Silicone Rubber: Materials, Properties, Industrial Manufacturing Guide
Silicone rubber is an inorganic elastomer synthesized from a polysiloxane backbone composed of alternating silicon and oxygen bonds, reinforced with organic methyl, vinyl, or phenyl side groups. Silicone rubber differs from carbon-based synthetic rubbers through its inorganic backbone structure, delivering thermal stability, chemical inertness, and biocompatibility across a service temperature range from -60°C to 230°C. The material resists degradation from UV radiation, ozone, moisture, and extreme thermal cycling, establishing it as a high-performance elastomer across aerospace, medical, automotive, and electronics engineering sectors.
The guide covers the core chemistry and molecular structure of silicone rubber, its physical and mechanical properties, and its industrial manufacturing and processing methods. Curing systems, compounding techniques, and specialty grade formulations are examined across standard and high-performance applications. Comparative analysis against carbon-based elastomers clarifies the material selection criteria for temperature-critical and biocompatible engineering systems. The content addresses the full scope of silicone rubber from raw material synthesis through final application deployment across major industrial sectors.
What Is Silicone Rubber in Industrial Polymer Engineering Systems?
The silicone rubber in industrial polymer engineering systems is listed below.
- Siloxane-Based Elastomer: A polymer network built on alternating silicon and oxygen bonds (Si–O–Si), with organic side groups (methyl, vinyl, or phenyl) attached to the silicon atoms. The siloxane bond energy of 452 kJ/mol exceeds the carbon-carbon bond energy of 346 kJ/mol, providing greater thermal and oxidative stability across service environments.
- Inorganic Backbone Structure: The Si–O–Si backbone carries bond angles of 130° to 160°, producing a highly flexible molecular chain that retains elasticity from -60°C to 230°C without permanent deformation. The inorganic nature of the backbone eliminates carbon oxidation pathways, reducing degradation rates in high-temperature and UV-exposed environments.
- High-Performance Elastomer Classification: Silicone rubber classifies under ASTM D1418 as MQ, VMQ, PMQ, PVMQ, and FVMQ grades, depending on side group composition and specialty additive content. The classification places silicone rubber above standard synthetic rubber grades in thermal ceiling, biocompatibility, and long-term compression set resistance across aerospace, medical, and electronics engineering applications.
What Chemical Structure Defines Silicone Rubber Performance?
The chemical structure that defines silicone rubber performance is the alternating silicon-oxygen (Si–O–Si) backbone chain, combined with organic methyl or vinyl side groups attached to each silicon atom. The Si–O–Si bond carries an energy of 452 kJ/mol and a bond angle ranging from 130° to 160°, producing a highly flexible molecular chain that retains elasticity across extreme thermal conditions. Methyl side groups (–CH₃) dominate standard grades, providing chemical inertness, hydrophobicity, and low surface energy across service environments. Vinyl side groups (–CH=CH₂) introduce crosslinking sites during peroxide or platinum-catalyzed curing, directly improving tensile strength, tear resistance, and compression set performance. The ratio of methyl to vinyl side groups determines the mechanical and thermal ceiling of the final silicone rubber grade, depending on the target application requirements across aerospace, medical, and industrial engineering systems.
Is Silicone Rubber Chemically Different From Natural Rubber?
Yes, silicone rubber is chemically different from natural rubber. Silicone rubber carries an inorganic Si–O–Si backbone with organic side groups, while natural rubber carries a fully carbon-based polyisoprene chain (C₅H₈)ₙ with no silicon content. The Si–O–Si bond energy of 452 kJ/mol exceeds the C–C bond energy of 346 kJ/mol in natural rubber, giving silicone rubber superior thermal and oxidative stability across service temperatures from -60°C to 230°C against natural rubber's limit of 80°C. Natural rubber strain-crystallizes under mechanical stress, delivering higher tensile strength to 30 MPa against silicone rubber's unfilled tensile strength of 5 to 10 MPa. Silicone rubber resists UV, ozone, and thermal degradation without additives, while natural rubber requires antioxidant and antiozonant compounding to match comparable outdoor durability.
Is Silicone Rubber Classified as a Synthetic Rubber?
