pump, no pressure builds, and no actuator movement occurs.
2. Input Force Creates Pressure
Resistance encountered by the flowing fluid creates pressure within the system, measured in psi or bar. Pressure originates from the load or restriction opposing fluid flow at the actuator or control valve, not from the pump directly. A pump rated at 3,000 psi reaches that pressure only when the system load demands it.
3. Pressure Travels Through Fluid
Pressurized fluid transmits force through hoses, tubes, and fittings with negligible energy loss over distance. Pascal's Law confirms that pressure applied at one point in a sealed fluid system transmits equally to every connected surface. Steel tubing rated to 6,000 psi and hydraulic hoses rated from 1,500 psi to 10,000 psi carry the pressurized fluid safely.
4. Fluid Reaches Actuator
Directional control valves route pressurized fluid to the correct actuator port, determining whether the cylinder extends, retracts, or holds position. Fluid volume delivered to the actuator determines travel speed, while pressure determines the applied force. A closed-center valve locks the actuator in position when no command signal is present.
5. Actuator Produces Movement
The actuator converts hydraulic pressure into mechanical force or motion through a cylinder or hydraulic motor. A double-acting cylinder with a 4-inch bore at 2,500 psi generates approximately 31,416 pounds of push force. Return fluid travels back to the reservoir after the stroke completes, finishing the closed-loop cycle.
What Is a Hydraulic System?
A hydraulic system is a power transmission technology that uses pressurized incompressible fluid to generate, control, and deliver mechanical force to actuators performing physical work. The system operates on Pascal's Law, established in 1647, confirming that pressure on a confined fluid transmits equally in all directions. Standard industrial hydraulic systems operate at 1,000 psi to 5,000 psi, with specialized systems reaching 10,000 psi to 15,000 psi in aerospace applications. The fluid serves simultaneously as the power carrier, lubricant, and heat transfer agent, distinguishing hydraulic systems from mechanical or pneumatic alternatives. Petroleum-based hydraulic oil with viscosity grades from ISO VG 32 to ISO VG 68 fills the reservoir, pump, valve block, and actuator circuit continuously during operation. Force multiplication through piston area ratios makes it possible to lift loads exceeding 50 tons using a compact pump driven by a 50-horsepower motor. Hydraulic systems serve aerospace, construction, manufacturing, agriculture, and marine industries because no equivalent technology delivers the same combination of force density, controllability, and design flexibility.
What Are the Main Components of a Hydraulic System?
The main components of a hydraulic system are listed below.
  • Hydraulic Reservoir: The reservoir stores hydraulic fluid from 5 gallons to over 500 gallons, dissipates heat from returning fluid, and provides a steady supply to the pump inlet without cavitation.
  • Hydraulic Pump: The pump converts mechanical energy into hydraulic flow, with gear, vane, and piston pumps covering flow ranges from 1 GPM to 150 GPM at pressures from 1,500 psi to 6,000 psi.
  • Control Valves: Directional, pressure relief, and flow control valves manage fluid routing, maximum operating pressure, and actuator speed. Pressure relief valves are set from 500 psi to 5,000 psi to prevent system overpressure.
  • Actuators: Hydraulic cylinders and motors convert fluid pressure into mechanical force or torque. A cylinder with a 3-inch bore at 2,000 psi generates approximately 14,137 pounds of linear force.
  • Hydraulic Fluid: Petroleum-based or synthetic fluid transmits pressure while lubricating internal surfaces. ISO VG 46 is the most commonly specified viscosity grade for industrial systems operating at 40°C to 80°C.
  • Filters and Seals: Filters rated at 3 to 25 microns remove particulate contamination, while seals prevent leakage at pressures up to 6,000 psi.
Is the Pump Responsible for Creating Flow in the System?
Yes, the pump creates flow in a hydraulic system, but it does not directly create pressure. The pump displaces a fixed or variable volume of fluid per revolution, establishing a flow rate in GPM. Pressure develops only in response to the resistance the flowing fluid encounters at the load, actuator, or closed valve. A gear pump at 1,800 RPM with 0.5 cubic inches per revolution displacement delivers approximately 3.9 GPM regardless of system pressure. Increasing pump speed raises flow and actuator speed, while increasing system load raises pressure without changing pump flow rate. Variable displacement piston pumps adjust output volume automatically in response to system demand, reducing flow to near zero when the actuator reaches full extension and maintaining standby pressure from 200 psi to 500 psi without energy waste. The pump originates all fluid movement in the circuit, and load resistance downstream transforms that movement into working pressure that performs mechanical work.
