Jig Grinder
Written byMegan Conniff
20 min read
Published September 30, 2026
A jig grinder is a precision machine tool that finishes hole locations, internal contours, and complex profiles to extremely tight dimensional tolerances using a rotating abrasive wheel mounted on a precisely positioned spindle. Jig grinding combines the material removal capability of conventional grinding with the positional accuracy of a jig boring machine, supporting hole placement and contour accuracy within fractions of a thousandth of an inch. Jig grinding machines incorporate rigid construction, high-precision positioning systems, and fine feed control to achieve dimensional consistency across demanding tooling and component applications. CNC jig grinders extend the capability further, automating multi-axis positioning and feed control to deliver repeatable accuracy across high-volume or geometrically complex production runs. Tool, die, mold, aerospace, and medical device manufacturers rely on jig grinding to achieve the exacting hole and contour specifications that conventional milling or boring cannot consistently meet.
What Is a Jig Grinder?
A jig grinder uses a small-diameter abrasive wheel positioned with extreme accuracy to finish hole locations, internal contours, and complex geometric profiles relative to a part's reference datums. The machine combines rotational wheel motion with precise table or spindle positioning, achieving hole location accuracy within ±0.0001 inch (±2.54 micrometers) on demanding tooling applications. Both straight and contoured hole profiles fall within its capability, supporting tapered bores, slots, and irregular cavity shapes beyond simple cylindrical geometry. Precision ground ballscrews with optical scales, linear encoders, or CNC-controlled servo feedback systems maintain consistent reference points throughout the grinding cycle, establishing the positional accuracy that defines the equipment. Tool and die manufacturers rely on jig grinders to achieve hole placement and form accuracy unattainable through conventional drilling, boring, or milling processes alone.
How Does a Jig Grinder Work?
A jig grinder works by positioning a small-diameter abrasive wheel with extreme precision relative to a workpiece, then removing material through controlled rotational and orbital wheel motion to achieve the target hole or contour geometry.
A jig grinder works by following the five steps below.
  1. Secure and Align the Workpiece. The operator mounts the workpiece on the machine table, referencing precision datums or fixture features to establish the part's coordinate origin. Accurate alignment at the stage directly determines the positional accuracy achievable throughout the grinding cycle.
  2. Position the Spindle to the Target Location. The machine positions the grinding spindle to the programmed or dialed-in coordinate location, using precision leadscrews, optical scales, or CNC servo control. Positioning accuracy at the step establishes the center point around which the finished hole or contour forms.
  3. Engage the Grinding Wheel in Orbital or Planetary Motion. The small-diameter wheel rotates at high speed while simultaneously orbiting around the programmed center point, removing material progressively to enlarge or shape the feature. The orbital radius adjusts incrementally to achieve the final target diameter or contour profile.
  4. Apply Coolant Throughout the Cutting Cycle. Coolant flows continuously into the grinding zone, removing heat and abrasive debris while preventing thermal distortion of the workpiece. Consistent coolant delivery maintains dimensional stability across extended grinding cycles on hardened tool steel.
  5. Verify Dimensional Accuracy Against Specification. The operator or CNC system measures the finished feature using precision gauges, air gauging, or in-process measurement systems. Verification confirms the hole or contour meets the specified location, diameter, and form tolerance before the part proceeds to subsequent operations.
What Are the Key Components of a Jig Grinding Machine?
A jig grinding machine consists of several specialized components that work together to achieve extreme positional accuracy and controlled material removal. Each component contributes a specific function, from generating the orbital cutting motion to maintaining precise coordinate positioning throughout the grinding cycle.
The key components of a jig grinding machine are listed below.
  • Grinding Spindle: The spindle drives a small-diameter abrasive wheel at high rotational speed, often combined with orbital or planetary motion to enlarge holes or generate contours. Spindle precision directly determines the achievable surface finish and dimensional accuracy of the finished feature.
