Blow Molding vs. Rotational Molding: What’s the Difference?
Written byKat de Naoum
Rebecca Piccoli
Updated byRebecca Piccoli
Published September 12, 2022Updated March 12, 2026
Learn which technique produces 70 parts an hour (and which can only make two…)
PET bottles being produced in a blow molding machine. Image Credit: MOLPIX/Shutterstock.com
As a manufacturing technique, molding has been around for thousands of years. Two of the oldest molding processes that are still used today are blow molding and rotational molding. In this article (and the video below), we explain them in more detail and cover how they differ and what they each do best.
Blow Molding Definition and Comparison to Rotational Molding
Blow molding is a plastic hollow-part forming process used to make products with simpler designs and thin walls. It’s an ancient technique that first emerged in the form of glassblowing around 1700 BCE in Syria. Later refinements allowed glassblowers to create bottles. The more modern blow molding process matured in the 1930s when the first automatic blow molding machine was introduced by the Plax Corporation.
Most modern blow molding deals with thermoplastics. The procedure, shown in the diagram below, involves a hollow plastic parison (also known as a preform) being placed at the mouth of a mold cavity and heated until properly malleable. Pressurized gas is then forced into the parison’s open end until it expands to match the mold cavity’s shape. The product then gets cooled and crystalized so it doesn’t deform while being removed from the mold.
Blow molding process
This method is ideal for large-scale production thanks to how quickly it can make parts—70 of them in just an hour. It can make thin, lightweight parts with parting line integrity (no visible hems or seams from the mold), and you can control the wall thickness. Though this fully automated approach is best known for soda and water bottles, it also finds uses in engineered gas tanks and electrical enclosures.
It’s preferred over rotational molding for its cost-efficiency in high-output industrial settings, especially at rates higher than 3,000 units per year. Further adding to its cost-efficiency is the mold itself, which lasts a very long time. Having said that, the tooling cost is quite high, and low-volume production quantities work out more expensive. As far as aesthetics, this isn’t typically the method you’d want to use if you need parts with super attractive finishes.
"Blow Molding is used for "high volume production" with simple geometries (symmetrical, simple designs). Think bottles and containers. Fast cycle times, material efficiency, low per-unit cost at scale, and ease of integration for assembly lines make it a good choice for projects. High tooling cost, short cycle times."
Kurt PokopacSolutions Engineer
What are the Advantages of Blow Molding Compared to Rotational Molding?
Compared to rotomolding, blow molding has several advantages:
  • Blow molding cycles are shorter.
  • The mold itself lasts far longer.
  • Blow molding produces thin, lightweight parts with parting line integrity.
  • It is more cost-effective for production rates higher than 3,000 units per year.
  • Blow molding offers better wall-thickness control and is fully automated.
What are the Disadvantages of Blow Molding Compared to Rotational Molding?
Some of the disadvantages of blow molding compared with rotational molding include:
  • Blow molding has less design flexibility.
  • The tooling cost is very high compared to rotomolding.
  • With blow molding, low-volume production quantities are more costly.
  • The surface finishes produced by blow molding are not always aesthetically pleasing.
Rotational Molding Definition and Comparison to Blow Molding
Also known as rotomolding, rotational molding is a high-heat, low-pressure thermoforming process used to make hollow plastic parts. A type of rotational molding was used in ancient Egypt to make ceramics, but an upgraded version was introduced in the U.S. around 1945 for plastics. This wasn’t met with open arms, though, due to its snail-like pace. The plastic powders have since had several upgrades so that they flow more easily and evenly, making the process today much faster (thankfully).
How the rotational molding process works
In the process, which you can see in the above picture, a hollow mold is filled with powdered plastic resin and spun before being transferred to an oven, where the resin melts and coats the mold’s walls. The mold keeps on spinning until the resin cools and hardens into the final desired shape. The mold can then be opened so you can take the part out.
It can make large parts with double walls and an open design, and not much secondary processing is necessary because it doesn’t have any weld lines or seams (as opposed to blow molding). There’s cheaper tooling due to the low pressures involved, and it’s more efficient at lower production volumes of less than 3,000 pieces a year—great for startups and small businesses.
With rotational molding, you get a lot more versatility, design flexibility, and stronger products that are much more durable than those made with blow molding. Rotomolded parts do, however, have thicker walls which uses more material and makes them heavier, and the final product could also end up with voids. This method is pretty labor-intensive, and doesn’t offer good control over the thickness of the walls. The tools also need regular maintenance or replacement.
"Rotational Molding or roto molding is used for more complex shapes in lower/mid-level production. It can accommodate special features (inserts, variable wall thickness), which makes it ideal for complex shapes. Think kayaks, storage tanks, and playground equipment. Lower cost tooling but comes with longer cycle times.'
What are the Advantages of Rotational Molding Compared to Blow Molding?
Rotomolding has the following advantages over blow molding:
  • Rotational molding offers more versatility and design flexibility.
  • Rotomolding is more cost-effective for production rates of fewer than 3,000 units per year.
  • Rotational molding has cheaper tooling due to the low pressures involved.
  • The final products are stronger and more durable than blow molded parts.
What are the Disadvantages of Rotational Molding Compared to Blow Molding?
The following are considered disadvantages of rotational molding compared to blow molding:
  • Rotomolding tools need regular replacement or refurbishment.
  • Voids in the end product are possible.
  • Rotomolded parts have thicker walls, so they’re heavier and use more material.
  • Rotomolding has poor wall-thickness control.
  • Rotational molding can be more labor intensive than blow molding.
Comparison Table Between Blow Molding and Rotational Molding
The table below offers a side-by-side view of these two manufacturing methods so you can determine which one will be better for your production needs.
Rotational molded parts are, on average, heavier and thicker than blow molded parts. However, rotomolded parts are known to have some degree of porosity. This is because the rotation of the drum distributes resin semi-randomly. In theory, the centrifugal force with a liquidized resin should be able to evenly distribute it over the entire surface, but in practice, this is not always the case.
Blow Molding vs. Rotational Molding: Lead Cost Comparison
The initial tooling costs of blow molding are greater than those for rotational molding. However, in the long run, blow molding can save you up to 40%. This is especially true for high-output production lines that turn out more than 3,000 units per year. Blow molding tooling typically costs about $200,000 for the lifetime of the mold whereas upkeep and parts for rotational molding average $150,000 per year.
Blow Molding vs. Rotational Molding: Speed Comparison
Blow molding is a much faster process than rotational molding. Cycle times for the former are often less than 1 minute, whereas rotomolding cycles can stretch past 30 minutes. Blow molding’s speed makes it far more energy- and time-efficient.
Blow Molding vs. Rotational Molding: Volume Comparison
Because of the difference in molding cycle times, blow molding is capable of higher production volumes compared to rotomolding. More specifically, blow molding machines can output 70 parts/hr, whereas rotomolding may be limited to only 2 parts/hr.
Blow Molding vs. Rotational Molding: Materials Comparison
Common rotational molding materials include Low-density Polyethylene (LDPE), Linear Low-Density Polyethylene (LLDPE), High-Density Polyethylene (HDPE), and Crosslinked Polyethylene (PEX). Meanwhile, common materials for blow molding include LDPE, Polypropylene (PP), Polyethylene Terephthalate (PET), Polyvinyl Chloride (PVC), and HDPE.
FAQs on Blow Molding and Rotational Molding
We’ve got a bunch of molding services here at Xometry, including insert molding, prototype molding, overmolding, and injection molding. You can get started today by uploading your designs to the Xometry Instant Quoting Engine®!