Why Are Hydraulic Systems Used in Machines?
Hydraulic systems are used in machines because they deliver exceptionally high force output relative to component size, a characteristic no purely mechanical or electromechanical system matches at equivalent scale. A hydraulic cylinder with a 6-inch bore at 3,000 psi produces over 84,823 pounds of force from a unit weighing under 50 pounds. Machines rely on hydraulic systems for precise, stepless speed and force control across variable output ranges. A proportional flow control valve adjusts actuator speed continuously from 0 to maximum, giving operators exact positioning authority over loads exceeding several tons without discrete steps or complex mechanical transmissions. Hydraulic systems also provide inherent overload protection through pressure relief valves preset from 1,500 psi to 5,000 psi, redirecting excess fluid to the reservoir automatically when an overload occurs. No operator intervention is required to protect downstream components. The combination of high force density, smooth controllability, and overload protection explains why construction excavators, aircraft control surfaces, industrial presses, and agricultural equipment all depend on hydraulic power as a core engineering solution.
How Do Hydraulic Machines Multiply Force?
Hydraulic machines multiply force by applying pressure across different piston surface areas within the same sealed circuit, following Pascal's Law, where Force equals Pressure multiplied by Area (F = P × A). A small pump piston generating 2,000 psi transmits that exact pressure to a large actuator cylinder, where the greater surface area produces a proportionally larger output force. A pump piston with a 1-square-inch area receiving 100 pounds of input generates 100 psi system pressure. Acting on a cylinder bore with a 20-square-inch area, the same 100 psi produces 2,000 pounds of output force, a 20-to-1 multiplication ratio. The trade-off is travel distance: the large cylinder moves a shorter distance than the input piston for the same fluid volume displaced. Hydraulic press systems in metal stamping exploit the multiplication principle at an industrial scale, with cylinder bore diameters reaching 24 inches at 3,000 psi to generate forces exceeding 1,000 tons. The force multiplication ratio scales directly with the actuator-to-pump piston area ratio across every application size.
Are Hydraulic Systems More Powerful Than Mechanical Systems of the Same Size?
Yes, hydraulic systems are more powerful than mechanical systems of the same physical size. A hydraulic motor delivering 50 horsepower occupies approximately one-third the volume and one-fourth the weight of a mechanical gearbox transmitting equivalent power at the same output torque. Hydraulic actuators achieve force levels of tens of thousands of pounds from cylinders compact enough to fit inside a vehicle chassis or aircraft wing, where no mechanical alternative packages equally. Energy travels at pressures from 1,000 psi to 5,000 psi through hoses and compact valves, eliminating the rigid shafts, gears, and bearings that add mass to mechanical power trains. Mechanical systems maintain efficiency advantages in steady-state transmission, with spur gear drives reaching 95% to 99% efficiency compared to 70% to 85% for hydraulic systems due to fluid friction and internal leakage losses. The efficiency gap narrows in variable-speed applications where hydraulic systems avoid throttling losses of fixed-ratio mechanical drives, confirming that power density and application context together determine which technology performs better at a given size.
Why Are Hydraulic Fluids Important in Hydraulic Systems?
Hydraulic fluids are important because the fluid simultaneously serves as the energy transmission medium, internal lubricant, heat transfer agent, and sealant across the entire operating cycle. No other single element performs as many simultaneous functions, making fluid selection and condition directly responsible for system performance and component service life. The fluid transmits pressure with minimal compressibility, quantified by a bulk modulus ranging from 200,000 psi to 300,000 psi for petroleum-based hydraulic oils. The high bulk modulus ensures pressure changes at the pump translate immediately into actuator force without energy absorption lag. The fluid also lubricates pump gears, valve spools, and cylinder surfaces, with viscosity maintained from ISO VG 32 to ISO VG 68 at operating temperatures from 40°C to 80°C. Heat generated by pressure drops across valves and pump friction accumulates in the fluid, which carries thermal energy to the reservoir and heat exchanger for dissipation. Contaminated or degraded Hydraulic Fluids account for 70% to 80% of all hydraulic system failures, confirming that fluid condition governs overall system reliability more than any other maintenance variable.