  • Precision Positioning System: Leadscrews, optical scales, or CNC servo systems position the worktable or spindle head relative to the part's reference datums. Positioning accuracy at the stage establishes the location tolerance achievable across the finished hole or contour.
  • Worktable: The worktable holds and references the workpiece, often incorporating fine manual or motorized adjustment to align the part precisely before grinding begins. Table rigidity prevents movement that would otherwise compromise positional accuracy during the cutting cycle.
  • Coolant System: The coolant system delivers cutting fluid to the grinding zone, managing heat generation and flushing abrasive debris away from the cutting area. Effective coolant delivery preserves dimensional stability, particularly on hardened tool steel workpieces.
  • Base and Frame: The machine base and frame provide structural rigidity, minimizing vibration and thermal drift that would otherwise compromise the tight tolerances jig grinding requires. Cast iron or granite construction commonly forms the foundation for stability.
  • Control System: The control system (manual dial-in or CNC programming) governs spindle positioning, orbital motion, and feed increments throughout the grinding cycle. CNC-controlled Grinding Machine configurations deliver repeatable accuracy across complex, multi-feature workpieces.
What Makes Jig Grinding Different From Other Types of Grinder?
Jig grinding differs from other grinding methods primarily through its emphasis on positional accuracy rather than simple surface or diameter finishing. Standard cylindrical or surface grinders focus on achieving precise dimensions along a fixed axis or flat plane, while jig grinders combine orbital wheel motion with precise coordinate positioning to finish holes and contours at exact locations relative to part datums. The small-diameter wheels used in jig grinding access internal features and irregular contours that standard grinding wheel configurations cannot reach effectively. Jig grinders incorporate positioning systems comparable to jig boring machines, achieving location accuracy within ±0.0001 inch that exceeds the positional capability of conventional surface or cylindrical grinding equipment. Tool, die, and mold manufacturing rely on the combination of positional and dimensional accuracy, distinguishing jig grinding from the broader category of types of grinders focused primarily on surface finish or bulk material removal.
"In precision tooling and aerospace manufacturing, achieving true geometric position on post-heat-treated components requires isolating thermal drift and tool deflection entirely. Jig grinding uniquely decouples spindle rotation from orbital coordinate feeds, enabling sub-micron true position tolerances that single-point boring simply cannot replicate on hardened tool steels (above 60 HRC). When designing for extreme-tolerance datum interfaces, factoring in wheel clearance and planetary reach during early DFM prevents costly manufacturing bottlenecks."
What Types of Jig Grinders Are Available?
Jig grinding equipment spans several distinct machine configurations, each offering a different balance of manual control, automation, and positioning capability. Selecting the appropriate jig grinder type depends on production volume, part complexity, and the precision demanded by the application.
The types of jig grinders available are listed below.
  • Manual Jig Grinders: Operator-controlled handwheels, dials, and micrometer adjustments position the spindle and workpiece relative to the desired hole or contour location. Manual machines suit low-volume, highly specialized tooling work where skilled operator judgment supports achieving extreme precision.
  • CNC Jig Grinders: Computer-controlled servo systems position the spindle and control orbital wheel motion automatically, based on programmed coordinate data rather than manual dial adjustment. The machines achieve repeatable accuracy across production volumes beyond what manual jig grinding can practically sustain.
  • Moore Jig Grinders: Precision jig grinding equipment manufactured by the Moore Tool Company, recognized within the tooling industry for exceptional positional accuracy and build quality. The machines incorporate robust construction and stable thermal characteristics suited to extended, high-precision grinding cycles.
What Are Manual Jig Grinders?
Manual jig grinders rely on operator-controlled handwheels, dials, and micrometer adjustments to position the spindle and workpiece relative to the desired hole or contour location. The operator references graduated dials or digital readouts to dial in precise coordinate positions, then manually adjusts wheel orbit diameter to achieve the target feature size. Manual machines suit low-volume, highly specialized tooling work where skilled operator judgment and direct tactile feedback support achieving extreme precision. The configuration requires significant operator expertise, since positioning accuracy depends entirely on the skill and attentiveness applied during setup and grinding. Tool rooms and specialty die shops commonly retain manual jig grinders for one-off or low-quantity precision work that does not justify CNC programming overhead.
