Hardness is a material’s ability to resist deformation at its surface. A measurement is taken of the resulting indentation and converted to a hardness value relative to the hardness scale of the particular test. Many different standardized hardness tests exist, with each having an area of applicability to different types of materials, such as metals, ceramics, or rubbers. Measuring hardness has a number of benefits in comparing materials and providing quality control in manufacturing and hardening processes. This article will discuss hardness testing, its definition, how it works, its types, and benefits.
What Is Hardness Testing?
Hardness testing measures a material’s resistance to permanent deformation at its surface, by pressing a harder material into it. It is used in a number of industries for material comparison and selection, as well as quality control of a manufacturing or hardening process. A specifically manufactured indenter, with chosen dimensions, is used to press into the material being tested, with a prescribed force. The pressing time is also important in the hardness test.
Hardness is not a fundamental physical property of a material, but rather a measured characteristic. It can however provide some valuable information about the strength and durability of a material, depending on the application it is intended for.
How Does Hardness Testing Work?
Hardness testing works by pressing a standardized, hard instrument into the material that is being tested. The instrument, called an indenter, is pressed into the sample for a standardized length of time (a number of seconds), and with a specific load (force) behind it. When the indenter is pressed into the material, it deforms the surface of the material by a measurable amount. This deformation is then measured, and the measurement is used to assign a hardness value to the material according to the test’s specific scale.
What Type of Materials Undergo Hardness Testing?
Hardness testing can be applied to various types of materials, some of which are listed below:
- Metals and alloys.
- Ceramics.
- Elastomers.
- Polymers and plastics.
- Films.
- Rocks and minerals.
What Is the Importance of Hardness Testing?
Hardness testing is important for a number of different reasons. The hardness of a material can be a critical parameter in its application. This can be the case for metal components used in cutting and grinding or on the opposite extreme, for rubbers used for shock absorption. It is important to be able to measure and compare the hardness of materials objectively.
Having an objective, standardized hardness value for a material is important to allow quality control during manufacturing. Each unit would need to be within an acceptable range of the specified hardness. Furthermore, these objective hardness values allow for the comparison of different materials and are therefore important for material selection to match the needs of an application.
What Are the Benefits of Hardness Testing?
Hardness testing provides a valuable measure of a material characteristic with a number of benefits, including:
- An automated hardness testing machine allows hardness to be measured relatively simply.
- To provide meaningful hardness readings for a wide variety of materials, from soft to hard.
- For some applications, the hardness of a material is the key characteristic that is valuable to know. This can be measured directly, rather than inferred by a physical property.
What Are the Challenges of Hardness Testing?
Hardness testing does have some limitations and challenges that can affect the accuracy and repeatability of hardness results, some of which are listed below:
- It is necessary to have properly prepared the surface of the sample to be measured, usually by grinding and polishing. The surface condition has a significant influence on the hardness reading, so improper surface preparation can give inaccurate or spurious readings.
- Most hardness tests are designed for flat surfaces, so curved surfaces do present a challenge. There are some correction factors that need to be applied to compensate for an indentation on a curved surface.
- The size of the indentation can be difficult to ascertain objectively, particularly when manually reading the size of micro impressions through an eyepiece. This is mainly an issue with older machines. The latest models have cameras and software packages to automatically focus correctly, and display the edge of the impression clearly on a connected computer screen.
- If the prescribed minimum distances between indentations are not followed according to the testing standards, the results of the hardness test will be affected. This is also true of an indentation too close to the edge of a sample.
What Are the Different Types of Hardness Test Methods?
There are a number of different hardness test methods, each suited to a certain scale of measurement, or type of material. Therefore, different methods should be selected according to the substance being tested. The most common hardness tests are explained below:
- Rockwell: Developed to give a quick reading, mainly for metallic samples. The depth of the deformation made by the indenter is measured, and a deeper indentation is assigned a lower number, indicating a softer material. Two broad types of tests are used: the Rockwell superficial hardness and the Rockwell regular hardness tests.
- Brinell: A spherical indenter is used, and the diameter of the resulting indentation is measured to give the hardness value. It is generally used for testing larger samples, or samples that are not perfectly homogenous since it causes a larger indentation that is less sensitive to local variations in material hardness.
- Vickers: Uses a diamond pyramid to make a square indentation on the surface of the material being tested. The diagonal of the indentation is measured optically and is converted to the hardness value. The Vickers hardness test can be applied for micro-testing.
- Knoop: Specifically used to test thin or brittle materials, as it gives a meaningful reading with a shallow indentation. It uses an elongated pyramid to make the impression, with the measurement of the long diagonal used to calculate the Knoop hardness. It is used for micro-hardness testing.
- Mohs: A scale from 1 to 10 that provides an indication of the relative hardness of minerals based on how easily they can be scratched. A mineral’s hardness is measured by attempting to scratch it with materials of known Mohs hardness and ranking it accordingly.
- Shore: Is used for softer materials such as elastomers and plastics. A spring-loaded indenter (called a durometer) is pressed into the material sample, and the depth of penetration is converted to a hardness value.
What Are Hardness Testing Loads?