Yes, silicone rubber is classified as a synthetic rubber. Silicone rubber occupies a distinct category separate from carbon-chain synthetic elastomers. Standard synthetic elastomers (Styrene Butadiene Rubber, Nitrile Butadiene Rubber, and Neoprene) carry fully organic carbon-based polymer backbones, while silicone rubber carries an inorganic Si–O–Si backbone with organic side groups. The ASTM D1418 classification system places silicone rubber under the M-class elastomer family, distinct from the R-class designation assigned to carbon-backbone elastomers. Silicone rubber delivers a service temperature range from -60°C to 230°C, far exceeding the thermal ceiling of standard elastomer grades capped from 82°C to 150°C, depending on grade. The biocompatibility, electrical insulation, and UV resistance of silicone rubber position it at the high-performance tier of the broader Synthetic Rubber classification system.
What Core Physical Properties Define Silicone Rubber?
The core physical properties that define silicone rubber are listed below.
- Thermal Stability: Maintains mechanical integrity from -60°C to 230°C in standard grades, with specialty formulations extending beyond 300°C through Si–O–Si bond energy of 452 kJ/mol.
- Tensile Strength: Increasing to 10 to 15 MPa with reinforcing fumed silica filler additions, depending on compound formulation, unfilled grades deliver 5 to 10 MPa.
- Compression Set Resistance: Retains the lowest long-term compression set among major elastomer grades, ranging from 10% to 30% after 70 hours at 175°C, depending on the cure system.
- Elongation at Break: Achieves elongation values from 100% to 800%, reflecting Si–O–Si backbone flexibility across cryogenic and high-temperature service conditions.
- Hardness: Ranges from 10 Shore A to 80 Shore A, covering soft medical-grade seals at 10 to 20 Shore A and firm industrial gaskets at 60 to 80 Shore A.
- Chemical Resistance: Resists dilute acids, alkalis, water, ozone, and UV radiation, with limited resistance to concentrated acids and hydrocarbon fuels requiring FVMQ grades.
- Electrical Insulation: Delivers dielectric strength from 15 to 25 kV/mm, maintaining stable electrical insulation across temperature extremes from -60°C to 230°C.
How Does Silicone Rubber Perform Under Thermal Stress?
Silicone rubber performs with exceptional consistency under thermal stress due to the Si–O–Si backbone bond energy of 452 kJ/mol, resisting chain scission and oxidative degradation at temperatures where carbon-based elastomers fail. Standard grades retain mechanical integrity from -60°C to 230°C, maintaining flexibility and dimensional stability across continuous thermal cycling. Specialty phenyl-modified grades (PVMQ) extend the lower service limit to -100°C, while high-consistency rubber formulations exceed 300°C in short-term thermal exposure. Silicone rubber retains compression set values from 10% to 30% after 70 hours at 175°C, depending on cure system and filler loading across aerospace, automotive, and industrial sealing applications.
How about Chemical Stress? Silicone rubber resists dilute acids, alkalis, water, ozone, and UV exposure across standard chemical environments without swelling or surface degradation. Concentrated acids, hydrocarbon fuels, and aromatic solvents require fluorosilicone (FVMQ) formulations for adequate protection in aggressive chemical service conditions.
Does Silicone Rubber Maintain Flexibility Across Extreme Temperature Ranges?
Yes, silicone rubber maintains flexibility across extreme temperature ranges. The Si–O–Si backbone bond angle, ranging from 130° to 160°, produces a highly mobile molecular chain that resists stiffening at cryogenic temperatures and softening at elevated thermal loads. Standard VMQ grades retain elongation values from 100% to 800% across a continuous service range from -60°C to 230°C without permanent deformation. Specialty phenyl-modified grades (PVMQ) extend low-temperature flexibility to -100°C, maintaining elastomeric behavior in cryogenic aerospace and defense sealing applications. Carbon-based elastomers (Styrene Butadiene Rubber and Nitrile Butadiene Rubber) lose flexibility below -40°C and above 120°C, confirming silicone rubber's superiority in extreme temperature flexibility across industrial engineering systems.
What Controls Silicone Rubber Synthesis in Industrial Production Systems?
Silicone rubber synthesis in industrial production systems is controlled through the seven steps listed below.
- Extract and Refine Silicon Raw Materials. Silicon dioxide (SiO₂) undergoes carbothermic reduction at temperatures exceeding 1,800°C, yielding metallurgical-grade silicon at 98% purity. The refined silicon reacts with methyl chloride through the Müller-Rochow Process to produce chlorosilane intermediates.