What Are CNC Jig Grinders?
CNC jig grinders use computer-controlled servo systems to position the spindle and control orbital wheel motion automatically, based on programmed coordinate data rather than manual dial adjustment. The CNC control system executes positioning, orbital radius changes, and feed increments according to a pre-programmed cycle, eliminating the variability introduced by manual operator adjustment. The machines achieve repeatable accuracy across multiple identical parts, supporting production volumes beyond what manual jig grinding can practically sustain. CNC programming also enables complex contour grinding and multi-feature part processing within a single automated cycle, reducing setup time between operations. Aerospace, medical device, and high-volume tooling manufacturers rely on CNC jig grinders to achieve consistent precision across production runs requiring hundreds or thousands of identical features.
What Is a Moore Jig Grinder?
A Moore jig grinder refers to precision jig grinding equipment manufactured by the Moore Tool Company, recognized within the tooling industry for exceptional positional accuracy and build quality. Moore jig grinders historically established benchmark standards for hole location accuracy, achieving tolerances that influenced precision grinding equipment design across the broader industry. The machines incorporate robust construction, precise leadscrew or optical positioning systems, and stable thermal characteristics suited to extended, high-precision grinding cycles. Tool and die shops specializing in extreme-precision work often reference Moore jig grinders as a standard against which other jig grinding equipment is compared. The brand's reputation for accuracy and durability has made Moore jig grinders a long-standing fixture in precision tooling manufacturing facilities worldwide.
What Are the Uses of a Jig Grinder?
Jig grinders serve a wide range of precision finishing applications across manufacturing sectors where exact hole location and contour accuracy determine component function. Each application leverages the machine's combination of positional precision and fine material removal capability.
The uses of a jig grinder are listed below.
  • Uses for Jig and Fixture Manufacturing: Jig grinding achieves precise hole locations and bushing bores that ensure accurate part alignment during downstream production operations.
  • Uses for Die and Mold Finishing: Jig grinding achieves exact contours, hole placements, and cavity geometries required for injection molding and stamping tooling.
  • Uses for Precision Hole Grinding: Jig grinding finishes hole diameters and locations to tolerances beyond the capability of conventional drilling or boring.
  • Uses for Internal Diameter Grinding: Jig grinding finishes bore surfaces within a workpiece, achieving precise diameter and roundness specifications using small-diameter orbital wheels.
  • Uses for Complex Contour Grinding: Jig grinding leverages orbital and multi-axis positioning capability to finish irregular shapes, slots, and curved profiles within a workpiece.
  • Uses for Tool and Cutter Production: Jig grinding finishes precise features on cutting tool bodies, including hole locations for inserts or pilot bores requiring exact placement.
  • Uses for Aerospace Component Machining: Jig grinding produces critical hole patterns, bushings, and contoured features requiring exacting dimensional control under demanding structural and operational loads.
  • Uses for Medical Device Component Finishing: Jig grinding achieves precise hole locations and contours on surgical instruments and implant components requiring biocompatible surface quality.
  • Uses for Precision Cavity Machining: Jig grinding finishes complex internal cavity geometries within die, mold, and fixture components requiring exact form and dimensional accuracy.
Jig grinding achieves precise hole locations and bushing bores that ensure accurate part alignment during downstream production operations. The process delivers the positional accuracy required for interchangeable tooling components used across repeated manufacturing setups. Manufacturers depend on the accuracy to maintain a consistent fit between the mating jig and fixture elements across multiple production batches. Tight hole location tolerances prevent misalignment that would otherwise compromise the function of downstream assembly or machining operations relying on the finished jig or fixture component.
Die and mold finishing applies jig grinding to achieve exact contours, hole placements, and cavity geometries required for injection molding and stamping tooling. The process removes machining marks and achieves the precise dimensional accuracy necessary for proper part formation and tooling longevity. Jig grinding reaches internal cavity features and complex contours that conventional milling cannot finish to the required surface and dimensional standard. The resulting precision directly influences molded part quality and the operational lifespan of the finished die or mold component.