How Do Hydraulic Fluids Transfer Power in Industrial Machines?
Hydraulic fluids transfer power in industrial machines by acting as an incompressible medium that carries pressure energy from the pump through the valve circuit to the actuator with minimal energy loss. The fluid fills the entire enclosed circuit continuously, meaning pressure generated at the pump reaches the cylinder or motor in milliseconds, regardless of circuit distance. Power transfer efficiency depends on fluid viscosity at operating temperature. Viscosity too low allows internal leakage across pump and valve clearances of 0.001 inch to 0.003 inch, dropping volumetric efficiency below 90% and wasting output as heat. Viscosity too high increases flow resistance and pressure drop across valve passages. ISO VG 46 at 50°C maintains approximately 46 centistokes, balancing leakage control with acceptable flow resistance in most industrial applications. Additive packages in industrial fluids improve transfer reliability by preventing oxidation, foam, and surface wear. Anti-wear additives containing zinc dialkyldithiophosphate (ZDDP) protect pump pistons and valve lands operating under contact pressures from 50,000 psi to 200,000 psi, maintaining the dimensional precision that volumetric efficiency requires throughout the service interval.
Are Hydraulic Fluids Essential for Pressure and Lubrication Control?
Yes, hydraulic fluids are essential for pressure control and lubrication, and neither function operates independently. The same fluid transmitting working pressure from 1,000 psi to 5,000 psi simultaneously lubricates every internal moving surface it contacts within the pump, valves, and actuator. Pressure control depends on fluid incompressibility. Petroleum-based hydraulic oil compresses less than 0.5% per 1,000 psi of applied pressure, making it an effective transmission medium that responds to load changes without absorbing significant energy. Degraded fluid with a reduced bulk modulus slows pressure response and decreases actuator positioning accuracy measurably. Lubrication control depends on maintaining adequate viscosity at operating temperature. Pump pistons, shoes, and swash plates rely on a hydrodynamic fluid film of 1 to 10 micrometers to prevent metal-to-metal contact at relative surface velocities from 1 to 10 meters per second. Allowing fluid viscosity to drop below 10 centistokes at maximum operating temperature collapses the film and reduces pump service life from 10,000 hours to below 2,000 hours.
How Do Plastic Injection Molding Machines Use Hydraulic Systems?
Plastic injection molding machines use hydraulic systems to generate and control the forces required for mold clamping, plastic injection, pack hold, and part ejection, with each phase demanding precise force and speed control at production cycle times of seconds per shot. The clamping unit uses large-bore hydraulic cylinders with bore diameters from 8 inches to 24 inches to hold mold halves closed against injection pressure. A mold with a 100-square-inch projected area at 15,000 psi injection pressure requires at least 750 tons of clamping force to prevent flash formation at the parting line. The hydraulic clamp cylinder generates equivalent force at system pressures from 2,000 psi to 3,500 psi through piston area advantage. The injection unit drives the screw forward at velocities from 50 mm per second to 500 mm per second, forcing molten polymer through runners and gates at fill pressures from 10,000 psi to 30,000 psi. Proportional hydraulic valves control injection speed and holding pressure independently during each phase, giving process engineers the precision needed to maintain dimensional tolerances in Plastic Injection Molding Machines producing parts to ±0.001-inch specifications.
Why Is Hydraulic Pressure Critical in Plastic Injection Molding Machines?