- Hydrolyze Chlorosilane Intermediates. Dimethyldichlorosilane undergoes controlled hydrolysis in water, producing silanol intermediates and hydrochloric acid as a byproduct. The hydrolysis reaction rate determines the molecular weight distribution of the resulting polysiloxane network.
- Condense Silanol Groups into Polysiloxane Chains. Silanol intermediates undergo condensation polymerization, forming linear polydimethylsiloxane (PDMS) chains with Si–O–Si repeating units. Cyclic siloxane byproducts are removed through vacuum stripping to control final polymer purity.
- Control Molecular Weight Through Ring-Opening Polymerization. Cyclic siloxane oligomers (D₄) undergo ring-opening polymerization using acid or base catalysts, producing high molecular weight gum ranging from 300,000 to 800,000 g/mol. The molecular weight directly determines the mechanical strength and crosslink density of the final compound.
- Incorporate Vinyl or Phenyl Side Groups. Vinyl side groups (–CH=CH₂) are introduced through copolymerization with vinylmethyldichlorosilane, providing crosslinking sites for peroxide or platinum-catalyzed curing systems. Phenyl side groups improve low-temperature flexibility, producing PVMQ and FVMQ specialty grades.
- Compound with Fillers and Additives. Fumed silica filler at loading levels from 10% to 40% by weight reinforces tensile strength from 5 to 10 MPa in unfilled grades to 10 to 15 MPa in reinforced compounds. Pigments, heat stabilizers, and flame retardants are dispersed through a two-roll mill or internal mixer equipment.
- Cure Through Vulcanization. Peroxide curing at 120°C to 200°C or platinum-catalyzed addition curing at 80°C to 150°C establishes the final crosslink network. Post-curing at 200°C to 250°C for 2 to 4 hours stabilizes compression set resistance across the final silicone rubber grade.
How Is Silicon Converted Into Industrial Silicone Compounds?
To convert silicon into industrial silicone compounds, follow the four steps below.
- Reduce Quartz to Elemental Silicon. Silicon dioxide (SiO₂) undergoes carbothermic reduction in an electric arc furnace at temperatures exceeding 1,800°C, yielding metallurgical-grade silicon at 98% purity. Carbon electrodes supply the reduction energy, producing molten silicon and carbon monoxide as a byproduct.
- Purify Metallurgical-Grade Silicon. Metallurgical-grade silicon undergoes trichlorosilane (SiHCl₃) distillation purification, removing metallic impurities (iron, aluminum, and calcium) to achieve electronic or chemical-grade silicon at 99.9% purity. Purity level determines the final performance grade of the silicone compound produced.
- React Silicon with Methyl Chloride. Purified silicon reacts with methyl chloride (CH₃Cl) at 250°C to 350°C through the Müller-Rochow Direct Process, producing a mixture of chlorosilane intermediates. Dimethyldichlorosilane (CH₃)₂SiCl₂ portrays the primary product, accounting for 70% to 90% of the chlorosilane output.
- Separate and Fractionate Chlorosilanes. The chlorosilane mixture undergoes fractional distillation to isolate dimethyldichlorosilane from trimethylchlorosilane, methyltrichlorosilane, and other byproduct fractions. Separation purity directly determines the molecular weight distribution and chain architecture of the final polysiloxane network.
How Are Siloxane Polymers Formed Into Elastomers?
Siloxane polymers are formed into elastomers through the six steps below.
- Hydrolyze Chlorosilane Intermediates. Dimethyldichlorosilane reacts with controlled amounts of water, producing silanol intermediates (HO–Si(CH₃)₂–OH) and hydrochloric acid as a byproduct. The water-to-chlorosilane ratio determines the degree of polymerization and molecular weight distribution of the resulting silanol chain.
- Condense Silanol Groups into Linear Chains. Silanol intermediates undergo condensation polymerization, releasing water molecules and forming linear polydimethylsiloxane (PDMS) chains with repeating Si–O–Si units. Chain length and molecular weight range from 300,000 to 800,000 g/mol, depending on catalyst type and reaction conditions.
- Remove Cyclic Byproducts. Cyclic siloxane oligomers (D₃, D₄, D₅) formed during condensation are removed through vacuum stripping and redistribution reactions at elevated temperatures. Byproduct removal controls final polymer purity and prevents interference with downstream curing reactions.