Precision hole grinding uses jig grinding to finish hole diameters and locations to tolerances beyond the capability of conventional drilling or boring. The process suits applications requiring exact bushing fits, dowel pin locations, or other critical hole features within tooling and fixture components. Small-diameter orbital wheels reach tight spaces and achieve roundness specifications that standard hole-making methods cannot consistently deliver. Manufacturers rely on the capability to maintain interchangeability across components requiring identical hole placement and diameter accuracy.
Internal diameter grinding applies jig grinding to finish bore surfaces within a workpiece, achieving precise diameter and roundness specifications using small-diameter orbital wheels. The process suits components requiring tight internal tolerances that standard internal grinders cannot reach due to geometric constraints or limited wheel access. Jig grinding accommodates bores positioned close to part edges or within complex surrounding geometry, expanding the range of internal features achievable. The resulting accuracy supports proper bushing fit and bearing alignment in finished tooling and mechanical components.
Complex contour grinding leverages jig grinding's orbital and multi-axis positioning capability to finish irregular shapes, slots, and curved profiles within a workpiece. CNC-controlled contour grinding achieves repeatable accuracy across intricate geometries unattainable through conventional grinding methods limited to straight or simple curved paths. The process suits die cavities, cam profiles, and other non-standard shapes requiring precise dimensional control. Manufacturers apply the capability whenever part geometry exceeds the limitations of standard surface or cylindrical grinding equipment.
Tool and cutter production applies jig grinding to finish precise features on cutting tool bodies, including hole locations for inserts or pilot bores requiring exact placement. The process supports the dimensional accuracy required for proper tool assembly and consistent cutting performance during subsequent machining operations. Jig grinding achieves the tight tolerances necessary for insert pockets and mounting holes that directly affect cutting-edge alignment. Tool manufacturers depend on the precision to ensure reliable, repeatable performance across produced cutting tool batches.
Aerospace component machining relies on jig grinding for critical hole patterns, bushings, and contoured features requiring exacting dimensional control under demanding structural and operational loads. Strict accuracy and traceability requirements govern jig grinding operations across aerospace production programs handling flight-critical hardware. The process achieves the positional and dimensional precision necessary for components subjected to extreme stress, vibration, and temperature cycling during service. Aerospace manufacturers depend on the capability to maintain structural reliability across critical assembly interfaces.
Medical device component finishing uses jig grinding to achieve precise hole locations and contours on surgical instruments and implant components requiring biocompatible surface quality. The process supports the tight dimensional accuracy required for proper device function, patient safety, and regulatory compliance across medical manufacturing. Jig grinding finishes intricate features on small, complex medical components that conventional machining methods struggle to reach effectively. Manufacturers rely on the precision to meet the strict quality standards governing implantable and surgical device production.
Precision cavity machining uses jig grinding to finish complex internal cavity geometries in die, mold, and fixture components that require exact form and dimensional accuracy. The process achieves the surface finish and positional precision necessary for proper part formation in subsequent manufacturing operations using the finished tooling. Jig grinding reaches deep or intricate cavity features that standard milling or grinding equipment cannot access with comparable accuracy. The resulting cavity precision directly determines the quality and consistency of parts produced from the finished tooling.
How Do You Select the Right Jig Grinding Machine?
Selecting the right jig grinding machine requires systematically evaluating production needs to match equipment capabilities to specific application requirements. Each step builds on the previous decision, narrowing the field of suitable machines until a clear best fit emerges.
To select the right jig grinding machine, follow the five steps below.
  1. Identify the Required Tolerance and Positional Accuracy. Determine the tightest hole location and contour tolerance demanded by intended applications, since it directly establishes the minimum machine capability needed. Tool and die work often requires accuracy within ±0.0001 inch, exceeding general-purpose grinding equipment.