The hardness testing load is the load (“force”) that is applied to the indenter when pressing into the material being tested. The depth or size of the deformation made by the indenter will depend directly on the load that was used to press it in. This load is applied by a machine, a hardness testing device. The automatic machine will apply a load according to the parameters given by the operator.
The load that is applied will depend on the size of the sample and the type of material being tested. Harder materials like metals will need higher loads in order to make an easily measurable depression. Softer materials like thermoplastics will need lower loads to produce an appropriately-sized indentation.
How Do Hardness Testing Loads Work?
Each hardness testing method has a range of loads that are applicable to the use of the test. Some tests, like the Vickers hardness test, can be used on a macro scale as well as a micro scale. The loads required are listed in Table 1 below:
| Method | Load Range | Standard |
Method Brinell | Load Range 1 kgf –3,000 kgf | Standard ASTM E10, ISO 6506 |
Method Rockwell | Load Range 15 kgf–150 kgf | Standard ASTM E18, ISO 6508 |
Method Knoop | Load Range 1 gf–1 kgf | Standard ASTM E384, ISO 4545 |
Method Vickers | Load Range 1 gf–1 kgf
1 gf–120 kgf
10 gf–100 kgf | Standard ASTM E384
ASTM E384
ISO 6507 |
Table 1: Different Hardness Test Methods and Their Corresponding Loads
How Is a Hardness Test Different From a Ductility Test?
A hardness test uses a limited compressive force to apply a small deformation to the surface of a material, in order to assign a relative value for the material’s hardness. However, a ductility test uses a destructive tensile force to measure the amount of plastic deformation that a material can withstand before breaking.
Both types of tests apply a load to cause plastic deformation in a material. However, the direction of the load is different (compressive vs. tensile) and the extent of the load is different (limited to surface indentation vs. complete yield).
What Does Indentation Mean in Hardness Testing?
Indentation in hardness testing means a permanent deformation in the surface of the sample material. This indentation will have a measurable geometry depending on the shape of the instrument used to make the indentation. The measurable aspects of an indentation, which are converted into a hardness value, can be the depth of the indentation, or a variation of the diagonal of the size of the indentation of the surface.
How is Hardness Testing Measured?
Hardness testing is measured according to different scales, which depend on the exact hardness testing method being used. For all common scales, the hardness of a material is proportional to the hardness value—a harder material will have a higher hardness value. For some hardness tests, the scale selected is fairly arbitrary. For example, the Rockwell hardness test has a range of hardness values from 0 to 100 depending on the depth of the indentation. However, each hardness test defines its scale differently.
A hardness value does not have a unit but is simply a value on the scale associated with a particular test. However, hardness values are quoted with a designation of which scale and test were used to generate them. For instance, HR is Rockwell hardness, HB is Brinell hardness, HV is Vickers hardness, and so on.
What Are the Hardness Testing Standards?
There are various standards available for the different hardness testing methods. Generally, the internationally accepted standards for hardness testing are those issued by ASTM (American Society for Testing Materials) and ISO (International Organization for Standardization). The two standards are very similar for each corresponding type of hardness test but have small differences between them for details such as the minimum thickness of the sample. The common ASTM and ISO standards for the four most popular hardness tests in metallic materials are listed below:
- ASTM E10: This standard covers Brinell hardness testing in metallic samples.
- ASTM E18: This standard includes the various ways that Rockwell hardness can be measured by standard methods, specifically for metallic materials.
- ASTM E384: This standard is for hardness testing on a micro-scale, and therefore includes the Vickers and Knoop hardness tests.
- ISO 6506: This standard mirrors ASTM E10, as it contains the standard method for measuring the Brinell hardness of metals.
- ISO 6507: This standard contains the details for the Vickers hardness test in metallic materials.
- ISO 6508: This standard is very similar to ASTM E18, as it deals with the Rockwell hardness tests, both superficial and regular, for metallic samples.
- ISO 4545: This standard covers Knoop hardness testing for metals.
What Is the Static Hardness Testing Method?
Static hardness testing uses an indenter that is pressed and held against the surface of the material being tested. The indenter is therefore static for most of the test and causes a permanent deformation of the surface of the material. In static hardness testing, therefore, the indenter pushes through the elastic deformation of the material and forces a plastic deformation. This is the most common approach, and the widely used Rockwell, Brinell, Vickers, and Knoop hardness tests are all static hardness tests.
What Is the Dynamic Hardness Testing Method?
Dynamic hardness testing measures the rebound velocity of a moving indenter as it hits the material sample and rebounds. The hardness value obtained is determined from the rebound distance or the rebound velocity. It is typically applied in cases in which a static hardness test (completed on a testing machine) may not be practical, such as out in the field, or when large specimens are involved. Dynamic hardness testing is usually not as precise as static hardness testing.
Can Hardness Testing Be Conducted on Any Types of Materials?
No, hardness testing cannot be performed on any type of material. Broadly speaking, hardness testing can be carried out on almost every type of material, but there are some exceptions for which it cannot be applied. For instance, the material must be solid, or at least gel-like. Even some solid materials cannot be tested for hardness, such as if they have a highly irregular surface, or are non-homogeneous.