- Introduce Crosslinking Sites. Vinyl side groups (–CH=CH₂) are incorporated through copolymerization with vinylmethyldichlorosilane, providing reactive sites for peroxide or platinum-catalyzed crosslinking. Crosslink site density directly controls the final hardness, elongation, and compression set of the cured elastomer network.
- Apply Curing Agent to Form Elastomer Network. Peroxide curing agents (benzoyl peroxide or dicumyl peroxide) decompose at 120°C to 200°C, generating free radicals that form carbon-to-carbon crosslinks from vinyl to methyl groups. Platinum-catalyzed addition curing at 80°C to 150°C produces a cleaner crosslink network with lower compression set and higher transparency than peroxide systems.
- Post-Cure to Stabilize Final Properties. Post-curing at 200°C to 250°C for 2 to 4 hours removes residual peroxide decomposition byproducts and volatile cyclic siloxanes from the elastomer network. The post-cure stage stabilizes tensile strength, compression set resistance, and long-term thermal aging performance across the final silicone rubber grade.
Does Silicone Rubber Require Vulcanization to Achieve Elasticity?
Yes, silicone rubber requires vulcanization to achieve elasticity. Unvulcanized silicone gum exists as a high molecular weight linear polydimethylsiloxane (PDMS) with no crosslink network, exhibiting plastic flow behavior rather than elastic recovery under mechanical stress. Vulcanization establishes covalent crosslinks from vinyl to methyl side groups through peroxide curing at 120°C to 200°C or platinum-catalyzed addition curing at 80°C to 150°C, converting the linear gum into a three-dimensional elastomer network. The crosslink density determines the final hardness, elongation, and compression set of the cured silicone rubber, ranging from 10 Shore A in lightly crosslinked soft grades to 80 Shore A in heavily crosslinked industrial grades. Post-curing at 200°C to 250°C for 2 to 4 hours further stabilizes the crosslink network, removing residual byproducts and optimizing long-term mechanical performance across aerospace, medical, and industrial sealing applications.
How Is Silicone Rubber Processed in Industrial Manufacturing Systems?
Silicone rubber is processed in industrial manufacturing systems through the six steps listed below.
- Prepare and Compound the Base Polymer. Silicone gum mixes with fumed silica filler at 10% to 40% by weight, curing agents, and additives through a two-roll mill or internal mixer. The compounding stage establishes hardness, tensile strength, and processing viscosity of the uncured compound.
- Select the Processing Method Based on Part Geometry. Silicone rubber processes as a thermoset material, requiring irreversible curing to establish the final elastomer network, unlike thermoplastic rubbers that re-melt upon reheating. Compression molding, transfer molding, injection molding, and extrusion portray the primary processing routes, depending on part complexity and production volume.
- Compression Mold for Simple Geometries. Uncured silicone compound is placed into a heated mold cavity at 150°C to 200°C and pressures from 7 to 15 MPa, curing for 3 to 10 minutes. Compression molding suits low-volume production of flat gaskets, seals, and simple molded components.
- Transfer and Injection Mold for Complex Geometries. Transfer molding forces pre-measured silicone compound through runner systems into closed mold cavities at 150°C to 180°C, improving dimensional consistency. Liquid Silicone Rubber (LSR) injection molding at 150°C to 220°C delivers cycle times from 15 to 60 seconds, suiting high-volume medical and automotive components.
- Extrude for Continuous Profile Production. Silicone rubber extrusion through a screw extruder at 60°C to 100°C produces continuous profiles (tubing, cord, and custom cross-sections) at consistent dimensional tolerances. Extruded profiles cure through a hot air vulcanization tunnel at 200°C to 300°C or a salt bath at 200°C to 220°C.
- Post-Cure to Stabilize Final Properties. Molded and extruded components undergo post-curing at 200°C to 250°C for 2 to 4 hours in a circulating air oven. Post-curing removes residual peroxide byproducts and volatile cyclic siloxanes, stabilizing tensile strength and compression set resistance.
How Is Silicone Rubber Processed Using Injection Molding Systems?
Silicone rubber is processed using injection molding systems through the seven steps listed below.
- Preparing the LSR Material. Two-component LSR (Part A and Part B) gets loaded into separate cylinders at a 1:1 ratio. A static mixer combines the components before injection, preventing premature curing. The material viscosity ranges from 100,000 to 300,000 centipoise, requiring controlled pumping pressure to maintain flow consistency.