  2. Determine Manual or CNC Control Suitability. Evaluate whether manual or CNC control suits the anticipated production volume and part complexity, balancing operator skill requirements against automation investment. High-volume or repetitive feature production favors CNC control for consistency and reduced cycle time.
  3. Assess Workpiece Size and Feature Geometry. Confirm the machine's table travel and spindle reach accommodate the intended part range, including the largest and most complex parts planned for production. Mismatched machine capacity limits the range of work the equipment can handle effectively.
  4. Compare Positioning System Technology. Evaluate leadscrew, optical scale, or servo-driven positioning systems across candidate machines, since it directly influences achievable accuracy and repeatability. Optical scale and servo-driven systems generally offer superior long-term accuracy compared to mechanical leadscrew positioning alone.
  5. Evaluate Supplier Reputation and Support. Review available technical support, parts availability, and total cost of ownership across candidate suppliers and machine models. Reliable long-term support ensures the selected machine maintains its precision capability throughout its service life.
Which Factors Should Be Evaluated Before Buying a Jig Grinder?
Buyers should evaluate several specific factors before purchasing a jig grinder, ensuring the selected equipment meets positional accuracy, production volume, and budget requirements.
The factors that should be evaluated before buying a jig grinder are listed below.
  • Required Positional Accuracy: Identify the tightest hole location and contour tolerance demanded by intended applications, since it determines the minimum machine capability needed. Tool and die work often demands tolerances within ±0.0001 inch, exceeding the capability of general-purpose grinding equipment.
  • Production Volume Expectations: Determine whether anticipated production volume justifies CNC automation investment or whether manual operation suffices for low-quantity, specialized work. High-volume or repetitive feature production favors CNC control for consistency and reduced cycle time.
  • Workpiece Size and Geometry: Confirm the machine's table travel, spindle reach, and orbital wheel range accommodate the largest and most complex parts planned for production. Mismatched machine capacity limits the range of work the equipment can handle effectively.
  • Positioning System Technology: Compare leadscrew, optical scale, and CNC servo positioning systems across candidate machines, since it directly affects achievable accuracy and repeatability. Optical scale and servo-driven systems generally offer superior long-term accuracy compared to mechanical leadscrew positioning alone.
  • Operator Skill Requirements: Assess available operator expertise, since manual jig grinders demand significant skill and experience to achieve consistent precision. CNC-controlled machines reduce dependency on individual operator skill, supporting more consistent results across multiple operators.
  • Total Cost of Ownership: Evaluate purchase price alongside maintenance, calibration, and operator training costs across the machine's expected service life. Higher upfront investment in CNC equipment often offsets long-term costs through reduced scrap and labor requirements.
How Do CNC Jig Grinders Compare With Manual Jig Grinders?
CNC jig grinders compare with manual jig grinders through differences in positioning consistency, programming flexibility, and dependency on operator skill throughout the grinding cycle. CNC machines execute programmed coordinate positioning and orbital motion automatically, eliminating the variability introduced by manual handwheel adjustment and operator judgment during setup. Manual jig grinders depend entirely on operator skill and attentiveness to achieve precise positioning, making them more suited to low-volume, highly specialized work where direct tactile control benefits the process. CNC equipment supports complex, multi-feature parts within a single automated cycle, reducing setup time and improving repeatability across production runs requiring hundreds or thousands of identical features. Manual machines typically carry lower upfront investment than CNC equivalents, though the gap narrows when accounting for the labor cost and accuracy variability associated with skilled manual operation across high-volume production.
Is a Jig Boring Service Better Than Buying a Jig Grinder for Precision Holes?
No, a jig boring service is not better than buying a jig grinder for precision holes. The optimal choice depends on production volume, ongoing need, and required surface finish rather than a fixed answer favoring one option universally. Outsourcing avoids the capital investment, training, and maintenance costs associated with owning dedicated equipment, suiting occasional or low-volume precision hole requirements. Purchasing equipment benefits manufacturers with consistent, ongoing precision hole and contour needs, since in-house capability eliminates outsourcing lead times and per-job service costs over the long term. Jig grinding also achieves superior surface finish and tighter tolerances compared to boring alone, since the abrasive process refines the hole beyond what a standard Jig Boring Service can achieve on hardened materials.