Hydraulic pressure is critical in plastic injection molding machines because every phase of the cycle requires a distinct pressure level, and the hydraulic system must switch from one to another within milliseconds to maintain part quality and dimensional consistency. Hydraulic pressure from 2,000 psi to 3,500 psi must exceed the separating force generated by melt pressure inside the cavity during clamping. Insufficient clamp pressure causes flash defects at the parting line, while excess pressure accelerates mold wear. During injection, hydraulic pressure drives fill at 10,000 psi to 30,000 psi and then maintains pack pressure from 5,000 psi to 15,000 psi to compensate for polymer shrinkage during cooling. Pack pressure directly controls part weight, sink mark depth, and dimensional stability. A 5% variation in pack pressure produces measurable changes in part mass and feature dimensions for precision components (medical device housings and optical lenses). Pressure consistency across thousands of cycles, maintained by closed-loop hydraulic control, determines whether the machine produces parts within specification across high-volume production runs.
Do Plastic Injection Molding Machines Rely on Hydraulic Force for Clamping?
Yes, plastic injection hydraulic molding machines rely on hydraulic force for clamping, with clamp cylinders generating forces from 5 tons to over 4,000 tons through direct-acting or toggle-assisted hydraulic arrangements. A direct hydraulic clamp uses a single large-bore cylinder behind the moving platen to generate clamping force directly from hydraulic pressure. A toggle clamp uses a hydraulic cylinder to actuate a mechanical linkage that multiplies cylinder force by a ratio of 20:1 to 40:1, reducing the required bore size and system pressure during clamping. All-electric machines use servo motor ball-screw drives for clamping in precision applications, but hydraulic machines retain dominance above 1,000 tons where electric servo systems cannot match hydraulic force density economically. Hybrid machines combine electric injection units with hydraulic clamp cylinders to capture speed and repeatability advantages while retaining hydraulic force capacity for high-tonnage requirements. The dependence on hydraulic clamping force remains a defining characteristic of full-hydraulic machines at every tonnage class from 5 tons to 4,000 tons.
How Does a Tensile Testing Machine Use a Hydraulic System to Apply Force?
A tensile testing machine uses a hydraulic system to apply precisely controlled tensile, compressive, or cyclic forces to a test specimen by converting hydraulic pressure into a calibrated load delivered through the crosshead and grips. The hydraulic actuator extends or retracts at programmable rates while a load cell measures applied force continuously from 0 to the machine's rated capacity. A servo-hydraulic testing machine connects a hydraulic power unit generating 3,000 psi to 5,000 psi to a precision servo valve that modulates actuator movement in response to electronic control signals. The servo valve adjusts fluid flow at update frequencies from 50 Hz to 1,000 Hz, enabling accurate testing across loading rates from quasi-static (0.001 inch per minute) to dynamic fatigue cycling at 100 Hz. Hydraulic testing machines reach force capacities from 10 kN to 2,000 kN, exceeding the range of electromechanical screw-drive machines without requiring proportionally larger motors. The actuator's force output remains consistent regardless of crosshead position or test speed, giving materials engineers a stable loading condition for evaluating tensile strength, yield strength, and elongation across metals, polymers, and composites tested on a Tensile Testing Machine.
How Is Hydraulic Force Generated Inside a Tensile Testing Machine?
Hydraulic force inside a tensile testing machine is generated when the power unit pressurizes the actuator cylinder, and the resulting pressure acting on the piston bore area produces a linear force transmitted through the crosshead to the specimen. Force follows F = P × A, where P is actuator pressure and A is effective piston area. A testing machine with a 4-inch bore actuator at 3,000 psi generates approximately 37,699 pounds (167.6 kN) of theoretical force, measured by the load cell after accounting for friction and seal resistance losses. The servo valve controls fluid flow direction and rate into the cylinder, determining crosshead travel direction and the rate at which load increases on the specimen. Closed-loop electronics compare the actual load cell signal to the commanded target at 50 Hz to 1,000 Hz update rates and adjust the servo valve to maintain target force within ±0.5% of the indicated load. The power unit maintains standby pressure at 500 psi to 1,000 psi from one test to the next, ensuring full actuator force is available within milliseconds of the next test command.
Does a Tensile Testing Machine Use Hydraulic Pressure for Strength Testing?