- Injecting into the Heated Mold. The mixed LSR gets injected into a closed steel mold cavity heated from 160°C to 220°C. Injection pressure ranges from 500 psi to 30,000 psi, depending on part geometry and wall thickness. The heating system maintains temperature uniformity within ±2°C across the mold surface to prevent inconsistent cure rates.
- Curing Inside the Closed Cavity. Platinum-catalyzed crosslinking begins immediately upon contact with the heated mold surface. The closed cavity maintains uniform pressure during cure, eliminating voids and surface defects. Cycle times range from 15 seconds to 3 minutes, depending on part thickness and mold temperature.
- Ejecting the Finished Part. Ejector pins release the cured part from the mold cavity after the crosslinking reaction reaches full completion. Demolded parts retain dimensional tolerances within ±0.005 inches. A secondary post-cure at 200°C for 1 to 4 hours removes residual platinum catalyst byproducts from the material.
How Is Silicone Rubber Processed Using Extrusion Systems?
Silicone rubber is processed using extrusion systems through the four steps listed below.
- Loading the Uncured Silicone. High-consistency rubber (HCR) gets fed into the extruder barrel through a hopper. The material requires a Durometer hardness from 20 Shore A to 80 Shore A before processing. A consistent feed rate prevents pressure fluctuations inside the barrel.
- Shaping Through the Die System. A rotating screw pushes the uncured silicone through a precision-machined die at pressures from 500 psi to 3,000 psi. The die profile determines the final cross-sectional geometry of the extruded part (tubing, cord, gaskets, seals). Dimensional tolerances hold within ±0.010 inches across continuous profiles.
- Conveying Through the Curing System. The extruded silicone profile passes through a hot air vulcanization (HAV) tunnel or salt bath immediately after exiting the die. HAV tunnels operate at temperatures from 200°C to 600°C, while salt bath systems maintain 200°C to 220°C. Cure time ranges from 1 minute to 5 minutes, depending on profile thickness and tunnel length.
- Cooling and Cutting the Profile. The cured profile passes through a water cooling trough, dropping the material temperature to 20°C to 25°C. Automated cutting systems trim the continuous profile into specified lengths. Final parts retain tensile strength from 200 psi to 1,500 psi after full cure.
How Is Silicone Rubber Processed Using 3D Printing Systems?
Silicone rubber is processed using 3D printing systems through the four steps listed below.
- Selecting the Silicone Feedstock. Silicone 3D printing uses either liquid silicone rubber (LSR) or elastomer-based filament as the primary feedstock. LSR operates at viscosities from 200,000 to 500,000 centipoise, requiring precision dispensing systems. Elastomer-based feedstocks process at Shore A hardness values from 20 to 60, depending on the target application.
- Preparing the Print System. The 3D printing system calibrates nozzle diameter, layer height, and deposition speed before processing. LSR systems use pneumatic or screw-driven dispensing at pressures from 30 psi to 150 psi. Layer heights range from 0.1 mm to 0.5 mm, depending on part resolution requirements.
- Depositing the Silicone Layers. The print head deposits silicone in successive layers, building the part geometry from the base upward. LSR systems cure each layer using ultraviolet (UV) light or heat immediately after deposition. Dimensional tolerances hold within ±0.02 mm to ±0.5 mm, depending on the print system used.
- Post-Processing the Printed Part. Printed silicone parts undergo post-cure at 100°C to 200°C for 30 minutes to 2 hours. The post-cure cycle completes crosslinking and stabilizes mechanical properties. Final parts retain elongation at break values from 100% to 700%, depending on feedstock formulation.
Does Silicone Rubber Require High Temperature Processing Equipment?
Yes, silicone rubber requires high-temperature processing equipment. High-consistency rubber (HCR) cures at temperatures from 116°C to 200°C, while liquid silicone rubber (LSR) injection molding operates at mold temperatures from 160°C to 220°C. Extrusion systems use hot air vulcanization (HAV) tunnels reaching 600°C to achieve full cure across continuous profiles. The crosslinking reaction in thermoset silicone activates when sufficient thermal energy reaches the polymer chains. Peroxide-cured systems require higher activation temperatures from 160°C to 171°C, while platinum-catalyzed systems initiate cure at lower ranges from 21°C to 177°C. Room-temperature vulcanizing (RTV) silicone illustrates the exception, curing at ambient temperatures from 20°C to 25°C without external heat. RTV systems produce parts with lower tensile strength, ranging from 200 psi to 500 psi, compared to heat-cured silicone reaching 1,500 psi.