What Maintenance Practices Help Maximize Jig Grinder Performance?
Maximizing jig grinder performance requires consistent maintenance practices applied across the machine's positioning systems, spindle, and supporting components. Each practice addresses a specific source of precision loss, working together to preserve the machine's rated accuracy over its service life.
Maintenance practices that help maximize jig grinder performance are listed in the five steps below.
  1. Inspect and Calibrate the Positioning System. Check leadscrew, optical scale, or servo accuracy at scheduled intervals, since any drift directly compromises the machine's core precision capability. Regular calibration catches positional error before it affects finished part accuracy.
  2. Monitor Spindle Bearing Condition. Track spindle runout and vibration levels, replacing or servicing bearings before wear degrades surface finish and dimensional accuracy. Early detection prevents bearing wear from compounding into larger precision losses.
  3. Maintain Coolant System Cleanliness and Flow. Check coolant filtration, concentration, and flow rate regularly, since contaminated or insufficient coolant accelerates wheel wear and risks thermal distortion. Clean coolant supports consistent dimensional stability during extended grinding cycles.
  4. Dress Grinding Wheels Routinely. Restore sharp cutting geometry on a scheduled basis, preventing the inconsistent material removal that dull or loaded wheels produce. Properly dressed wheels maintain a consistent surface finish and cutting performance.
  5. Verify Machine Alignment and Level Periodically. Confirm overall machine alignment at regular intervals, since foundation settling or thermal cycling can introduce positional drift that accumulates gradually over time. Prompt correction prevents accumulated error from affecting finished part accuracy.
Which Jig Grinder Components Require Regular Inspection?
Several jig grinder components require regular inspection to maintain the machine's positional accuracy and surface finish capability over its service life. Each component contributes differently to overall precision, requiring specific inspection intervals and methods.
The jig grinder components that require regular inspection are listed below.
  • Spindle Bearings: Spindle bearings require periodic runout and vibration checks, since wear in the component directly degrades achievable surface finish and dimensional accuracy. Excessive bearing wear necessitates replacement before precision capability falls below acceptable limits.
  • Positioning System Components: Leadscrews, optical scales, or servo encoders require calibration verification at scheduled intervals, confirming the machine maintains its rated positional accuracy. Drift in the components compromises hole location accuracy across subsequent production runs.
  • Coolant System: Coolant filtration, flow rate, and concentration require regular checks, since degraded coolant performance accelerates wheel wear and risks thermal distortion. Clean, properly maintained coolant supports consistent dimensional stability during extended grinding cycles.
  • Grinding Wheel Condition: Grinding wheels require routine dressing and inspection for loading, glazing, or damage that would compromise cutting performance. Properly maintained wheels deliver consistent material removal rates and surface finish quality.
  • Machine Level and Alignment: Machine level and overall alignment require periodic verification, since foundation settling or thermal cycling can introduce gradual positional drift. Correcting alignment issues promptly prevents accumulated errors from affecting finished part accuracy.
Can Poor Maintenance Affect Jig Grinding Accuracy?
Yes, poor maintenance can affect jig grinding accuracy. Neglected spindle bearings introduce runout and vibration that directly degrade surface finish and dimensional consistency across finished features. Uncalibrated positioning systems accumulate drift over time, causing hole locations to shift gradually away from programmed or dialed-in coordinates without the operator necessarily noticing immediately. Contaminated or insufficient coolant accelerates wheel wear and risks thermal distortion, introducing dimensional variation that compromises tight tolerance requirements. Dull or loaded grinding wheels produce inconsistent material removal and degraded surface finish, often requiring rework or part rejection. Consistent, scheduled maintenance across all critical components remains essential to preserving the extreme positional accuracy that distinguishes jig grinding from conventional grinding processes.