Yes, tensile testing machines use hydraulic pressure as the direct source of force for strength testing. The load cell measures actual specimen force independently of the hydraulic pressure reading, providing calibrated output traceable to ASTM E4 and ISO 7500-1 standards with accuracy of ±0.5% of indicated force. Hydraulic servo machines hold clear advantages over electromechanical alternatives in dynamic and fatigue testing. Cyclic tests requiring force amplitudes from ±1 kN to ±500 kN at 1 Hz to 100 Hz exceed the continuous capability of most screw-drive systems, while servo-hydraulic actuators sustain the required amplitude without thermal overload. Sinusoidal, triangular, trapezoidal, and random load spectra are achievable by modulating hydraulic pressure through the servo valve under computer control. Static tensile testing to ASTM E8, compressive testing of concrete to ASTM C39, and flexural testing all rely on consistent hydraulic force delivered at prescribed loading rates, confirming hydraulic pressure as the fundamental energy source for quantifying material strength across every standard test method.
What Are Common Examples of Hydraulic Systems?
The common examples of hydraulic systems are listed below.
  • Excavators and Backhoes: Hydraulic excavators control the boom, arm, and bucket through circuits at 3,500 psi to 5,000 psi, generating bucket breakout forces from 10,000 to over 40,000 pounds. Swing motors, travel drives, and blade cylinders all operate from the same hydraulic power circuit.
  • Automotive Braking Systems: Hydraulic disc brakes transmit pedal force through brake fluid to caliper pistons at line pressures from 300 psi to 1,500 psi, multiplying driver input by 20:1 to 40:1 through the master cylinder and booster.
  • Aircraft Flight Control Systems: Commercial aircraft hydraulic systems at 3,000 psi to 5,000 psi actuate ailerons, elevators, rudders, flaps, and landing gear through redundant circuits that prevent total control loss from a single failure.
  • Hydraulic Press Machines: Metal forming presses generate forces from 10 tons to 5,000 tons at 1,500 psi to 4,500 psi for blanking, deep drawing, and forging operations.
  • Agricultural Equipment: Tractor three-point hitches and loader arms operate at 2,000 psi to 3,000 psi, lifting implements from 500 pounds to over 10,000 pounds with precise depth and draft control.
How Do Car Lifts and Heavy Equipment Use Hydraulics?
Car lifts use hydraulic cylinders or scissor mechanisms to raise vehicles from 3,500 pounds to over 18,000 pounds, with two-post and four-post designs operating at 1,500 psi to 3,000 psi to reach lifting heights from 70 inches to 80 inches. The circuit includes a motor-driven gear pump, pressure relief valve, directional solenoid valve, and a mechanical safety lock that engages automatically at the raised position to prevent uncontrolled lowering. Heavy construction equipment applies the same principles on a larger scale. A 20-ton crawler excavator uses a main hydraulic pump delivering 80 GPM to 120 GPM at 5,000 psi to power boom, stick, and bucket cylinders simultaneously, while swing and travel motors operate from the same circuit through priority valves. Total installed hydraulic power in a 20-ton excavator reaches 150 horsepower to 250 horsepower, converting engine output into controllable mechanical force at the attachment with cycle times of 4 to 6 seconds per dig cycle. Wheel loaders, bulldozers, motor graders, and articulated dump trucks all depend on hydraulic circuits for lift arm control, steering, blade pitch, and transmission clutch engagement.
Do Hydraulic Systems Power Construction and Industrial Equipment?
Yes, hydraulic systems power the majority of construction and industrial equipment globally, and no equivalent technology has displaced hydraulic power transmission in high-force, mobile, or variable-load applications at comparable cost and reliability. Industrial equipment relying on hydraulic power includes injection molding machines, metal stamping presses, die casting machines, hydraulic bending brakes, and material handling systems. A 500-ton hydraulic stamping press at 3,500 psi performs blanking and forming on steel sheet at 10 to 60 strokes per minute, producing forces no pneumatic actuator delivers at that scale without prohibitive cost. The dominance of hydraulic power in construction and industrial settings traces to four performance characteristics no alternative technology simultaneously matches: force density exceeding 1,000 horsepower per cubic foot of actuator volume, infinitely variable speed control from 0 to maximum, inherent overload protection through relief valves, and structural simplicity across a force range from 50 pounds to 5,000 tons. Electric and hybrid systems supplement hydraulic circuits in emissions-sensitive applications, but hydraulic power remains the primary force generation technology across every global market.