How Is Silicone Rubber Used in Industrial Coating and Sealing Applications?
The industrial coating and sealing applications of silicone rubber are listed below.
- Gasket Sealing: Silicone rubber gaskets seal mating surfaces in industrial flanges, enclosures, and pipe joints. The material compresses from 15% to 35% under bolt load, maintaining a leak-proof interface. Operating pressure tolerance ranges from 0 psi to 1,500 psi, depending on gasket thickness and durometer.
- Conformal Coating: Silicone conformal coatings protect printed circuit boards (PCBs) and electronic assemblies from moisture and contamination. Coating thickness ranges from 25 microns to 75 microns, applied through spraying, dipping, or selective dispensing. The coating retains dielectric strength from 400 V/mil to 600 V/mil after full cure.
- Thermal Interface Coating: Silicone-based thermal interface materials (TIMs) fill microscopic air gaps from 50 microns to 200 microns across mating surfaces. Thermal conductivity ranges from 0.5 W/m·K to 6.0 W/m·K, depending on filler concentration. The coating maintains performance across repeated thermal cycles from -55°C to 200°C.
- Chemical Resistant Lining: Silicone rubber linings coat the interior surfaces of tanks, ducts, and chemical processing equipment. The lining resists acids, alkalis, and solvents at concentrations of up to 30%, preventing substrate corrosion. Lining thickness ranges from 1 mm to 6 mm, depending on chemical exposure severity.
How Does Silicone Rubber Improve Sealing Performance in Industrial Systems?
Silicone rubber improves sealing performance in industrial systems through compression set resistance and sustained elasticity under repeated pressure cycles. The crosslinked polymer network retains from 80% to 95% of its original thickness after prolonged compression, preventing gap formation at sealing interfaces. Compression set values for silicone rubber range from 10% to 25%, measured at 175°C for 22 hours per ASTM D395 standards. The low compression set directly prevents leakage at flange faces, pipe joints, and enclosure gaskets operating under continuous load.
Silicone rubber maintains elastic recovery across pressure cycles from 0 psi to 1,500 psi without permanent deformation. The material retains elongation at break values from 100% to 700% after 10,000 pressure cycles, depending on durometer and compound formulation. Operating temperature range from -60°C to 230°C preserves seal integrity across thermal expansion and contraction cycles. Service life for silicone seals in continuous industrial service reaches 10 to 20 years, depending on chemical exposure and compressive load conditions.
Does Silicone Rubber Maintain Sealing Integrity Under Pressure Variation?
Yes, silicone rubber maintains sealing integrity under pressure variation. The crosslinked polymer structure recovers from 80% to 95% of its original thickness after each pressure cycle, preventing gap formation at sealing interfaces. Compression set values remain from 10% to 25% at temperatures up to 175°C, measured per ASTM D395 standards. Silicone seals operate across pressure ranges from 0 psi to 1,500 psi without permanent deformation or material fatigue. Elongation at break values range from 100% to 700% after repeated loading cycles, depending on compound formulation and durometer grade. The material sustains elastic recovery across thermal fluctuations from -60°C to 230°C, maintaining consistent contact stress at sealing surfaces. Industrial silicone seals achieve service life from 10 to 20 years under continuous pressure cycling, depending on chemical exposure and compressive load conditions.
What Are the Main Industrial Applications of Silicone Rubber Materials?
The main industrial applications of silicone rubber materials are listed below.
- Aerospace Sealing Systems: Silicone rubber seals and gaskets maintain pressure integrity in aircraft fuel systems, hydraulic lines, and cabin pressurization assemblies. The material operates at altitudes where temperatures drop to -60°C, retaining elastic recovery without brittleness. Compression set values remain from 10% to 25% under continuous load at temperatures up to 175°C.
- Medical Device Components: Silicone rubber meets USP Class VI and ISO 10993 biocompatibility standards for implantable and fluid-contact medical devices. The material resists sterilization methods (autoclaving, gamma radiation, ethylene oxide) without degrading mechanical properties. Tensile strength remains from 200 psi to 1,500 psi after repeated sterilization cycles.
- Electrical Insulation Systems: Silicone rubber insulates high-voltage cables, busbars, and switchgear components operating at voltages from 1 kV to 500 kV. The material maintains dielectric strength from 400 V/mil to 600 V/mil across temperatures from -60°C to 200°C. Tracking resistance exceeds 600 minutes per IEC 60587 standards.
- Automotive Gaskets and Hoses: Silicone rubber gaskets and hoses seal engine components operating at coolant temperatures from -40°C to 180°C. The material resists automotive fluids (engine oil, coolant, transmission fluid) at continuous operating pressures from 15 psi to 150 psi. Service life reaches 10 to 15 years under continuous thermal cycling conditions.
- Industrial Thermal Insulation: Silicone rubber foam insulates pipes, ducts, and process equipment operating at temperatures from -60°C to 200°C. Thermal conductivity ranges from 0.03 W/m·K to 0.05 W/m·K, reducing heat loss across insulated systems. Closed-cell silicone foam retains insulation performance after compression from 25% to 50% of its original thickness.
How Is Silicone Rubber Used in Industrial Sealing Components?
Silicone rubber is used in industrial sealing components through the four steps listed below.
- Selecting the Silicone Compound. High-consistency rubber (HCR) or liquid silicone rubber (LSR) gets selected based on sealing requirements. HCR suits compression-molded gaskets requiring Shore A hardness from 40 to 80, while LSR suits injection-molded seals requiring Shore A hardness from 20 to 60. The compound formulation determines compression set resistance, ranging from 10% to 25% at 175°C.
- Forming the Gasket Geometry. Compression molding, transfer molding, or die-cutting processes shape silicone into flat gaskets, O-rings, and profile seals. Compression molding operates at pressures from 500 psi to 2,000 psi and temperatures from 160°C to 200°C. Dimensional tolerances hold within ±0.005 inches across molded sealing surfaces.
- Curing the Sealing Component. Peroxide or platinum-catalyzed cure systems crosslink the silicone polymer network at temperatures from 116°C to 200°C. Full crosslinking eliminates void formation and surface defects that compromise sealing integrity. Post-cure at 200°C for 2 to 4 hours stabilizes tensile strength from 200 psi to 1,500 psi.
- Verifying Thermal and Pressure Resistance. Cured sealing components undergo compression set testing per ASTM D395 at temperatures from 150°C to 200°C for 22 hours. Pressure resistance testing confirms seal integrity at operating pressures from 0 psi to 1,500 psi. Thermal cycling tests validate performance across temperature ranges from -60°C to 230°C before industrial deployment.
How Is Silicone Rubber Used in Electrical Insulation Systems?
Silicone rubber is used in electrical insulation systems as a high-performance dielectric material, protecting conductors and components across voltage ranges from 1 kV to 500 kV. The siloxane backbone (Si-O-Si) provides inherent dielectric stability, retaining dielectric strength from 400 V/mil to 600 V/mil across temperatures from -60°C to 200°C. The Si-O bond energy of 452 kJ/mol resists thermal degradation, preventing insulation breakdown under continuous electrical stress. Tracking resistance exceeds 600 minutes per IEC 60587 standards, making silicone rubber reliable in high-voltage switchgear, busbar insulation, and cable jacketing systems.
Silicone rubber resists moisture absorption at rates below 0.2% by weight, preventing conductivity loss at insulation surfaces. The crosslinked polymer network blocks environmental contaminants (saltwater, industrial chemicals, ozone) from penetrating the insulation layer. UV resistance prevents surface chalking and cracking across outdoor service conditions, maintaining insulation integrity for 10 to 25 years. Hydrophobic surface properties recover after temporary contamination, restoring surface resistivity from 10¹² to 10¹⁴ ohm-cm across wet and polluted environments.
Does Silicone Rubber Support Sustainable Industrial Material Design?
Yes, silicone rubber supports sustainable industrial material design. Industrial silicone components achieve service life from 10 to 25 years, reducing replacement frequency and material waste across manufacturing systems. The crosslinked polymer network retains tensile strength from 200 psi to 1,500 psi after repeated mechanical and thermal cycling. Silicone rubber maintains dimensional stability across temperatures from -60°C to 230°C, preventing material failure under environmental exposure. The material resists UV radiation, ozone, and moisture absorption below 0.2% by weight. Compression set values remain from 10% to 25% after prolonged reuse cycles, confirming elastic recovery without permanent deformation. Silicone rubber components reduce raw material consumption by extending replacement intervals from 5 to 15 years compared to organic rubber alternatives.
